Members jbennion Posted May 29, 2019 Members Report Posted May 29, 2019 I just bought two Singer 97-10 sewing machines at an auction. One is a parts donor, but the other seems to be all original, even the motor. I have never used a sewing machine before, and would really appreciate some help in the form of tutorial, advice, resources, and maybe even a shop visit to someone who uses one. Any advice would be appreciated. I don´t even know what kind of thread to use. Quote
Northmount Posted May 29, 2019 Report Posted May 29, 2019 @jbennion Moved your post to leather sewing machines. You are more likely to get answers here. You might like to add your location to your profile since you are interested in visiting a shop. You might get invitations from Mars or Venus otherwise! This is a worldwide forum. Have you done any internet searches for Singer 97-10? there are manuals available on some sites. Welcome to the forum. The best all around leather working site available. Tom Quote
kgg Posted May 29, 2019 Report Posted May 29, 2019 There was discussion on the Singer 97-10 a while back such as "Singer 97-10 Users? Questions ". Just do a search in the search at the top and you should get some good info. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members trash treasure Posted May 30, 2019 Members Report Posted May 30, 2019 21 hours ago, jbennion said: I have never used a sewing machine before Wow, for having never used a machine before, you're starting right at the top of the hill! I'm envious Quote The model number giveth, and the subclass taketh away ......... Sometimes
Members jbennion Posted May 31, 2019 Author Members Report Posted May 31, 2019 Thanks, yall. I've found a couple manuals, and read several of the posts here. I finally figured out how to thread the machine. I did hane to pull a part from the donor. # 58797 according to the manual. The brass piece broke and had been soldered. The old motor doesn't work, but with the machine threaded i was able to see a seam manually. I'm on cloud nine. Any suggestions on a suitable motor? Quote
CowboyBob Posted May 31, 2019 Report Posted May 31, 2019 You only need that part called the thread lock for when your sewing real thick leather like 3/4" or so.You can use a 1/2 -3/4 HP motor. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members shoepatcher Posted May 31, 2019 Members Report Posted May 31, 2019 You could get the motor rewound or as Bob stated, get a new motor. I have some needles for that machine if you need some. glenn Quote
Members jbennion Posted May 31, 2019 Author Members Report Posted May 31, 2019 Thanks, Bob and Shoepatcher. I think i will take the motor into my local electric shop and have them peek at it. Since i have two I'm thinking about taking the head off the donor machine, if i can cobnle enough parts to make it run, and putting it on a table. Would you recommend a servo motor or a clutch motor, and if so what sive would run this? I plan on doing projects up to 1/2", but dont wnat to be limmited should the need arise. If anyone has one of these working in either original or non-original condition would you mind sharing a photo of the set up? Most abliged. Quote
Members dikman Posted May 31, 2019 Members Report Posted May 31, 2019 If you've never used a sewing machine then fit a servo, you will save yourself a lot of grief and frustration! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members DavidMillsSaddlery Posted June 1, 2019 Members Report Posted June 1, 2019 14 hours ago, dikman said: If you've never used a sewing machine then fit a servo, you will save yourself a lot of grief and frustration! This has a built in clutch in the base... I’m not sure a servo would move this heavy of a flywheel? Quote
