Is this machine workable on leather projects short of Saddles? I believe it takes 138 thread as the maximum it will use. I make Holsters, Knife Sheaths, thick cowboy type wallets, briefcases and journals, with nothing over about 3/8 inch combined thickness. I want to do decorative sewing on belt blanks also. I have been told that in my HOBBY shop, that a Cowboy 3200 or a Cobra class 3/4 would be overkill, so I need some opinions please:)
Sam
When I spoke to one of the clone  companies they stated they had only tried it on 2 x 1.6mm veg tan which they thought was the maximum, and that was without the upgrade heavy wheel that Sailrite add among other bits
Mi omputer is ot ood at speeling , it's not me
The Sailrite Fabricator is a flat bed versus the Cowboy and Cobra are cylinder machines which can be made into flat bed machine with a table top accessory. If you need the punching power because of the thickness / type of the leather and need 138 thread regularly. Go with a Cowboy or Cobra then add a table top. If you are using mostly thinner / softer leather or other materials and maxing out on 138 thread then look at the Juki 1541s and then get a used cylinder machine for the occasional need.
I looked at a lot of Juki clones and figured that since most of my stuff falls into the maxing out on 138 thread and this would be my main machine I would cry once, buy once. I purchased the best I could afford, a new Juki 1541s and now I am waiting for the right priced (cheap) well loved cylinder machine to come along for the occasional need. The Juki 1541s with a Kobe 550 watt servo motor is a nice little machine. It creeps along as slow as I want through the max material I can fit under the foot and I have even forced material under the foot without any hand spinning the belt wheel, machine baulking, struggle or speed jerking from the start in both straight runs or curves. I am pleased and sometimes impressed with the Juki.
kgg
I owned a Fabricator. Nice machine for what it is built for - heavy canvas, sails, upholstery and light leather. It is NOT a dedicated leather machine. The machine head itself is nice and Sailrite tunes it perfectly, and the Sailrite motor is great. However, if your hobby includes sheaths, holsters etc then the Sailrite machine will struggle punching through some of that. It *can* do it occasionally but it's not built for it and hammering it with heavy leather projects will wear it out prematurely.
I would look at something like Artisan's copy of the Juki 1508H or a similar machine if you wanted to go for a reasonably priced heavy flatbed, or just go for the Cowboy 3200 and don't let anyone put limits on your hobby.
You say nothing over 3/8", but I'll bet that if you get a machine that can do a bit thicker then you'll end up doing just that. A 3200 "might" be struggling to do really light stuff (in which case buy an old domestic machine for that) but overall it's probably the closest we hobbyists can get to a good all-round machine. If you make stuff heavier than it can handle then you're getting into the realms of the heavy stuff - the 4500/441 machines.
A 3200 would probably be the ideal machine for what I do - only problem is the cost.
Sorry it looks like i confused it with the cheaper sailrite version ultrafeed
  • 4 months later...
kgg
KGG-- how are you still liking your Juki 1541? Im on the market for a machine. Was looking at the Sailrite Fabricator but I did some research and also read this thread..I called a local guy near me and he mentioned the Juki 1541 to me. Also not crazy about the price for my first personal machine.. (im a shoe cobbler and have plenty experience w/ sewing at the shop, but I dont have a leather machine for my own use)... but i will bite the bullet and pay for what i gotta pay for. I havent went to try out the Juki just yet, i plan to this week. Just looking for feedback from someone who has the machine.
Lance
Hi Lance,
I have found that my Juki 1541S has meet / exceeded my expectations with no problems (knock on wood) other then the dumb pedal user. If I can force it under the presser foot it will sew it. Most of my stuff incorporates hard back 1200 gsm Sherpa, high density rubber, ripstop material all of which is dog related. In the topic " Work Bench Lighting" you can see in the second photo the off-white Sherpa that is just shy of about 2" (the beginnings of a dog bed). I just completed a custom sized one two days ago for a client that was just over 2" thick. When this material was compressed down it just managed to fit under the foot. As far as leather I have only done a couple of layers of light upholstery leather. The machine still amazes me as to what abuse I can ask of it.
If the Juki will do the job I would advise you to get the Juki 1541"S" which has the built in safety clutch not the Juki 1541, it could save you a repair bill down the road. Also don't forget to bring some samples of the thickness plus a bit of what you are planning on using.
kgg
kgg
You may be better off buying a Consew 206RB-5 than a Juki DNU-1541. Some buyers have reported repeated problems with that Juki model (problem 1problem 2,   problem 3).
Posted IMHO, by Wiz
Your area I believe is fortunate and has some dealers. Some are frequently on the forum here.
Your capability sounds like a real benefit to many of us.  An interest I have in trying to help answer is your actual machine usage.
I have an answer and still want to say there are many used machines in storage or basements looking for new owners.
As always smart reasons to talk with brick and motar companies is the personal walk in option. With that the first sew machine dealers I ever talked to are mentioned also on this forum frequently.
I really do appreciate and respect these dealers here, and that I have purchased items from. With some of their assistance in peices and parts like motors, needles, table tops and reducers they have moved my basement, garage, gov surplus and in a barn sewing machine purchases to a success for my needs.
To make this post complete, this specific forum has been my go to for machine tech. and learning my patience in particular learning my machines tips and tricks.
Good day
Floyd
