Members rivercityleather Posted July 14, 2021 Members Report Posted July 14, 2021 Hi! I’m a newbie and need help threading this machine I just bought. Will certainly pay u for your time! I think it might be missing pieces but I’d like another set of more experienced eyes to take a look before I go make a case about it with the guy in Austin that I bought it from. Looking for someone who’s willing to FaceTime or zoom. I am an experienced seamstress with Bernina and Singer machines. This one has me stumped tho! Also new to working with leather. Thanks! Quote
kgg Posted July 14, 2021 Report Posted July 14, 2021 (edited) 1 hour ago, rivercityleather said: I think it might be missing pieces What I see from your photo: Threading: i) The first double hole top thread guide pin which probably sits in the hole in the top of the machine located just behind and above the letter "t" in brother. ii) Don't see a thread thread take-up arm, maybe just the angle with the sewing light hiding it. iii) Top Thread Take-up arm is missing the protective arm that prevents things like you light from striking the take-up arm as it cycles through it's sewing cycle iv) Top Thread Guide just before the needle is missing v) The Front Bobbin Cover (nose) is missing. Structural: i) The machine appears to have received a serve knock that removed the front left corner of the base. ii) The machines appears to have had a very heavy coat of paint applied. This maybe covering structural cracks. iii) Top Belt Pulley maybe not original? Identification: i) Your machine looks very similar to a Taking TK-335 so the following video ( www.youtube.com/watch?v=t52VC4KCZpM )should help you with threading and missing pieces. If it is a 335 class machine you will probably be limited to V92 thread. ii) The model nameplate is missing. Do you know what model it is??? hope this helps kgg Edited July 14, 2021 by kgg added missing added link Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Moderator Wizcrafts Posted July 15, 2021 Moderator Report Posted July 15, 2021 I hope you didn't pay very much for this fixer upper! It needs a lot of parts and work. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Constabulary Posted July 15, 2021 Members Report Posted July 15, 2021 looks like a Pfaff 335 clone - manuals can be found online. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members jimi Posted July 15, 2021 Members Report Posted July 15, 2021 (edited) Hi Rivercity and welcome to the forum. Here is the path for the thread, usually i have the thread from a large cop just behind the machine and coming through the wire at the back in the picture or directly from the bobbins on the wall. Hope this helps. Edited July 15, 2021 by jimi Quote
RockyAussie Posted July 15, 2021 Report Posted July 15, 2021 I think the previous owner has angle grind cut away that front section and if I am not wrong they have cut away the back section as well probably in order to get a deep bag to fit further in or something like that. Long and short that machine is not likely to hold up to much downward pressure without bending or breaking the hole cylinder arm apart. Spare parts is all I think it could be good for. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
kgg Posted July 15, 2021 Report Posted July 15, 2021 3 hours ago, RockyAussie said: I think the previous owner has angle grind cut away that front section and if I am not wrong they have cut away the back section Looking at the photo again I agree the back very well may have be hacked off as well. I hope they didn't spend much for the machine. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members chrisash Posted July 15, 2021 Members Report Posted July 15, 2021 How long before any vibrations make the arm fail its been weakened so much, send it back and claim a full refund it trouble either today or next week Quote Mi omputer is ot ood at speeling , it's not me
Members trash treasure Posted July 20, 2021 Members Report Posted July 20, 2021 Wow ! Best to bite the bullet on this one, and start over. Quote The model number giveth, and the subclass taketh away ......... Sometimes
Members bj139 Posted July 22, 2021 Members Report Posted July 22, 2021 Maybe a brazing project? Quote
