Awhile back I was asked about what guides were available for installing zippers into handbags and the like. Over the years I have made a huge range of jigs and guides for various different products but I knew of no multi-purpose type tool that could do this job with out making up special tools like my line up table I've detailed somewhat previously on this forum. What I have come up with no doubt will be improved in time but for my first effort I can say that this guide has performed better than I expected and for those that would like to make copies for themselves I will attach the stl file needed here which you are welcome to use for your own private use. If you just want to buy the parts let me know but I would like to offer it to @Uwe for his rights to sell within the US (if he wants it). This is due to the fact that I admire his contribution and help to so many on this forum and is just my own way of thanking him from us all. Also he has now the equipment for making this stuff and his integrity to service and quality I would trust. For those that want to print it out I will attach some pictures as well.
In this first pic it shows the orientation I recommend to print as it give good strength to the 1mm legs and it works pretty well. I decided on a 30% fill using pla. In this case the 3 pieces took about 17 minutes I think. Bit rough and would be better on my old thing a bit slower perhaps.
This is what it looks like finished on the platform. Bit rough above the holes but they work strongly anyway.
Each piece I cleaned up with a knife and some sandpaper on a flat surface. This takes about 2 minutes to do well each.
Now showing after cleaned up and ready to try out.
A few more printed and cleaned up and pressed down onto No3 YKK nylon chain zip.
Once the guide is pressed on the lot can be handled well as a single unit to work on.
In the picture above you can see another printed guide made specifically for that length zip to make the position on the back for gluing the zipper into place.
These bags linings below were all done using that method I will show more of further down.
This shows what is wrong with doing good quality work......toooooo many bags to make. Over 50 croc bags in this lot and probably near as many to follow next month.  Sorry I went off subject there a bit. I will load this now and have a coffee and be back shortly.
YouTube Channel
Instagram
  • Replies 61
  • Created
  • Last Reply
Top Posters In This Topic
With the purpose made guide It is inserted into the hole and marked around the edges onto the back as shown. The width is the same as the outer edges of the zip.
This is shown on one of the line up cardboards that is used for lining up the clicker knife when cutting the inside slot hole but this is what is done on the leather backing prior to gluing in the zipper into place.
With the new guide the leather can be lowered over the hole to attach or leather can be butted up to the guide on each side.
I found that you can hold the unit in one hand and apply with the other but this was hard to photograph by myself so ......
If you are not needing to glue into place it can be done by most sewing machines by holding the guide up against the foot and feeding in the leather against the guide as it goes through. I did a wobble first try but once I learned how to hold it it went quite easily.
Other side is easier still
As shown below the guide hangs on quite well but can pull out when you want to easily as well.
That's it for now except here is the stl file ZIP JIG3 chain ny.stl
Please if you make it and use it.... post some pics on here for other to see.
Brian
YouTube Channel
Instagram
Note: I will try and get a No5 chain nylon and metal guides done over the next couple of weeks. I got a lot of bags to catch up on first.
Brian
YouTube Channel
Instagram
Brian, Thanks for all the detailed pictures - don’t know where you find the time to photograph everything in such detail!
Zippers are still a bit of a mystery to me - I have some that I want to use in a project - maybe a small jewelry roll.  Just need to get ready to sacrifice some leather while I learn!
Gary
Cowboy 4500, Consew 206RB-4
That's a brilliant piece of design!   Kudos and thank you!   Now I know for sure that I need a 3D printer!
-Bill
RockyAussie;
Would you mind posting the new details and .stl file links in our 3D Printers and Lasers forum? There are a few members lurking there that would appreciate seeing this. You can link to this topic in a post you make in that forum.
I for one will try to find somebody with a 3D printer to make your zipper guides for me (our usual 3D printer guy just moved). I mostly use #5 YKK zippers in Biker wallets and money belts. But, I do use a #4 or 4.5 on occasion.
Posted IMHO, by Wiz
A bit of good old Aussie ingenuity! Nicely done Brian and thanks for taking the time to document this.
A question - what is the red squeeze thingy you're using? I assumed it's for applying glue, but if so what glue are you using that's thin and doesn't clog the tube?
Fantastic, Brian.
Thanks for all of the detail and the .stl file.  Will keep watching for further updates...
"Just love preserving that old black cast iron"
Our Current Industrial Singer Machines - 103K;  31M32;  31K48;  31K47;  132K6;  307G2;  17-8;  45K25;  29K58;  and more coming...
Our Domestic Singer machines - 201K (classic style) with knee controlled motor;  201K (classic style) with hand crank;
201K (aluminium body) with foot controlled motor.
  On 8/18/2018 at 10:28 PM, Wizcrafts said:
RockyAussie;
Expand
I will do that Wiz as best I can. I would be honoured to send you a range of the different sizes as soon as I can get them done. If you decide to get them done faster mention that the scale part in a program like Curra will allow you to make them as long as you want or short and wider as well for various width zips. I don't know with out checking if the piece is made wider for a number 5 zip if the gap from the stitch would be good or not. It may be fine. Your shop address alright to address to?
Expand
That is a glue pot that I converted over from being a brush on style. If you want one H. Leffler and sons should have them. I have plenty of old brushes worn out here and I just break away the outer aluminium part that retains the brush and insert a brass tube that you can get at the hobby stores. I cut it to length and flare one end and force it into the hole. I then hammer around the top edge of the aluminium next to the brass tube to really tighten it into place. A little bit of an angle grind to the tip helps the spreading out. I keep the tip from drying out by keeping it covered by a bigger tube that I have the end squeezed shut on. The one in the picture is a bit of brake tubing.
A bottle made up with a bolt inserted as shown helps to keep a swap over tip or brush ready to
This pic shows the brake tube cover
Another handy thing to store multiple brushes in thinners is a army food dish.
As to the glue (NE - 1820) I buy it from a chemical company in Sydney (PCA Barham pty ltd) in 20 litter drums but your local shoe repairer should be of help. Its just a contact glue. Freight is a killer to get it here.
Brian
YouTube Channel
Instagram
