Members scrapyarddog Posted August 13, 2020 Members Report Posted August 13, 2020 Still not 100% sure how to perfect the corners but at least now the blades are sharp enough and turned edges are light enough. Alran Sully Red, Fil Au Chinois 632 Rouge. Quote
Members plinkercases Posted August 13, 2020 Members Report Posted August 13, 2020 Well done. There are book binder videos on how to come around corners if you search around. Quote
Members battlemunky Posted August 13, 2020 Members Report Posted August 13, 2020 Super clean work. Personally, its a bit one noted being all the same color but I'm sure it'll sell without a doubt. Quote
Members scrapyarddog Posted August 14, 2020 Author Members Report Posted August 14, 2020 15 hours ago, plinkercases said: Well done. There are book binder videos on how to come around corners if you search around. Thanks. I did view a few but binding is thin leather wrapping a harder, thicker base. It’s a little different from turning .4 mm back onto .6-.8 mm goat. Or maybe for the corners I should pare 1.2 mm to .4? Poor goats. Gonna keep skinning them til I figure out. Quote
Members scrapyarddog Posted August 14, 2020 Author Members Report Posted August 14, 2020 5 hours ago, battlemunky said: Super clean work. Personally, its a bit one noted being all the same color but I'm sure it'll sell without a doubt. Thanks but I can see the issues like all self conscious makers do. This is a custom request and I let the buyer decide the goat hide he wanted. I’d love to make a red / pink one. Quote
Members Stetson912 Posted August 20, 2020 Members Report Posted August 20, 2020 Do you mean stitching the corners or making the turned edge meet nicely when you turn it? For the first, a small round hole instead of angled hole will help stitches lie better. And i like to start in the corners and pick towards the middle. So my stitching lies perfect in the corner. Unless I round my corners, then it doesn't much matter. For the turning, you simply clip the corner off. Then when you turn the edge they line up nicely . Hope my silly drawing makes sense. Quote
RockyAussie Posted August 20, 2020 Report Posted August 20, 2020 What @Stetson912 said is correct but I will add that you need to come out from the corner edge, the thickness of the product (normally between 1 or 2mm). I do this by resting a straight skiving knife against the corner holding it on a 45 degree angle or a little more. The thicker the piece then the distance out is wider and if thinner its less. I would get some cardboard squares and glue onto some leather bits and practice the technique until it works every time on a few thicknesses. With practice you can get a rounded corner using the same technique as shown in this pic below. Quote
Members Stetson912 Posted August 21, 2020 Members Report Posted August 21, 2020 @RockyAussie thanks for that addition. I responded quickly because I was at work and thought about the thickness of what the binding was covering after the fact, but it is an important aspect to making it come out right Quote
Members scrapyarddog Posted August 24, 2020 Author Members Report Posted August 24, 2020 On 8/20/2020 at 3:08 PM, Stetson912 said: Do you mean stitching the corners or making the turned edge meet nicely when you turn it? For the first, a small round hole instead of angled hole will help stitches lie better. And i like to start in the corners and pick towards the middle. So my stitching lies perfect in the corner. Unless I round my corners, then it doesn't much matter. For the turning, you simply clip the corner off. Then when you turn the edge they line up nicely . Hope my silly drawing makes sense. I meant the latter but now that I come to think of it, it's both. The problem with double turn edge is it takes some skills to match up the 2 piece neatly and so while the placement of stitching holes look nice on one side, it could be a little off on the other. Hopefully, it's something I can resolve through practice. The method you described works too, and with a double turn edge, it would cover up the corner's turn, but it would leave a visible line on the other. The way Philip Jury does it in his video is there would be small overlap of skin. The problem I have is I have yet to find the right angle to skive the corner to get just the right amount of overlapping. Right now, I either have too much bulk b/c of the excessive overlapping or a little cut that exposes an untreated edge (even if it's just less than 1 mm, it still bothers me). On 8/20/2020 at 3:58 PM, RockyAussie said: What @Stetson912 said is correct but I will add that you need to come out from the corner edge, the thickness of the product (normally between 1 or 2mm). I do this by resting a straight skiving knife against the corner holding it on a 45 degree angle or a little more. The thicker the piece then the distance out is wider and if thinner its less. I would get some cardboard squares and glue onto some leather bits and practice the technique until it works every time on a few thicknesses. With practice you can get a rounded corner using the same technique as shown in this pic below. Hey, thanks for the photo. I mainly wanted to avoid exposing any edges Quote
