I have one of each, Barry King sz 2 and Ron's Edger sz 3, and both are very comparable to what they take off your edges.
As for the Tandy's, they make two different versions,  One rounds the edge, the other squares it off.  I don't like the squaring off versions of their tools at all, I hate them, but have a full set.
There are Youtube vids out there to help you keep them sharp.
Hope this helps
Vikefan
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
On 2/14/2018 at 3:47 PM, YinTx said:
Maybe for some.  My set is rusting in the drawer.
I have one Barry King edger, it does well, but it is really for thin leather since it only takes a tiny bit off the edge.  And you have to rest the leather you are edging on a thicker piece of leather to get it to do it's job.
Tandy edgers work every time.  But I don't like the squared off edge they create.
I have some Osborne edgers, they work, but seem to be geared towards thick thick leather.  They also need a good sharpening to start working, even new.  I have difficulty controlling how much they take off the edge - they can pretty much cut all the way through the leather if I am not careful.
Someone mentioned Feng tools for good edgers I think it was.
Thus, I am on the prowl for decent edgers as well.  With my collection of edgers that don't quite suit me, I'm a bit wary of spending even more $$.
YinTx
 Can't believe the JW edgers didn't suit you did you get a bad set? Hell send them to me i love mine they work perfectly.
Pick up one of the Douglas groover while you are at it, absolute best stitching groover on the market.
  • 1 year later...
I know this thread is old, but I was looking through some old stuff and thought I could add to it.  I know others out there are looking.  I have 3 sizes of the Ron's I bought from Makers leather supply.  I really like them.  they came very sharp.  I believe if you ever need them done, you can send them back and Ron will resharpen them.  and if you are passing anywhere close to MLS you can try them out there.  I believe he will let you send them back if you are absolutely unhappy with them, but they wont disappoint.
I have 6 or 7 various others and do not like any of them.  most I believe are Tandy, and like someone said earlier, it is really easy to go way to deep with the edger.  I even have a Kyoshelin from Japan that I spent over $30 on.  I don't like that one either, it seems like the two points on the side that guide you through the leather want to dig into the leather.
P.S. I know it is misspelled I am at work and don't have it near me.
I use a Tandy #2. It seemed to perform well enough. I got suckered into buying a Horseshoe Brand by one of Nigel's videos.
I got a #1 Horseshoe, which is a close equivalent to the Tandy #2. The Horseshoe would make marks on the top grain when used on inside curves.
 Went back to the Tandy.
What performance difference should I expect with a premium edger? I appreciate quality tools when they provide a qualitative difference.
I mean... in the end, I just going to sand over it all anyway, right?
Vikefan  -- which Tandy edger makes a round profile? I am not familiar with it. Didn't know they made such a thing. Sounds like an actual improvement over what I have.
nick
Edited by wizard of tragacanth
Tandy sell two types of edge beveler
One is a simple, traditional looking tool with a wooden handle, but it doesn't seem to be on their current website, though you can see it in their Deluxe Leathercrafting set #55403-00. I wonder if they're discontinuing it? However it is available from several other suppliers, typical cost is about $12 to $15. Pros - cheap, easy to use and easy to sharpen. Cons - makes a straight cut
The other is their Craftool Pro Classic Edger # 83001, $25-99, which looks more modern, in stainless steel and has a black synthetic handle. Pros - makes a rounded cut. Cons - more expensive, but not impossibly so; needs more care in use and sharpening
An Osborne edge beveller typically costs $32 to $35. After that you're into the top range models, with higher prices
Edited by zuludog
Nigel Armitage has a review on YouTube, called, logically enough, 'Tandy Craftool Edge Beveller Review
Search YT for 'how to sharpen an edge beveler'; there are several videos. I have made a board similar to that by lb custom knives
I have the simple straight cut beveller and a set of the Craftool Pro bevellers #00 to #2 that I got when my local store (now closed) had them on offer. They do need a bit of care & practice compared to the simple one
This kind of edge shave will give you more of a round profile but take a bit more to maintain.
https://www.abbeyengland.com/economy-hollow-edge-shave-3005.html
Hope this helps
JCUK
nick
