Members Campleathergoods Posted February 25, 2021 Members Report Posted February 25, 2021 (edited) Just got a hold of a Singer 29-4 (serial # L771630) and the balance wheel is busted (pictured) anyone know where I can find a replacement wheel for a good price? all I have seen is around $70-80 with shipping, wondering if other models will work for this machine hole diameter is 13mm approximately 1/2". Overall wheel diameter is 9 1/4" also wanted to hook it up to a small motor and foot pedal, anyone have any cheaper recomendations? Edited February 25, 2021 by Campleathergoods Quote
Members chrisash Posted February 25, 2021 Members Report Posted February 25, 2021 JB Weld may be your friend if you have the other half, defiantly worth a try Quote Mi omputer is ot ood at speeling , it's not me
Members Campleathergoods Posted February 25, 2021 Author Members Report Posted February 25, 2021 Thanks for the reply chrisash, unfortunately I don't have the other piece. Quote
CFM Frodo Posted February 25, 2021 CFM Report Posted February 25, 2021 my advice, find a machine shop in your area, take it to them and tell them you want the hole welded filled in, then a new hole drilled they usually charge by the hour, i do not see more than a hors work, $45.00 is a fair price for what i see and, YES, cast iron can be welded if you have the right tools and a trained welder Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Members Campleathergoods Posted February 25, 2021 Author Members Report Posted February 25, 2021 Thanks Frodo! Quote
Northmount Posted February 26, 2021 Report Posted February 26, 2021 Moved to leather sewing machines. Quote
DonInReno Posted February 26, 2021 Report Posted February 26, 2021 The supply and price of used 29-4 wheels on eBay varies - if you wait a bit one will come along for a better price. You can also have someone cut off the remainder of the broken area and braze or weld on a $2 collar. Sometimes welding schools do repairs like this for free - the hard part is getting someone that can do the repair straight enough it won’t wobble. Quote
Members chrisash Posted February 26, 2021 Members Report Posted February 26, 2021 In UK but here is one 82159 HANDWHEEL – Sew Europe (sew-europe.co.uk) dont know if its the same size you would need to check the parts list or 82159 HAND WHEEL SINGER 29K-71 | College Sewing Machine Parts Ltd (college-sewing.co.uk) Quote Mi omputer is ot ood at speeling , it's not me
Members Constabulary Posted February 26, 2021 Members Report Posted February 26, 2021 (edited) Be careful with 29K71 parts! The 29K71 fly wheel does not fit on early 29 / 29K models without installing additional parts - it´s a totally different system. You need a sleeve and the all clutch parts for engaging / disengaging the fly wheel clutch - it will not work without these parts. EDIT: You need all these parts if you want to install a 29K71 FW to a 29-4 - if it works at all If it was my machine and I want to restore it on a budget I would install an adjustment ring / sleeve as DONINRENO suggested. If you want to DIY the whole thing: Grind down re remaining bushing until its flat, look for a shaft collar that fits the shaft and is wide enough, drill 4 - 5 holes (approx 5mm diameter) into the shaft collar and around the bushing of the flywheel (holes have to line up), fill the holes with JB weld and hammer in some slightly oversized spring dowel pins. Let it dry, sand down the JB and finish it with black paint. Instead of dowel pins you can also tap some thread and bolt the shaft collar the fly wheel. As I said - a budget repair. Edited February 26, 2021 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
toxo Posted February 26, 2021 Report Posted February 26, 2021 Try looking for "Taperlock" bush and pulley. It's a very cheap way of replacing a handwheel and it will also slow down your machine and give it more torque. You order whatever size bush fits your shaft and whatever size pulley you want abd three set screws lock everything in place and it take less than an hour to fit. See mine here in a recent post with a 250mm pully.. Quote
