Sometimes I make one larger and sometime not (depends on the thicknesses since thinner tends to wander a little more) and also I will use WAXED paper to help prevent premature sticking of items when gluing them.
Good video Dwight thanks. Nice touch where the liner and the outer meet at the buckle end.
That's one hefty belt.
"Oh my God....I beseech thee grant me the grace to remain in Thy Presence; and to this end do Thou prosper me with Thy assistance, receive all my works, and possess all my affections" Brother Lawrence c.1614-1691
plinkercases.ca
  • Replies 31
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
3 hours ago, PJCustomLeather said:
I feel like it would have to be lined with something really thin?
I use webbing if I feel there is a need to add some strength, such as for a dog collar for a big dog, which I made previously and posted details of.
I use webbing which is 8 - 10mm narrower than the belt. The webbing gets glued to both pieces with contact cement.
Kindest regards
Brian
"Whether you think you can or whether you think you can't, you are right"  Henry Ford
Machines: Singer 201p, Kennedy,  Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Thanks Dwight.  I think I am going to give this a go for my next project.
  • 1 month later...
On 6/20/2018 at 11:25 PM, Dwight said:
PJ, . . . depending on the desired thickness at the end of the job, . . . it will be between two layers of 6 oz and two layers of 8 oz.  I like cutting the pieces from the same hide, . . . side by side if I can.
I don't do much custom carving (actually try to avoid it) so I'm not the best source, . . . just giving you the info on how I do it.
The video shows how I put em together.
May God bless,
Dwight
We make heavy-duty gunbelts that are way over 1/4" thick and put 'em together almost exactly the same way. Only differences: I never thought about putting the strip underneath to get a better grip -- I'll have to try that; you have a fancier technique for making the knuckle; we use a heavy-duty lineoleum roller instead of thw wall-paper roller.
Thanks for sharing.
  • 2 weeks later...
I cut my liners 1/4" wider than the face.  That gives me 1/8" on each side for "wiggle room."  I put waxed paper between the two layers when I'm ready to bond them together.  As I set the face down on the liner I roll the waxed paper back as I move along.
"Don't squat with your spurs on."
www.GibsonLeather.com
Me too.  WIth a solid color "plain" belt, doesn't matter if I trim a tad. But a carved belt, trimming really takes away from the look -- especially if there are carved or stamped borders.
5 leather patterns
  • 3 months later...
May God bless,
Dwight
Dwight, I just came across this video while researching belt making techniques.  Can you tell me about the way you have the end of your belt cut where it folds back over and meets up with the liner, please?
That's easy, . . .
When I started making belts, . . . I did not like the way it looked after a while with the two pieces just butting up against each other.  A wrinkle would develop, . . . especially if it was flipped over backwards one or two too many times.
So I set about to find a better way.  That is what I developed.  The one picture shows the tool, . . . just a piece of conduit I sharpened all the way around, . . . cut it half way through (cross ways) the split the cut half and bent them back 90 degrees.  As you can see, . . . they come together nicely, . . . and the irregular shape keeps the belt from developing the "wrinkle".
May God bless,
Dwight
www.dwightsgunleather.com
