Members chrisash Posted March 13, 2020 Members Report Posted March 13, 2020 Motors off the machine give you far more flexibility for the future if you need to get a new one rather thanĀ a built in version Quote Mi omputer is ot ood at speeling , it's not me
toxo Posted March 13, 2020 Author Report Posted March 13, 2020 3 hours ago, Constabulary said: also - do you notice the beeeeeeeep sound while he is sewing? It comes from the motor - I had one of these "beeeper" servo motors and I found it totally annoying and sold the motor. I could not stand it on longer projects. back then seller said it will disappear - but it did not! So check what motor you will have on the machine. I had to have another look Folker. I never noticed it before but I can see where it would annoy. I wonder if they're all the same? Is it definitely the motor and not the machine? If it's the motor there may be a £130 discount for a machine sans motor and a call to College machines! Quote
toxo Posted March 13, 2020 Author Report Posted March 13, 2020 1 hour ago, chrisash said: Motors off the machine give you far more flexibility for the future if you need to get a new one rather thanĀ a built in version Absolutely Chris. And I don't want to lose the ability to put a bigger pulley on the hand wheel. Harry has speed reduction pulleys on that machine in the video. Quote
toxo Posted March 13, 2020 Author Report Posted March 13, 2020 Another twist. Just spoke to Maury in London. He has a Durkopp 269 and a Adler 069. After a quick search I found this Adler 069 on ebay which is probably the same one. Waiting for pics of both. Pros and cons please over the tysew? https://www.ebay.co.uk/itm/durkopp-adler-069-Walking-Foot/223580347023 Quote
toxo Posted March 13, 2020 Author Report Posted March 13, 2020 More news. Apparently the Tysew I've been looking at is a copy of the Juki DSC 245. It's the same as the Wimsew 245 and the Japsew DSC 245. He has a Japsew in the shop at the moment. I'll take a trip to JT Batchelor early next week and call in to take a look at these machines. Matt. if you want that cuppa Ā why not meet up there? Quote
Members Matt S Posted March 13, 2020 Members Report Posted March 13, 2020 9 hours ago, Constabulary said: also - do you notice the beeeeeeeep sound while he is sewing? It comes from the motor - I had one of these "beeeper" servo motors and I found it totally annoying and sold the motor. I could not stand it on longer projects. back then seller said it will disappear - but it did not! So check what motor you will have on the machine.  5 hours ago, toxo said: I had to have another look Folker. I never noticed it before but I can see where it would annoy. I wonder if they're all the same? Is it definitely the motor and not the machine? If it's the motor there may be a £130 discount for a machine sans motor and a call to College machines! That was the servo that Wimsew used to supply with their machines. I had one, and it beeped. No speed limiter or provision for EPS/NPS either. They now supply Jack servos with their machines IIRC. 4 hours ago, toxo said: Just spoke to Maury in London. He has a Durkopp 269 and a Adler 069. After a quick search I found this Adler 069 on ebay which is probably the same one. Pros and cons please over the tysew? Adler 69 is pretty much a Pfaff 335 -- small cylinder with 2-motion/oscillating feed dogs and relatively small H-size bobbin. Adler 269 is more of a Singer 153/Seiko CW8/Cowboy 227 -- a larger 75mm nose with larger M-type bobbins and a 4-motion/elliptical feed. You'll likely have about a 7mm distance from the end of the arm to the needle with both of these, unless they're some special subclass or modification. The 69 will probably top out at TKT40/V69 thread and the 269 TXT20/V138 thread, but both can probably go up another size in the needle, or maybe top and bottom with a timing tweak. You'll probably get about about 9-10mm sewing capacity in the 269, and a few mm less in the 69. You can see scans of the original brochures for these machines here:http://www.duerkopp-adler.com/commons/download/download-text-attachments/Vintage_Leaflets_Adler/Leaflets_Adler_Class_69.pdfhttp://www.duerkopp-adler.com/commons/download/download-text-attachments/Vintage_Leaflets_Adler/Leaflets_Adler_class_269.pdf One advantage that these have over the Tysew, Typical and Global machines is that they were German made. German engineering speaks for itself. Quality of manufacture in a sewing machine leads to less noise/vibration in use, less "walking out" of settings, easier accessory compatibility, easier adjustment and less chance for parts to bend, break or strip screw threads. 2 hours ago, toxo said: Apparently the Tysew I've been looking at is a copy of the Juki DSC 245. It's the same as the Wimsew 245 and the Japsew DSC 245. He has a Japsew in the shop at the moment. I'll take a trip to JT Batchelor early next week and call in to take a look at these machines. Matt. if you want that cuppa  why not meet up there? I had a Wimsew W246 for a while. It's definitely an improvement in features over a 335-type machine, in that it has a small 50mm nose but a larger M-size bobbin, a 4-motion/elliptical feed dog and is happy with TKT20/V138 thread. On a real Juki I'm sure it works excellently but the example I had (which had been much abused by a previous owner) certainly wasn't up to Juki quality. Perhaps I got a lemon, perhaps the the water and welding spark damage the previous owner did to it tipped it over the edge, perhaps they improved their quality since. However it's not something that I want to invest my money or remaining sanity into any time soon. Yes let's meet up and visit Maury. I need to go to Batchelor's next week anyway. I'll PM you my number tonight. Quote
Members Silverd Posted March 20, 2020 Members Report Posted March 20, 2020 What bobbin type (L or M) does the 335 use? Ā Silverd Quote
Members Constabulary Posted March 20, 2020 Members Report Posted March 20, 2020 Pfaff 335 came with different size hooks, the new type is using larger bobbins. I think both have approx 22mm diameter but the new bobbins are a bit higher by afaik 3-4mm or so. So I think neither L nor M - rather G I“d say but not 100% sure of the exact type Quote ~ Keep "OLD CAST IRON" alive - it“s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Matt S Posted March 21, 2020 Members Report Posted March 21, 2020 According to Threadexchange the 335 takes a H bobbin. I assume that's the older/smaller hook version. Quote
