I'm just getting started with leather craft - I wanted to make a bag out of a single A4 piece of leather, and this is the result
Also had a go at making the pattern into a printable pdf
Nice. What's A4?
  On 1/14/2022 at 1:04 PM, DrmCa said:
Nice. What's A4?
Expand
The paper size! (210 x 297mm) - the place I ordered my leather from had A4-size pieces that were very affordable, so it seemed like a good place to start before buying a larger amount of leather
A4 is a European measure of area, usually used for paper, = 8.25 inches by 11.5 inches, approx
  On 1/14/2022 at 7:37 PM, tsunkasapa said:
One of 2 formulas that didn't work before we came up with C4? ;)
Expand
No. the measures are ;  size A, B, C, D, E.     Envelopes are often in C sizes. My printer used to use a B size for printing my magazines. D sizes are often used for cash payment envelopes and E size is a speciality size
  • CFM
Expand
:rofl:
Expand
c4 is an explosive!
  On 1/14/2022 at 7:50 PM, chuck123wapati said:
c4 is an explosive!
Expand
oh, I didn't know that, not needing to use it. I prefer Semtex any way
Expand
OMG he's Joking
I like det cord OL
  • CFM
Expand
C4 was my go-to when I was blowing things up for the Army, 45+ years ago. I like it, easy to use, you can cook your rations on it, even fish with it.
Expand
That's really nice! Could you show us a picture from the side, please? I'm interested in the gusset and the bottom corners...
Expand
Are you sure its A4? It looks more like A3 to me
Expand
I thought the same thing, but then I held an A4 notebook against me and it's actually pretty big. I suspect the side seam is in the middle so that both front and back contribute to the gusset. Or???
I believe A3 printers are pretty rare...
For our US friends this is the European standard paper sizes, Each size double the side of the next i.e A5 doubles to A4 and so on
Edited by chrisash
O'h for goodness sake !!!!!!!!
Is this about a nice bag that the maker  has made or  the size of a bit of bloody paper ????
@imocow Its a lovely bag, I quite like it . I too have experimented with .. 'cough ahem'...... " bags with a similar dimension to paper", going by customer demand. Not too big or bulky .
Looks like  a one piece creation  ?? . I have done two piece creations using kangaroo hide. Mostly 'one offs ' . Keep up the good work  :)
HS
Expand
Here's the side! It's stitched right side to wrong side because I wanted a smooth rounded sort of shape
Expand
Definitely A4 (but that doesn't include the leather for the straps). It does happen to be pictured on a particularly small person here which makes it look  bigger! The final bag is approx 14 x 9 x 3cm (5.6 x 3.6 x 1.2")
HS
Expand
Thanks :) Yep, a single piece (except the small strips enclosing the D-loops)
Expand
Wow! You must have small hands, to accomplish that! How did you get needles/awls in there?
HS
Expand
There did seem to be confusion so I clarified, did you have a few to many tinnies
Expand
Thanks, gotchya. Its a fine bit of using what you have to the mostest degree
Expand
Haha, I actually have pretty large hands (for a woman), but yes, getting the needles in there was quite tricky - I did both short sides first so I was sort of working my way up and out of the bag as it came together
Thanks for the pictures! It's not how I imagined, but most probably looks better. The bottom corners sure look tricky... and the rest not too easy either. I think that's a case where I wouls punch the holes all the way through so I could work without awl - did you?
Expand
Yes, I punched it all first and didn't use an awl
With those D rings you could easily add an accessorry of a shorter strap to make it a clutch or handle thingy.  Excellent work!
