Members myjtp Posted October 16, 2018 Author Members Report Posted October 16, 2018 (edited) On 10/16/2018 at 6:41 PM, CowboyBob said: Those 135x17 are for cloth...order what I wrote 135x16D like I said is for leather. Expand whoops how about these? https://www.sailrite.com/Schmetz-Needles-135x16-DI-20-Pack-10 Let me know and I will just order them from you since you have been so helpful! thanks! Edited October 16, 2018 by myjtp Quote
CowboyBob Posted October 16, 2018 Report Posted October 16, 2018 It's a step in the right direction BUT the pulley only has on set screw & if you start sewing anything very thick in time it won't hold,that's why they put 2-screws in the original pulley that line up with the grooves in the shaft. On 10/16/2018 at 6:49 PM, myjtp said: whoops how about these? https://www.sailrite.com/Schmetz-Needles-135x16-DI-20-Pack-10 Let me know and I will just order them from you since you have been so helpful! thanks! Expand Sailrite is high priced on everything they sell,we sell the for $4.00 a pk. Quote
Members myjtp Posted October 16, 2018 Author Members Report Posted October 16, 2018 On 10/16/2018 at 6:54 PM, CowboyBob said: It's a step in the right direction BUT the pulley only has on set screw & if you start sewing anything very thick in time it won't hold,that's why they put 2-screws in the original pulley that line up with the grooves in the shaft. Expand Do you have a good 6" pulley with the two set screws in the same spot as stock pulley? Quote
CowboyBob Posted October 16, 2018 Report Posted October 16, 2018 No,I priced one from Pfaff once & it was $150.00 (still cheaper than a reducer & servo) BUT you need a servo anyways. Quote
Members myjtp Posted October 16, 2018 Author Members Report Posted October 16, 2018 On 10/16/2018 at 6:58 PM, CowboyBob said: No,I priced one from Pfaff once & it was $150.00 (still cheaper than a reducer & servo) BUT you need a servo anyways. Expand Sent you a message to your inbox Quote
Members myjtp Posted October 16, 2018 Author Members Report Posted October 16, 2018 This pulley might do the trick? http://www.grizzly.com/products/Grizzly-Single-V-Groove-Pulley-6-Pitch-Dia-1-2-Bore/G5436 Quote
Members dikman Posted October 16, 2018 Members Report Posted October 16, 2018 That should work. The other option is to drill and tap that other one for a second screw, which I've done on a couple of pulleys. I've run a smaller belt like that and so far it's been fine. There is a possibility that it may slip, depending on the fit in the pulley, but so far it hasn't been an issue for me. The alternative is to fit a larger belt, which will then ride a bit higher on the motor pulley but will still work. The only potential issue with a wider belt is that it may be be a bit stiffer. I've done both. This is one I've just finished - As you can see the belt is low in the pulley, but it has driven a size 24 needle through 1/2" of veg without slipping/stalling. Quote
Members myjtp Posted October 16, 2018 Author Members Report Posted October 16, 2018 So I just cleaned out the bottom gear of all the old grease now I need to clean out the upper gear BUT this plate with the wicks are in my way :/ anyone know how to pull these out? One of the wicks is knotted and and few other ones are keeping the plate down any ideas? Quote
Members councilman24 Posted October 17, 2018 Members Report Posted October 17, 2018 I just got a 206RB-3 for $300 on table and motor. But in order to get that deal I had to take a 331k4 singer shuttle machine and a 111wsv77 for $100 each, on tables. And they threw in a Rimaldi 4 thread serger on table for free. Hmm, four machines that were in use when turned off for $500. I couldn't say no, even though 2 weeks later 3 of the tables are still on the trailer because I don't have any room in the house OR garage for them. I'll have to read all the advice above. Too late now. Did we ever decide exactly what the 111w special variant 77 was? I have a 111w151 and 155. I guess I'll have to set them next to each other and see. Quote
Members dikman Posted October 17, 2018 Members Report Posted October 17, 2018 Well done, councilman! Sounds like a real good deal to me. I had the same problem (still have, actually) regarding lack of room. My solution - dismantled my glasshouse, sold it (got more than I paid for it ) and built a small shed in place of it for the sewing machines. Unfortunately, I ran out of room again and now have one in my garage. As for the WSV77, after comparing parts in mine to the 111W15x manuals the best I can figure out is that it appears to be the same as a 111W153. It's definitely not a W155, but I'll be interested in your thoughts after comparing it to the W151. Quote
Members chrisash Posted October 17, 2018 Members Report Posted October 17, 2018 On 10/16/2018 at 6:54 PM, CowboyBob said: It's a step in the right direction BUT the pulley only has on set screw & if you start sewing anything very thick in time it won't hold,that's why they put 2-screws in the original pulley that line up with the grooves in the shaft. Sailrite is high priced on everything they sell,we sell the for $4.00 a pk. Expand I am confused, is it not the key that takes all the power transfer rather than the allen keys that just hold the wheel into place, so id if in alignment with the motor have little work to do Quote
CowboyBob Posted October 17, 2018 Report Posted October 17, 2018 On 10/17/2018 at 8:26 AM, chrisash said: I am confused, is it not the key that takes all the power transfer rather than the allen keys that just hold the wheel into place, so id if in alignment with the motor have little work to do Expand The shaft has 2-grooves on it approx. 45degrees apart that the head of the screw seats into,there is no keyway on these machines. Quote
Members chrisash Posted October 17, 2018 Members Report Posted October 17, 2018 Thanks, it just seemed odd, I assumed that all had a keyway Quote
Members myjtp Posted October 17, 2018 Author Members Report Posted October 17, 2018 On 10/17/2018 at 6:36 AM, councilman24 said: I just got a 206RB-3 for $300 on table and motor. But in order to get that deal I had to take a 331k4 singer shuttle machine and a 111wsv77 for $100 each, on tables. And they threw in a Rimaldi 4 thread serger on table for free. Hmm, four machines that were in use when turned off for $500. I couldn't say no, even though 2 weeks later 3 of the tables are still on the trailer because I don't have any room in the house OR garage for them. I'll have to read all the advice above. Too late now. Did we ever decide exactly what the 111w special variant 77 was? I have a 111w151 and 155. I guess I'll have to set them next to each other and see. Expand Now THAT is one hell of a deal!! On 10/17/2018 at 8:20 AM, dikman said: Well done, councilman! Sounds like a real good deal to me. I had the same problem (still have, actually) regarding lack of room. My solution - dismantled my glasshouse, sold it (got more than I paid for it ) and built a small shed in place of it for the sewing machines. Unfortunately, I ran out of room again and now have one in my garage. As for the WSV77, after comparing parts in mine to the 111W15x manuals the best I can figure out is that it appears to be the same as a 111W153. It's definitely not a W155, but I'll be interested in your thoughts after comparing it to the W151. Expand Sounds like it’s time for a two story shed! Quote
Members myjtp Posted October 18, 2018 Author Members Report Posted October 18, 2018 Well, color me impressed with the 206RB-2 it sewed through 3 layers of VEG TAN equaling 3/8 thick of veg tan. I don't think its the proper needle and definitely not the proper thread so I can't wait to get those and then give it a try Quote
Members councilman24 Posted October 20, 2018 Members Report Posted October 20, 2018 On 10/17/2018 at 1:11 PM, myjtp said: Now THAT is one hell of a deal!! Sounds like it’s time for a two story shed! Expand I'm building a shed to move things like generator, power washer, etc out if garage so I can fit more in there. Must be up to 15 on tables including 30 inch arm and 7 class, three tables still on the trailer, one 29-4 treadle stand, one 7 class table in storage while I work.on head, and my grandmothers old treadle home machine. Is there a 12 step program for us? Two have been for sale for 5 years, but only advertised on craigslist once 5 years ago Quote
Members myjtp Posted October 21, 2018 Author Members Report Posted October 21, 2018 Finally got the thread balanced right and tested it on some veg tan with hard lizard skin glued on top and that machine ate through it like butter! Now I just need to figure out the best edge coating to use and I’ll be off to the races! Quote
Members myjtp Posted October 23, 2018 Author Members Report Posted October 23, 2018 (edited) Just installed a 6” pulley 1/2” Bore from grizzly and it fits perfectly and has two screws which will grip the shaft perfectly. Slows the machine down to the perfect speed for leather IMO. 45mm pulley installed on the servo motor the combo is excellent. YEQIN Industrial Sewing Machine Clutch Motor 45mm Pulley Slow Speed Down Universal Fit (45mm) https://amzn.to/2q6qtQ7 Grizzly G5436 - Single V-Groove Pulley - 6" Pitch Dia., 1/2" Borehttp://www.grizzly.com/products/Grizzly-Single-V-Groove-Pulley-6-Pitch-Dia-1-2-Bore/G5436 https://i.imgur.com/zqI8OgB.gifv Edited October 23, 2018 by myjtp Quote
DonInReno Posted October 23, 2018 Report Posted October 23, 2018 Nice! The cast iron looks right at home on that machine Quote
Members myjtp Posted October 26, 2018 Author Members Report Posted October 26, 2018 Alright finally got the proper length new belt and painted the new pulley to match the badge color of the consew logo background ( yup I’m weird ) now I’m waiting for my edge guide to come in and I’ll be off to the races! Quote
Members myjtp Posted November 5, 2018 Author Members Report Posted November 5, 2018 Just installed an edge guide and man that helps sooo much keeping the leather straight! Quote
Members councilman24 Posted November 5, 2018 Members Report Posted November 5, 2018 (edited) Never mind Edited November 5, 2018 by councilman24 Quote
Members Colt W Knight Posted November 8, 2018 Members Report Posted November 8, 2018 On 10/14/2018 at 7:07 PM, JLSleather said: SOmebody correct me if I'm wrong, but I think that consew is a 135x16 needle, prolly range size from like 16 to 22 or 23. Thread maybe size 42 to 138? You STEALIN again Seriously, I owe ya a beer for NOT telling my wife about any of this.. she LOVES to buy stuff whether I need it or not! Congrats! Expand I have some #25s I bought for mine(206-rb1) to sew biothane. I never could get 206 thread to work on mine, so I use 138 with a 23 needle. Have a hard time sewing with a #22 needle. But my machine has definitely been used hard for 40 years. On 11/5/2018 at 12:07 AM, myjtp said: Just installed an edge guide and man that helps sooo much keeping the leather straight! Expand Oh yeah, edge guide is a god send, especially on long belts. I turn the speed up and mine actually sews better. It will sew very slow, but it prefers fast. Quote
Members luxuryluke Posted March 3, 2019 Members Report Posted March 3, 2019 Thanks for the more info on servos! Quote
Moderator Wizcrafts Posted March 3, 2019 Moderator Report Posted March 3, 2019 On 3/3/2019 at 8:35 PM, luxuryluke said: Thanks for the more info on servos! Expand What ever are you talking about? This topic was about older Consew 206rb machines with clutch motors and large aftermarket pulleys on the top shafts. Quote
