kgg Posted November 29, 2021 Report Posted November 29, 2021 (edited) I am planning on turning a 3" diameter burnisher and am wondering what material would be best suited and why for burnishing using a motorized burnisher? metal: steel / brass / aluminum wood: soft woods / hardwoods Any thoughts kgg Edited November 29, 2021 by kgg wording Quote
Members McCarthy Posted November 29, 2021 Members Report Posted November 29, 2021 Cocobolo is pretty much universally respected for burnishing. The grooves darken but don't transfer dye after you wipe it. I have tried oak and didn't like it. Also tried brass and it didn't do much. I have seen someone on youtube using aluminum but I forget who. Sam Andrews maybe. Quote
CFM Hardrada Posted November 29, 2021 CFM Report Posted November 29, 2021 Yeah, cocobolo. I tried using brass with a burnishing attachment for my creasing machine, but it didn't really work that well with Edge Kote. Quote
Members dikman Posted November 29, 2021 Members Report Posted November 29, 2021 Yep, Sam Andrews uses aluminium so it can't be too bad. I made a couple out of wood, one using a hardish wood the other a slightly softer wood and both work fine, but I think hardwood would be better than softwood. Quote
Members DrmCa Posted November 29, 2021 Members Report Posted November 29, 2021 Cocobolo is pricey. Any hard wood would work. I'd be weary of soft wood as it breaks and wears easily. Quote
kgg Posted November 29, 2021 Author Report Posted November 29, 2021 Thank you all for the info. If I go with wood I would like to us a North American species. I can see the softwoods like spruce cracking / breaking / wearing or even your softer hardwood species where as your tougher hardwoods like your eastern iron woods, white oaks and hard maples being stronger. This info has sent me down the wood rabbit hole and so far have found the following info: A lot burnishers use the non native to North America rosewood Cocobolo which has Janka rating of 2,960 Ibf Native to North America: i) Southern Live Oak (Quercus virginiana) has Janka rating of 2680 Ibf ii) Eastern Ironwood (Ostrya virginiana) has Janka rating of 1,860 Ibf iii) Hard maple has Janka rating of 1,500 Ibf iv) White Oak has Janka rating of 1,360 Ibf As a reference your typical White Spruce has Janka rating of 460 Ibf. This raises the question if a good burnisher is based on hardness why not just go with metal or are there other factors? 9 hours ago, dikman said: Yep, Sam Andrews uses aluminium so it can't be too bad. I couldn't find him so if you have a link I would appreciate it. 11 hours ago, Hardrada said: Yeah, cocobolo. kgg Quote
Members DrmCa Posted November 29, 2021 Members Report Posted November 29, 2021 Do not overthink it. Beech, birch, oak, all of the hardwoods will do just fine. Quote
Members Cumberland Highpower Posted November 29, 2021 Members Report Posted November 29, 2021 (edited) i found long ago elm made a good hard burnishing head. oak seemed the least stable. maybe the grain structure? Edited November 29, 2021 by Cumberland Highpower Quote
Contributing Member JLSleather Posted November 29, 2021 Contributing Member Report Posted November 29, 2021 oak is very good - and in N. America it's everywhere Quote
CFM Hardrada Posted November 29, 2021 CFM Report Posted November 29, 2021 This is mine: http://www.proedgeburnishers.com/hand-burnishers.html Posting as reference, since the OP mentioned he wants to turn his own. They make burnishers for machines too: http://www.proedgeburnishers.com/motor-burnishers.html Quote
kgg Posted November 30, 2021 Author Report Posted November 30, 2021 4 hours ago, Hardrada said: Posting as reference, since the OP mentioned he wants to turn his own. There is no question the Proedge are nice looking burnishers. They are on the pricey side for someone who can turn their own with either a wood lathe or metal lathe. I am planning on turning one using a metal lathe that is also another reason for the question about using metal as a burnisher. kgg Quote
Members dikman Posted November 30, 2021 Members Report Posted November 30, 2021 This is the guy, you can see his burnisher at 13m 29secs. He has other videos too. Quote
kgg Posted November 30, 2021 Author Report Posted November 30, 2021 7 hours ago, dikman said: This is the guy, you can see his burnisher at 13m 29secs. He has other videos too. Thank you. That is a nice burnisher as it stays close to the body of the machine so you can apply a lot of pressure. kgg Quote
Contributing Member JLSleather Posted November 30, 2021 Contributing Member Report Posted November 30, 2021 7 hours ago, dikman said: This is the guy, you can see his burnisher at 13m 29secs. He has other videos too. Sam is pretty good most of the time. Hank appears to REALLY be packin' on the pounds 12 hours ago, kgg said: e Proedge are nice looking burnishers. They are on the pricey side for someone who can turn their own with either a wood lathe or metal lathe. Yup. Never did understand why somebody would pay 50, 60, 80 $ for something you could do yourself - with whatever size grooves you want - with a piece of oak dowel stuck in a drill press and a file applied Quote
kgg Posted November 30, 2021 Author Report Posted November 30, 2021 3 minutes ago, JLSleather said: Never did understand why somebody would pay 50, 60, 80 $ for something you could do yourself Maybe I'm just cheap but I love to tinker and for the most part I have the time. I approach things where if I need / want something simple I'll usually give it a go first. Sort of jack of all trades, master of none approach. If I fail well then I'll buy a tailor made. kgg Quote
Contributing Member JLSleather Posted November 30, 2021 Contributing Member Report Posted November 30, 2021 4 hours ago, kgg said: need / want something simple exactly. and since buying theirs means you STILL need a drill press, might as well buy the drill press and spend 20 minutes making YOUR OWN burnisher. I dont think that's "cheap", I think that's SMART Quote
kgg Posted November 30, 2021 Author Report Posted November 30, 2021 1 hour ago, JLSleather said: I dont think that's "cheap", I think that's SMART Thank you, I haven't been accused of that before. HaHa kgg Quote
kgg Posted November 30, 2021 Author Report Posted November 30, 2021 14 hours ago, dikman said: This is the guy, you can see his burnisher at 13m 29secs. He has other videos too. I couldn't find a email address or whether the burnisher was aluminum or steel. So me being me I called him, a really nice guy. He confirmed he made it out of aluminum as steel will turn the leather blue. kgg Quote
CFM chuck123wapati Posted November 30, 2021 CFM Report Posted November 30, 2021 2 hours ago, JLSleather said: I dont think that's "cheap", I think that's SMART That's why you buy tools so you can make your stuff. IT is smart! Here in Wyo. its also a necessity sometimes. I built one on my wood lathe and as i was testing it realized i could also use the lathe to power it. Used local scrub oak. Quote
Members PastorBob Posted November 30, 2021 Members Report Posted November 30, 2021 I bought one of those cheap cocobolo tips for my dremel. I still prefer the hand slicker from Tandy and a bit of canvas. Seems to go just as fast, except for on belts. Quote
Members Spyros Posted November 30, 2021 Members Report Posted November 30, 2021 Canvas always gives me the best results, and now I'm wondering how come no one has made a rotating wheel out of canvas for burnishing... maybe because it will probably wear too quickly. Maybe I should make one and try Quote
Members dikman Posted November 30, 2021 Members Report Posted November 30, 2021 Spyros, the same thought occurred to me once, but as you say I don't think it would stand up to the pressure and speed. kgg, I thought about making one out of aluminium as it would be pretty easy to do on the lathe but the biggest problem was how to cut the thread for the shaft in the ally. The advantage of wood is that I could drill the centre hole slightly undersize and then force it onto the shaft, using the shaft thread to cut a matching thread in the wood. Quote
kgg Posted December 1, 2021 Author Report Posted December 1, 2021 2 hours ago, dikman said: I thought about making one out of aluminium as it would be pretty easy to do on the lathe but the biggest problem was how to cut the thread for the shaft in the ally. My plan of attack is to use a metal lathe that way I can use either wood or metal for the burnisher. My main shaft on my burnisher / polisher is 3/4" that tappers down to a 5/8"-11 threaded section. So far me thoughts are: For a aluminum: Drilling a 17/32" hole almost to the end then drilling a 13/16 " hole so far down and then tapping the 17/32" section for a 5/8" - 11 bolt thread. Once that is done cut the grooves in the surface, drill and tap a grub screw in the 13/16" end. For wood: Round and mill the grooves into the wood to the correct diameters, drill a 11/16" hole completely from end to the other then drill a 1 5/8" hole so far down to accommodate a 5/8"nut and on the other end drill a 1 3/8" flat washer to butt up against the 3/4" shaft. Quote
Members Cumberland Highpower Posted December 1, 2021 Members Report Posted December 1, 2021 (edited) 4 hours ago, Spyros said: Canvas always gives me the best results, and now I'm wondering how come no one has made a rotating wheel out of canvas for burnishing... maybe because it will probably wear too quickly. Maybe I should make one and try Well it sort of has been done. I have a shoe finisher/lineshaft type deal and it has a cast iron 'lobed" wheel of some kind that has a canvas jacket over it. That qualifies as a burnisher of sorts. (I think?) I also have both a bench Randall Burnisher and a Galli FCE that has wheels that are made from alternating layers of canvas and leather. 4 hours ago, dikman said: Spyros, the same thought occurred to me once, but as you say I don't think it would stand up to the pressure and speed. kgg, I thought about making one out of aluminium as it would be pretty easy to do on the lathe but the biggest problem was how to cut the thread for the shaft in the ally. The advantage of wood is that I could drill the centre hole slightly undersize and then force it onto the shaft, using the shaft thread to cut a matching thread in the wood. Dikman I don't know if aluminum is a good idea. Aluminum is soft and can rub off onto the leather. Damp leather might be ok, but if it were somewhat less than soft it would make black on your leather from the aluminum rubbing off... Edited December 1, 2021 by Cumberland Highpower Quote
Members dikman Posted December 1, 2021 Members Report Posted December 1, 2021 When I first thought about it I wasn't sure it would work either, but the fact Sam Andrews uses one proves that it does, in fact, work. The only proviso could be in the grade of aluminium used, some are harder/denser than others. kgg, I needed mine to fit on the left side of the grinder, which is a left-hand thread, plus the shaft is too short to extend past the burnisher. Finding such taps here isn't easy and the lathe I had back then couldn't cut threads. Your ideas should work. Quote
