Everything posted by friquant
It was very handy to be able to adjust it in increments. I had been breaking needles attempting to stitch through a 1/2" (12mm) stack of vinyl and foam (auto upholstery project). So I disconnected the belt and ran a few stitches by hand on a thick test piece and it wasn't very many stitches by hand before the hook point tried to bisect the needle. Ah-ha! After that discovered the needle guard adjustment screw, put some medium strength thread-locker on it, and backed the set screw out until the needle guard mostly prevented contrived collisions of the same sort. Then put it back together and stitched that troublesome seam in one pass (relief!). Not seeing any skipped stitches or unraveled thread yet (If I did I would think I had gone too far with the adjustment.)
I hadn't noticed this before, but I think it's an adjustment screw for the needle guard. (Jianglong 341) Looking closely, I could see a hexagonal shape behind the round hole. 1/16" (1.7mm) hex wrench seems to fit. Or from a different angle: Here I removed the needle guard and you can see the set screw that sits behind it: I've been wanting the needle guard to be stiffer anyway. (What good is a needle guard that just gets out of the way when the needle comes by?) Using this adjustment screw will mean there is a support closer to the bulge in the needle guard, so I expect it to flex less when the needle presses against it.
How to ease when sewing leather on a 1341?
friquant replied to joetroba's topic in Leather Sewing Machines
Oh that jogs a memory. I've got a deal in the works to buy this machine that has two foot pedals. It might be for raising the presser foot though 🤷♀️ -
A bag maker in the making...with a zypper, no less 🌟 That seam next to the zypper would look cleaner if you pull the old thread off. (Looks like you made a seam, ripped that seam out, but left the old thread)
Sounds like a video in the making 😉 -
I'd like to see that. She appears to be using a clutch motor, based on the rapid start / rapid stop and the old style ON/OFF power selector. -
You'll have better luck if you start a new topic 😉
How does she make the machine feed in reverse? She's got a knee lift for the presser foot, but both hands in the shot when she reverses. -
Did you account for seam allowance? For a non-eased seam, the the pieces will have the same length along the stitch line. (Not necessarily the same length along the outside edge of the leather) -
It would be handy if there were a cross reference for beehive tension springs. You know, free length, diameter at base, diameter at top, and force when fully compressed. You can of course bend your own from music wire.
Interesting...Can you send photos of the pieces of leather that comprise a single finger stall? -
I'm assuming you only need one. And as others have said, VFD is a convenient electronic solution to get 3-phase.
Looks like a table-mounted bobbin winder could be a 3:1 speed reducer if you added a tiny pulley to the spot where you normally mount the bobbin.
No video But stills are present. Looks like you could make the pulley part of the handwheel three times its current diameter before it runs into the motor pulley. That would be a good start. And then check the foot pedal out like al was sayin.
Can you post some photos/videos of your Pfaff 130? Foot Pedal Does your foot pedal give linear response? That is, proportionally more torque based on how far your press the pedal? If not, buy a new pedal. Here's one I bought recently which gives good response: https://www.amazon.com/dp/B08D8WPWTY Slow Downers As for slowing it down (and increasing available torque) there are many ways to slow down a machine. Adding an oversize handwheel is just one: https://leatherworker.net/forum/topic/132445-domestic-motor-with-plywood-pulley/ Other ways include going to a smaller motor pulley, or adding a speed reducer between the motor and the machine. Or finding a motor that is slower in the first place. Here is a link to the Used Sewing Machines: https://leatherworker.net/forum/forum/84-used/
FEIT DCL-8500N : Stump for Tilting Machine Head
friquant replied to friquant's topic in Leather Sewing Machines
No lock screws on this one. I've got the head unit on my workbench, and I've been experimenting with different support points using a test support. Some positions are quite stable, other cause it to lift at the hinge line. I think I'll 3D print a new support (shorter than the original so the head unit pivots exactly 90 degrees) and use either a screw or double-sided sticky tape to hold it down in one of the stabler locations. The other idea that popped in would be to screw the support to the back of the machine head. But then I'd have to source screws that match the threads that the rear cover plate is already using. -
You can disconnect the belt while you diagnose.
Anybody care to measure the distance from the hinge line to the tilt stump on their machine? My working hypothesis is that a tilt stump too close the the hinge axis will lift the machine off its hinges. For reference, this is the hinge type on the table. I have not personally owned this style of hinge. It appears that even with the machine head tilted back, the hinge can still be pulled straight out of the table. But I suspect that is true of this other style as well: -
How does this "tilt stump" attach to the table? Is there a nut under the table? Or do I pry the plastic cap off to reveal a bolt head and it screws out the top? This is a customer's machine, a FEIT DCL-8500N. The closest manual I have found so far is this one for the Artisan 8500N. I brought the head unit home with me for repair. But I'm convinced that the tilt stump is in the wrong place. It prevented the head unit from tilting all the way back. But after a couple minutes, the handwheel end of the head unit slithered off the table hinge and into the drip pan. Nobody was hurt in the process, but seems liable to happen again. My intention is to move the stump further away from the operator, and a maybe a couple inches left (from the operator's perspective) so that it loses its tendency to lift the machine off of the table hinge closest to the hand wheel. But I'll need to pack the appropriate tools to do so, and while I was there I did not manage to figure out how it attaches. artisan-8500n__similar-to-feit-dcl-8500n__manual.pdf
I would recommend a bottom feed machine. I've been using this bottom-feed Singer 31-15 on a tabletop skirt for my thinner goods. We have a domestic sewing machine that would work as well, but I like bigger toys I guess. If the machine you're looking at is in sewing condition, you could take some of your canvas and thread (TEX 70 I'm guessing) and make sure it will sew through as many layers as you are likely to need, and make sure it has even stitch length when going over minor humps.
This box looks complex. It has the following ports which are common to a lot of digital servo motors: X1, X2: motor X3: gas pedal X7: needle positioner But then there's additionally X5 (head unit) and X4 (looks like a control panel) that most digital servo motor's don't have. In other words, I'll bet this is a proprietary system and that it will be difficult to buy the pieces individually.
Can we get a photo of the back of the box that says "pico drive"? Also can we get separate photos of each piece that plugs into the back of the motor? I'm not familiar with this model, but trying to see if all the parts are here.
Can you post a link to where you bought your pulley? I recently ordered this 25cm pulley from amazon, still waiting for it. Yours looks more comfortable and safer (harder to get fingers caught in it.)
