Members 29k15engine Posted November 19, 2021 Author Members Report Posted November 19, 2021 Just threaded up the machine and it stiches perfectly. Fine through 2 pieces of 1mm leather and 6 peices of 1mm leather ! Quote
Members 29k15engine Posted November 27, 2021 Author Members Report Posted November 27, 2021 (edited) After much work these are the DXF files required to cut correctly profiled shuttle gears for the 29k15 Singer Patcher, although I have extensively tested these on my machine I take no responsibility that these fir yours, they are however ovet 6 month work and are as accurate as i can make. These can be cut with an EDM wire erosion machine from a suitable steel (Hardened tool Steel) I will provide side profile drawings for the depth to cut the shuttle gear after the EDM has cut the gear profile. I have tweaked the shuttle so it does not need to be reamed out to correct pinion size. thickness for pieces before being cut on EDM, surface grind to these sizes, ideal shuttle5-25mmdia.DXF Description:- pinion gear 6.68mm ideal rack.DXF Description:- rack 3.8mm ideal plate.DXF Description:-Locating plate 2.73mm thick ideal shuttle5-25mmdia.DXF ideal rack.DXF ideal plate.DXF Edited November 27, 2021 by 29k15engine Quote
Members DrmCa Posted November 27, 2021 Members Report Posted November 27, 2021 Just one question: why did you not have them make the whole length of the rack? Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Members 29k15engine Posted November 27, 2021 Author Members Report Posted November 27, 2021 (edited) Hi thanks for the reply, Due to these machines not having an adjustment for shuttle timing the length of the full rack would be subtly different from machine to machine after 100 so years. due to this I have worked on an adjustable rack (see earlier posts) which would allow timing adjustment equivalent to the later machines with a eccentric bush. If you look at earlier posts you will find an old 60s catalogue picture from italy which shows the replacement rack end as a weld on item, so without the adjustable rack the end can be replaced on an existing machine rack (with care) Edited November 27, 2021 by 29k15engine Quote
Members chrisash Posted November 27, 2021 Members Report Posted November 27, 2021 First class work, I am sure many will appreciate your hard work Quote Mi omputer is ot ood at speeling , it's not me
MikeRock Posted November 28, 2021 Report Posted November 28, 2021 Solid Concepts, in Michigan, could print these. Quote
Members 29k15engine Posted November 28, 2021 Author Members Report Posted November 28, 2021 (edited) Here are the files in their stl format for 3d printing, the rack extended for welding is a bit longer to ease welding onto the original or new rack rod.(also in dwx) ideal plate.STL ideal rack extended for welding.STL ideal rack.STL ideal shuttle5-25mmdia.STL ideal rack extended for welding.DXF Edited November 28, 2021 by 29k15engine Quote
Moderator Wizcrafts Posted November 28, 2021 Moderator Report Posted November 28, 2021 4 hours ago, 29k15engine said: Here are the files in their stl format for 3d printing, the rack extended for welding is a bit longer to ease welding onto the original or new rack rod.(also in dwx) ideal plate.STL 33.87 kB · 0 downloads ideal rack extended for welding.STL 63.95 kB · 0 downloads ideal rack.STL 63.95 kB · 0 downloads ideal shuttle5-25mmdia.STL 65.51 kB · 0 downloads ideal rack extended for welding.DXF 41.76 kB · 0 downloads Could you please also post these files in the 3D and Laser Printers section of the LWN? Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Melville Posted October 31, 2022 Members Report Posted October 31, 2022 On 6/30/2021 at 1:14 AM, 29k15engine said: Just found from a supplier I can get parts 8608 Following Pinion for both 29k1 but also following pinions for 29k15 and the like. 8599 Small rack plus 8600 long rack!! which I may be able to be modified to fit a 29k15 with an adjustable rack rod. These are all new parts. Will keep you informed on these as it is another direction to get these parts working the older machines. Here is a picture from the supplier of part 8600 in stock. Hi who and where is the Supplier please rdonald8@tpg.com.au Quote
Members john franklin Posted April 24, 2023 Members Report Posted April 24, 2023 Hi could I ask the name of the company in Italy where you got the parts please Kind regards John johnagfranklin@hotmail.co.uk Quote
