So we need to replace the motor to my mom's Singer 29K60 machine.
She had an old school Dayton Sewing Machine Conversion Kit installed ( 1/15hp, 115 Volts AS-DC) Model 2X420.
Seems like Dayton may have gone out of business. Are there other options to procure another motor kit?
I saw some online such as this, but want to ensure I'm buying the right one.
Thanks so much.
Your link is to a regular domestic textile sewing machine motor. What does your mom want to do with her patcher?
Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
The only way you're going to get help on this forum is to post pictures of the motor and its path to the machine pulley. We are used to dealing with motors rated at 1/2 to 3/4 horsepower, not 1/15th.
As for the type of motor you linked to, it is a typical throwaway household sewing machine motor and vari-speed pedal. They are sold by numerous domestic sewing machine dealers, rebuilders and enthusiasts. The price seems unusually low to me. I usually see these combinations sell for 50 to 70 bucks. I wouldn't trust or even plug in anything that cheap.
A Singer patcher is best powered by a 1/3 HP to 1/2 HP motor.
Posted IMHO, by Wiz
One of the Singer 29K70 machines that I have came to me with a household sewing machine motor fitted to it.  Actually, it worked fairly well for fabrics and thin leathers, which is about all that the 29-series is good for sewing anyway.  They had mounted the motor on a small piece of thin angle iron screwed to the shoulder of the head, and ran a 3/16-inch round leather belt on it.  The basic household foot control was mounted with one screw onto the top of the normal 29-style treadle stand under the machine pillar, had a hole drilled in the foot pedal, and had a small chain attached down to the original treadle stand foot plate.  I believe that my motor was a Dayton, but I can’t seem to locate any photos of its nameplate, and no telling where the motor is now.  I stripped it all off of the machine immediately and converted it back to treadle years ago.
The problem that you may run into is the pulley size on the replacement household motor.  It seems like it needs to be as large as the pulleys on the 29K in order to avoid belt slippage. Maybe you can use the pulley off of the old motor?  My Dayton motor had a pulley on it that matched the pulleys on the machine head, and was wider/deeper than normal household pulleys, so the 3/16” belting worked fine.
CD in Oklahoma
"I sew, I sew, so it's off to work I go....."
My sewing machines:
Adler 205-370 (Hand Crank), Adler 205-64 (Hand Crank), Consew 226 (Clutch/Speed Reducer), Singer 111G156 (Hand Crank or Clutch), Singer 111W153 (Clutch), Singer 20U33 (Clutch), Singer 78-3 Needlefeed (Treadle), Singer 20U (Treadle), Singer 29K70 (x2) (Both Treadle/Hand Crank), Singer 96-40 w/Darning Foot (Treadle), Singer 31-15 w/Roller Foot (Treadle), Singer 31-15 (Hand Crank), Singer 16-41 (Treadle), Singer 66-1 (Treadle/Hand Crank), Singer 201K4 (Treadle/Hand Crank), Singer 216G Zigzag (Treadle/Hand Crank), Singer 319W (Treadle)
Thanks so much.
Unfortunately I don't have an actual photo as I live across the country, but my parents did share this with me which is the current configuration that they have setup at home. This looks identical to what cdthayer has done with his sewing machine
Edited by Hoowzer
20 hours ago, Hoowzer said:
iSo we need to replace the motor to my mom's Singer 29K60 machine.
Thanks so much.
That motor won't be strong enough to run it with 0.9 amps,there is a 1.5 amp motor available that we stock if you need one.
Edited by CowboyBob
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
That was an error.  I should have said 1/4" round leather belting.
CD in Oklahoma
My sewing machines:
Is it a new motor? Can you share model and pricing?
Hoowzer
I would guess if the old motor worked and you were happy with it then just get a replacement from the same makersee https://www.ebay.com/c/1684286080
But there is also plentiful simular motors at very low price on  ebay with a larger power
It all depends on what you want to sew and how thick it is especially if veg tan as most patchers would probably have been used on Chrome leather for shoes and boots
Hobby people like myself with little money from a pension, have to make do with what we can afford, in my case using leather under 2mm mostly about 1.4mm to make things and have a Singer 201 domestic machine (uprated from 60W to a massive 90W) that can sew the thin chrome leather ok with 69 thread and I also have a 29K53 which will do the veg tan and canvas, neither is perfect for the job and I would love a better option, but hard to justify
Sometimes the professionals sell you the perfect answer to your needs and sell you a car, when a bicycle will do the job but not as well
ps Massive was tongue in cheek
Edited by chrisash
Mi omputer is ot ood at speeling , it's not me
It is not the motor which would screw you up - it is the pedal. If you have an old style nichrome coil pedal, then it would overheat when running a more powerful motor then stock.
