Members SeyR Posted September 29, 2020 Members Report Posted September 29, 2020 I have some experience with veg tan but I’ve only ever connected pieces with rivets and buckles and so on. Very little stitching, no gluing. Now, I’m making a quiver. I’m buying new tools and doing a lot of research, as it’ll be my first times for carving, stitching, and gluing. I have some questions and concerns - I’m not working from an existing pattern. I’m thinking about closing the quiver’s long edge with a baseball stitch. The straps will be connected to that edge with overlays, and help reinforce the seam. Concerns: I’m designing the pattern with paper to start, and the construction paper warps into a teardrop shape without reinforcement at the seam. I worry I will have some weakness in the same area with 8 oz veg tan? Would it be more reasonable to use a butt stitch, even though I don’t prefer it aesthetically? Regardless of the stitch, should I, or would it be advisable to, contact cement (or otherwise glue) the butt edges of the leather together before stitching? Thanks for any tips, first time posting but I've been lurking for a long time. Quote
CFM tsunkasapa Posted September 30, 2020 CFM Report Posted September 30, 2020 I would do a lap seam with a double row of stitching. Or do a but seam with an overlay piece. But that is just my preference. Quote
garypl Posted September 30, 2020 Report Posted September 30, 2020 I make a butt joint on the beer growler case by running a stitch line down each side of the joint using @3 stitches per inch. Then hand stitch between the two rows pulling the edges up tight. Finish with a strip glued on the inside overlapping the joint. Makes a very strong joint. Quote
Members Dwight Posted September 30, 2020 Members Report Posted September 30, 2020 (edited) A. Make sure your two edges are exactly 90 degree cuts . . . and as near perfectly straight as you can make them. B. Contact cement the edges together C. I would (for a simple quiver) use a much simpler stitch pattern than Garypl used .. . . just a simple XXXXXXXXX stitch straight down the seam. D. To help insure it stays together . . . I'd put my shoulder strap attachments at the top and bottom of the seam . . . with a 3/4 inch or so wide strip running down the outside . . . with the ends of it becoming the anchor points for said shoulder strap. For garden variety pratice arrows . . . nothing needed . . . but for my broadhead arrows . . . each one goes into a separate plastic tube liner. May God bless, Dwight Edited September 30, 2020 by Dwight Quote
Members Handstitched Posted September 30, 2020 Members Report Posted September 30, 2020 I try to use adhesive wherever I can on joining , stitching etc. its like an extra pair of hands . Any chance of seeing the end product? HS Quote
Members Rahere Posted September 30, 2020 Members Report Posted September 30, 2020 @Dwight, the same for bodkins. For fun, have you seen Joerg Sprave's The Slingshot Channel on Youtube? He's trying to make quivers redundant. Quote
Members SeyR Posted September 30, 2020 Author Members Report Posted September 30, 2020 Thanks guys this is all very useful. @Dwight That's exactly what I intend to do with the straps, and I'll be sure to use contact cement too. I'm not an archer - the quiver is actually for my niece. I've been asking a lot of questions though. @Handstitched I'll make a point to post it! It'll be a few months, it's a christmas present, and with this much learning I'd rather take my time and get it right. @garypl That stitch is gorgeous. I think I might end up doing some tests - baseball or xxx or whatever, with or without a strip of leather behind. I do like the idea of a glued down strip under the stitch. I extra like the idea of not stitching that down too. Quote
Members SeyR Posted March 17, 2021 Author Members Report Posted March 17, 2021 @Handstitched the quiver is complete! I posted a new post in the Show Off forum but thought I'd mention it here too. Making of album: https://ibb.co/album/bbvb1X Quote
Members Retswerb Posted March 17, 2021 Members Report Posted March 17, 2021 You handled that stitch very nicely. Did you end up reinforcing it on the inside? Quote
Members SeyR Posted March 20, 2021 Author Members Report Posted March 20, 2021 @Retswerb Thanks! Yes I did, with a strip running the length of the inside of the quiver. I did a test run on a short piece and saw how easily the seam could buckle without reinforcement. Quote
Members Handstitched Posted March 22, 2021 Members Report Posted March 22, 2021 (edited) That looks absolutely great !! Well done You did a great job on the colours . A lot of medieval clubs would love that. HS Edited March 22, 2021 by Handstitched Quote
