Members coma44 Posted October 2, 2019 Members Report Posted October 2, 2019 Add says "Chandler" but no model numbers any one here know what this machine actually is. https://newhaven.craigslist.org/tls/d/new-milford-chandler-sewing-machine/6990386393.html Chandler sewing machine Quote
Members shoepatcher Posted October 2, 2019 Members Report Posted October 2, 2019 That is an Adler 67-373./ Chandler was a distributor for Adler in America for a number for years. Good machine. glenn Quote
Contributing Member LatigoAmigo Posted October 3, 2019 Contributing Member Report Posted October 3, 2019 The link conntects to these images: Quote
Members shoepatcher Posted October 3, 2019 Members Report Posted October 3, 2019 (edited) , and yeah. Any chance of getting more pics of the needle bar area? The take up lever guide is all bent to hell. That needs to be removed and straighten. Send more pics of the head from different anglws if you can. The bobbin winder is missing the drive wheel, slide plates missing just so you know. Pic of the aluminum model in back of the machine. glenn Edited October 3, 2019 by shoepatcher grammar Quote
Members Gregg From Keystone Sewing Posted October 4, 2019 Members Report Posted October 4, 2019 (edited) The bent part is the take up lever cover that will easily bend back into place. The REAL concern is the take up lever, and I can't see if it's there or not from the poor quality image even after blowing it up. It may have snapped off. New this item sells for over $280 so buyer beware unless you are looking for a parts machine. Edited October 4, 2019 by Gregg From Keystone Sewing Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
mikesc Posted October 4, 2019 Report Posted October 4, 2019 yep ..magnified waaay up..the take up lever is not there..broken off ? with maybe damage to other expensive parts when it broke ? Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
Members Constabulary Posted October 4, 2019 Members Report Posted October 4, 2019 (edited) well to me it looks like the take up lever is there its in its upper position. But seems both slide plates are missing What I would check is the condition of the timing belt. if it is brittle or cracked I would not buy the machine. You may get the belt for $30-50 or so but replacing it is a pain. I did that once for a friend and it was no fun. Replacing a timing belt on a Singer 111 is like a breeze compared with the Adler. I just checked - it was approx 4 years ago: Edited October 4, 2019 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
mikesc Posted October 4, 2019 Report Posted October 4, 2019 I'm thinking like Gregg..that looks like the other part of the bent take up lever cover, to me looks like the bent cover was jammed back into the take up lever slot..or, it might be the take up arm, but..without better photos, or someone actually seeing it "in the flesh"..no way to know for sure..if the only thing wrong is a bent cover ( and the take up lever is there and not damaged ) could be a good deal..Looks like the two bed covers ( bobbin / hook cover and the one from the other side of the needle area ) are also missing. Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
CowboyBob Posted October 5, 2019 Report Posted October 5, 2019 Try to make sure it has a rubber timing belt in it because the cloth ones aren't available anymore,you can convert it to rubber but you'll need new top & bottom pulleys to match it cost over $300.00. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Gregg From Keystone Sewing Posted October 7, 2019 Members Report Posted October 7, 2019 On 10/5/2019 at 12:29 PM, CowboyBob said: Try to make sure it has a rubber timing belt in it because the cloth ones aren't available anymore,you can convert it to rubber but you'll need new top & bottom pulleys to match it cost over $300.00. I have at least one machine with this issue, and it has a cloth timing belt as well with no replacement. Otherwise bulletproof machine. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
