Members chrisash Posted November 5, 2020 Members Report Posted November 5, 2020 Over the moon , just brought my first real machine a singer 111g155 at £90 and looks in good condition, maybe run on clutch for a time then fit a servo see https://www.ebay.co.uk/itm/193729354814?ul_noapp=true Can anyone supply a maintenance manual Hard to believe i got it at £90 Quote Mi omputer is ot ood at speeling , it's not me
Members Tejas Posted November 5, 2020 Members Report Posted November 5, 2020 (edited) Try the links in Tejas's post of 26 July 2018 in the thread below which are not for the G model which has reverse, but might be helpful. http://forum.sailrite.com/consew-255-clone-of_topic3607.html Edited November 5, 2020 by Tejas Quote
Members dikman Posted November 5, 2020 Members Report Posted November 5, 2020 Bargain!! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Constabulary Posted November 6, 2020 Members Report Posted November 6, 2020 (edited) 8 hours ago, dikman said: Bargain!! 2nd its a machine from the 1960s (and onward) - so a relatively new one. I have a good clear 111G156 (same machine but with reverse) manual if you want it send me your email address by PN Lots of timing values in it, basically all you need. Edited November 6, 2020 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members chrisash Posted November 6, 2020 Author Members Report Posted November 6, 2020 Anyone know the average sizes of industrial tables and will they fit into a estate car without the head Quote Quote Mi omputer is ot ood at speeling , it's not me
Members Matt S Posted November 6, 2020 Members Report Posted November 6, 2020 Excellent find Chris Average size is about 3-4ft by 2ft. If you take the legs off the table top you'll have no issue fitting it in an estate, I've done this plenty of times fitting them iny little hatchback. Quote
Members EMI Posted November 6, 2020 Members Report Posted November 6, 2020 Congrats, really nice find. For a sister Consew 225R machine I am currently overhauling I found the US Navy Course NAVEDRA 14217 manual very helpful (Link below) https://www.google.com/url?sa=t&source=web&rct=j&url=http://keysew.com/Webpages/DemoImages/USNavySinger111WConsew225REPAIR.pdf&ved=2ahUKEwjR0bGA0O3sAhXKyIUKHaxQBzMQFjAAegQIARAB&usg=AOvVaw2W219vX6s2_tJX2L_mg6u7 Consew 225, Juki LU562 and Seiko STW8B clones are very similar.The Juki and Seiko parts list manuals helped also alot (very clear illustrations) Quote
Members EMI Posted November 6, 2020 Members Report Posted November 6, 2020 2 hours ago, Constabulary said: I have a good clear 111G156 (same machine but with reverse) manual if you want it send me your email address by PN Lots of timing values in it, basically all you need. Is it a service or user manual ? I may need all the help I can get with the reassembly and final tuning of my Consew 225R and the US army/navy service manuals are a bit hard to follow. Quote
Members pcjc2 Posted November 6, 2020 Members Report Posted November 6, 2020 3 hours ago, chrisash said: Anyone know the average sizes of industrial tables and will they fit into a estate car without the head I got one in my old Toyota corolla once... I guess I must have dismantled it partially, but don't fully recall. Take some packaging with you to securely rest the machine on, and make sure it doesn't end up bumping / damaging any of the mechanism or thread guides. Last machine I moved, I cable-tied some wooden pieces (and some foam off-cuts) around the machine castings for it to sit on. (And still managed to slightly bend the presser lift pneumatic cylinder bracket whilst handling everything). Quote
Moderator Wizcrafts Posted November 6, 2020 Moderator Report Posted November 6, 2020 8 hours ago, chrisash said: Anyone know the average sizes of industrial tables and will they fit into a estate car without the head? I don't know the metric size, but in the USA the standard walking foot and straight stitch table is 20" x 48" x whatever height is set on the legs. The average height is between 28 and 29 inches. Top mounted thread stands, bobbin winders and flex lamps may interfere with sliding it into a car. Be prepared to unscrew these things and box them. Also, there will be a drawer for bobbins, needles and accessories that needs to be removed and boxed. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
