Hi!
Made my first SD case yesterday. But I was wondering, is it possible to hide the stitching on the outside? I'm not sure if I like seeing it when the case is closed. Maybe it's just me idk.
Thanks!
Nice. Looks functional. Only thing is do is add some type of closure like a snap, Sam brown stud, or strap closure. But that's not required.
You can't hide the edge seam stitches unless you do a glue only construction. Which would work ok if you really wanted to.
The stitches in the center you can hide by lining the case. Basically you do what you already did, just stitch the pouches to the grain side. Then glue the flesh side of that piece to the flesh side of another piece of leather and stitch around the perimeter.
You get a nicely lined case and no visible outer stitching except the perimeter seam.
Wot he says.   :17:
Another idea. Take the SD cards out. Wet the centre of the case, fold over to find the centre line, gouge a shallow trench along that centre line. If you don't have a gouge use something to press a good hard line on the centre line. Still being wet, fold over again and then tap the fold with a mallet [not a steel hammer]. Let it dry and the case will have a preferred fold to it
One approach is to make the back quite long, like a flap.  It can then wrap around the entire case, sort of like a tool roll or big trucker wallet.
Another approach is to make it with a third piece of leather that is stitched only around the edge.
I like the stitching showing, but would use a contrasting colour to the leather, so that the stitching is prominent and a focal point
Mi omputer is ot ood at speeling , it's not me
Expand
Yep its just you .....it looks good as is and nice any minimal in just a good way.:thumbsup:
YouTube Channel
Instagram
Same opinion. It’s just you :)  it looks like a hand made leather case. Nicely done and looks great.
Short of adding another layer of leather on the "outside", I don't think there's another way to hide the stitching. You can perhaps make a sleeve similar to a slip in sheath for spectacles - that will also secure the sd cards better (looks like you didn't use any form of snap or other closure on the case).
"People are more violently opposed to fur than to leather because it's safer to harass people in coats than to try being nasty to motorcycle gangs." ~Anonymous
  • CFM
If you're concerned about the stitching you can use 0.6 mm Tiger thread, or you can try to do something artistic with it that makes it a feature instead of an 'eyesore', such as using thread of a complementary colour.
Thanks everyone for the tips & comments! Will try them out next time!
Made a small version as well this evening haha, I think I'm addicted already.
  On 10/6/2019 at 7:39 PM, Hardrada said:
Neat! What leather did you end up buying for this?
I can't see your edge work on those photos. Did you bevel and burnish or did you just leave it plain?
Expand
I used 2mm Veg tanned leather from Ebay! (this one)
And yes, I did bevel and burnish it, it did wonders to the final piece!
Edited by Tyra
  • CFM
Expand
:clapping:
Now you need to make a version for CompactFlash, or a combo for both types. Sell them to your fellow photographers!  :thumbsup:
  On 10/6/2019 at 9:40 PM, Hardrada said:
:clapping:
Expand
Ha love the idea! :)
I'm currently looking into buying/making a stamp to put some kind of logo on my creations!
