Many of our members are using the Family Sew FL-550, fitted with a 50mm pulley. I have this setup on a walking foot machine and I can easily sew 1 or 2 stitches per second, all day long. The final slow speed is determined by the diameter of the pulley on the machine. These motors have a rotary switch or potentiometer that limits the top speed. When set to the minimum, the motor turns over at about 350 rpm. When set to full speed they spin at about 3600 rpm. To really slooooow these motors down, add a 2:1 or 3:1 speed reducer wheel between the motor and machine. The reducer multiplies the torque by the same ratio as it reduces the speed.
- 4 replies
- servo motor
- 1811
(and 1 more)
Get a stronger top tension beehive spring.
Machine/foot for padded belts and other tricky edges
Wizcrafts replied to HVLW's topic in Leather Sewing Machines
I just answered your question in another topic. You will probably do better with a straight stitch machine and a custom curved foot. It might resemble a very broad piping foot, which has an arch ground along the left side. The problem is you will require an arch that has a radius broad enough to conform to a 16mm to 20mm (or more) watch strap. It may be possible, but I doubt it. The largest piping foot I have is 5/8" US measurement. That's probably close to 15 or 16mm. A lathe might be able to broaden out the radius for your straps. There are piping foot sets for walking foot machines. Again, the widest I have found online is 3/4" radius.- 10 replies
- recommendation
- uneven leather
(and 2 more)
Beveled men's belts are factory sewn on straight stitch machines fitted with a curved presser foot and edge guide. The left portion is cut in a broad arc to ride on top of the raised portion, while a very short right portion presses down on the very outer edge. To sew beveled belts on a walking foot machine calls for some creativity. Your basic task will be to find or make a smooth left toe foot set, then adjust the alternating lift high enough so that the inside foot fully presses down the edge and the outside left toe lifts enough to let the belt move along with the needle feed.
Basically put, a zipper foot is a single sided presser foot, with either a left or a right toe only. In the case of a walking foot machine, you must have an inside foot to cause the outer foot to lift and lower. Thus, zipper foot sets are sold as matched pairs. 99% have teeth on the bottom. Some are very narrow, down to 1/4 inch (~6.4mm) total width. Right toe zipper sets usually have the hole offset to the left edge on the inner foot. If you want a poor man's zipper foot, buy a regular smooth foot set, with a narrow profile, and grind off the right toe from stem to stern. Polish and slightly round the sharp bottom edges of the outer presser foot. This will serve as a left toe set when you need to sew close to the edges. You may have to buy this foot in person to get one that has the left toe close to the inside foot's left edge. Otherwise, you may end up with a big gap between the inside and outside feet.
I neglected to use the term parallel when describing the lines of stitching I sew into tow straps.
Sewing Machine For Beginner
Wizcrafts replied to firstcapitalfirearms's topic in Leather Sewing Machines
I have seen a picture of a CB3200 with a hand crank. Not ideal, but an option for unpowered sewing. I will conjecture that one could be adapted to a patcher base and be treadle operated. Slippage of the leather would be a recurring problem though. -
I Need To Tell You How Much I Hate The Consew Servo Motor...
Wizcrafts replied to JimC's topic in Leather Sewing Machines
This reminds me of the 125 pound Adler 204-374 flat bed walking foot machine that I bought privately in 2010. It had a 1/2 HP clutch motor with a 2" pulley feeding a 3:1 speed reducer. I could easily feather it down to 1 stitch every few seconds. The top speed was all of 2.5 stitches per second. The beast could sew a solid 1/2 inch of leather with #346 thread. I traded it off for a Union Lockstitch Machine. -
I searched our own forum and found the video in question embedded into a reply concerning using a Sailrite to sew leather Renaissance gear. It shows a person using one to sew a knife sheath. Read the entire topic to gain some background. -
I sew webbing tow straps on occasion. I sew a series of vertical lines about 1/4 to 1/3 inch apart, at 4 to the inch. I back tack at both ends, into the same holes for at least 1 inch, covering about 5 inches of folded length. In the past I would sew a rectangle with a X pattern inside it. But, I found that the row going across the front end was the weakest point because it went across from side to side. I looked a heavy tow strap that was used on bigger trucks and it was sewn with multiple rows inline. This is similar to the technique used in heavy horse tack, where the buckle and squares ends are never sewn across the strap, but inline along the sides. Bob Kovar sells round point system 7x3 needles in most sizes up to #27. I have some packs I bought from him in #25, 26 and 27.
Since you asked, I can already feather a clutch motor down to 1 stitch per second, using the standard control arm and proper adjustment of the slack bolt and return spring. However, a long extension arm would make it easier on the ankle to hold it at slow speed. -
He is. Darren is in Australia.
Our member, Darren Brosowski is the official dealer for the "Able" brand of Chinese patchers in the Northern and Southern Hemispheres on this side of the Atlantic Ocean. When he sees this topic he may reply about the ability of his machines to sew 20 or 21 ounces ounces of veg tan leather at 5 stitches per inch or better. He may be "able" - pardon the pun - to set one up specifically to do this for you.
I have 2 Singer patchers (long arm big bobbin and short arm small bobbin), a long arm version of the Singer 111 walking foot (a 139w109) and a Cowboy 4500. Here is how I divide up work among them. For sewing patches over pockets or sleeves, or for sewing on new strap tabs on the sides of purses, or for sewing zippers onto purses, bags and boots, or for top stitching shoe or boot uppers or cylindrical items, or sewing a patch onto a wallet back, I use a 29k series patcher. I keep the small bobbin model fitted with #69 thread and the large bobbin model with #92 thread. A Singer 29 series "patcher" is only good for repairs. For sewing wallets, phone cases, denim goods, chaps, jacket front zippers, and most anything that is between 3 ounces and 15 ounces, I use my long body Singer compound feed walking foot machine. I normally keep #92 thread in it with a #19 or #20 needle. I'll occasionally use #69 and a #18 needle for pigskin wallet interiors. Once in a great while I'll thread it with #138 thread and a #23 needle. You can use the Singer 111w155 for the same kinds of jobs. In your case you will probably use it more often than I do with #138 thread, which can sew pancake holsters together. Just sew double rows, 1/8" to 3/16" apart, for added strength. It maxes out with #138 thread. It maxes under with #69. Any jobs that are 1/4 inch or thicker, or that require #207 or larger thread are done on the big Cowboy CB4500. This includes holsters, gun belts, knife sheathes, thick cases, tow straps, animal collars and harnesses, headstalls and bridles. I typically keep it threaded with #277 thread and a #25 needle. These are not all of the machines I have in my leather shop. I also have a straight stitch drop feed Singer 31-15 tailors' machine for sewing cloth and linings and a very old Singer 42-5 spring foot for heavy upholstery work. But, the two patchers, the Singer compound feed walking foot and Cowboy machines are the ones I use the most. A well equipped leather business can not only make new items, but can repair old ones. Repairs are often a good stream of cash flow. So, since you are just starting out, my advice is, if there is any way you can swing it, buy the patcher and the Singer 111 now and the Cowboy later, using money earned from repairs and new builds to help pay for the machines. I see that you mentioned a Cowboy CB2500. It will sew up to 7/16 of an inch with #277 (and probably #346) thread. But, it is a bottom feeder only and the large teeth will leave very noticeable marks on the bottom layer. Further, its lower thread capacity is #138 thread with a #23 needle. No smaller needles are commonly available for this machine. If tooth marks are unimportant, this may be a viable option for you. Plus, there is an optional wide roller foot for it.
If the motor is attached to a bracket on the back and connected by a belt, it is a 15-90. If the machine has a pod motor built into it, it is a 15-91
I started this topic to alert members of LWN that the email problems with the Toledo Industrial Sewing Machines website have been acknowledged and fixed. I then posted a little piece of potentially helpful advice to self-managed website owners using shared hosting accounts to log into their control panels and verify that the email server settings they are using are still valid. Then my friendly little post got hijacked into a rant against Microsoft and other matters. So, I am using the powers vested in me to close this topic, as it is only going to denigrate further if left open.
Some folks take the lowest level hosting accounts when they start out, many of which do impose file count and size limits. These accounts are much cheaper than unlimited/unmetered accounts. I know several people that chose this path at first, then had to upgrade to a more expensive plan as the website grew in content and popularity. I have seen changes in my mail server designations from three different web hosts. This often accompanies upgrades to the Apache or Nginx software. I've personally had mail servers with no prefix, "pop." and "smtp." and "mail." prefixes. Then there's more changes when you sign up for Cloudflare or another CDN.
If you've recently sent email inquiries to Bob Kovar, or used the contact form on his Toledo Industrial Sewing Machines website and got no replies, or, you called to follow up and they claim to have not received your email, it is because he probably didn't receive your email due to a website mail server problem. Bob Kovar asked me to look into an email reception problem he has been experiencing since September 23, 2016. Between that day and October 20, he was not receiving any new email sent to his domain's email account, including messages sent via the contact form. He would check for new messages but found nothing new listed after 9/23/16. I learned that the problem was caused by a misconfiguration of the website's email MX record, which was first setup in 2011 and worked fine. Sometime during the last year or so the email server prefix was changed by the hosting provider. The unchanged mail server record eventually stopped being recognized on Sept 23. It was corrected on October 20 (after over 30 minutes on the phone with tech support). Emails to tolindsewmach.com are now showing up in the inbox as expected. So, if you have sent emails, or submitted questions via the Toledo Industrial Sewing Machines contact form, and received no answer, please resubmit your inquiries. If you happen to be a website owner, or a webmaster, it may be worth your time to poke around your cpanel - or equivalent - in the email configuration section, to make sure that the mail server is set to the current values used by your web host. Prefixes and ports get changed with server upgrades, as I just found out. A wrong mail server entry may lead to missed or bounced messages if the mail server doesn't forward messages sent to the old server to the new one. Example: Old incoming mail server was: your-domain.com Server upgrade changes the MX Record to: mail.your-domain.com or pop.your-domain.com These are regarded as different mail servers. Mail will eventually bounce or go to the bitbucket until you correct the entry. Ports may have also been changed during an upgrade, so verify IMAP, POP3 and SMTP ports if you use your domain to send and receive email. Another thing I learned is that saved email messages are regarded as "Files" and count toward any max files limit imposed by the web host for your hosting account! Further, if there is such a numeric limit set on how many files can be stored and your domain's email Inbox (including junk and custom folders) reaches that number, the mail box will be listed as 100% full and will stop accepting any new messages until some old ones are deleted, or the limit is increased by the host's tech support. This is the same thing that happens to our voicemail boxes. Now you know what else I do when I'm not sewing things, or playing steel guitar in Country bands.
I want that overcast looper, please, for my Pfaff 4 spool, two needle serger.
Yes, as long as it is thin, soft temper leather, sewn with thin thread and no larger than a #18 leather point needle. If the top grain happens to have a grabby texture, you will need to change the presser foot to either a roller or Teflon foot.
I have a servo motor on my 31-15. It has a small 50mm pulley and a shorter than standard matching v-belt. If the clutch motor you now have has a pulley larger than 2 inches, you will definitely need a figure out the length of belt you will need if you swap it out for a servo motor with a 2" or smaller pulley. You should tell the dealer you are ordering the motor from the length of belt that is on the machine now, plus the diameter of the motor pulley. This will help him choose the most likely size for a new belt, which will likely be much shorter.
Yes, it is the same oil. I use his oil in all of my numerous sewing machines.
I use my 31-15 to sew wallet interiors and for all cloth projects (tailoring). I usually use a walking foot machine to sew the back to the interior. My machine can handle #69 bonded nylon, because I clearanced the shuttle driver and shuttle race to do so. Otherwise, it would not clear that size of thread without a slight but noticeable binding and click sound that messed with the stitch quality and dependability.
It is a standard domestic Class 15 machine. You will be limited to #69 bonded nylon thread, using a #18 leather point needle.
I once owned a Singer 111w155 and it was good up to 1/4" with #138 thread. I tried sewing thicker but the needle would get stuck in the leather. Now, it will sew bridle leather a little thicker, as it is less dense than plain carving leather. I do have a long arm Singer that is based on the 111 mechanism. It is capable of sewing 5/16" maximum. I keep it threaded with #92 thread and use it for lighter projects, like wallets, zippers, phone cases, hemming, etc.
