Yes and yes. They will sew thin material, and small diameter needles are available, but a smaller machine will do a better job with #69 thread, into a few ounces of wallet leather. I use a Singer 31-15 for wallet interiors and hemming clothes (#69 thread). I have a walking foot machine for medium duty work, up to 3/8 inch or so (#138 thread) (jeans, belts, seat covers), then the big Cowboy and a Union Lockstitch for the really thick work, with very heavy thread (#277 and up). I also have a long arm big bobbin Singer patcher, which is invaluable for sewing in any direction, for applying patches, repairing shoes and boots and odd jobs.
Look into a Cowboy, Cobra or Techsew 441 clone. They are capable of sewing over 3/4 inch, with very heavy thread and are fully supported by our dealers who set them up and sell them.
The 7 dimes, at about 1/16" each, show the actual maximum lift and sewing thickness you can expect in the real world. The type of material will have an impact on how much higher you can cheat and pre-raise the presser bar. If you have to sew 5/8 inch of nylon webbing, or buffing wheels, you can loosen a set screw on the foot bar clamp and raise the foot to clear that much material. In return, you will have about 1/8+" of free space under the raised foot. If you need to sew something thin, you'll need to reposition the foot. The spring used to hold down the foot is not heavy enough to keep 1/2 inch of veg-tan leather from lifting with the needle. When the needle gets stuck, you have skipped stitches. The feed is bottom only, via feed dogs with serious teeth. The more top pressure you apply, the deeper the tooth marks will be. The needle system used in these machines normally starts at #22, which is the right size for #138 thread. If you want to use thinner thread, into thin wallet parts, you must hunt down thinner needles, in size 18. You can learn more about these machines here Here is another GA5-1
Marco; I don't have a GA5-1, but I have spoken to dealers who sell that type of machine and all seem to agree that it is maxed out even sewing 7/16 inch. I have never seen a spec that shows the presser foot being able to lift over 1/2 inch. Would you mind providing a link to the machine you are considering?
I have owned two Singer 29-4 patchers and have tried using them for projects they cannot handle. Holsters is one of those things. First of all, the machine is not designed to sew above 1/4 inch of leather. The stitch length at 1/4 inch drops to about 7 or 8 to the inch. The bobbin is about the size of a thick dime and only holds a very small amount of #69 thread. It can probably sew two or three average belts. The drive is by means of teeth on the bottom of the presser foot. The 29-4 might be up to 100 years old. Unless it has rarely been used, and never abused, the foot driving mechanism my have so much slack that you won't even get 6 stitches per inch, into 8 ounces of leather. These machines are best reserved for sewing embroidered cloth patches onto jackets and vests.
Fabric Sewing Machines For Leather
Wizcrafts replied to OldManDan's topic in Leather Sewing Machines
I too have a Singer 15-91. I tried to use it to sew leather and Naugahyde, before I got a real walking foot machine. Yes, it can sew leather, even a dress belt. But, the feed system is a limiting factor as is the top needle and thread sizes. Adding a so-called walking foot attachment only accomplished a lessening of the separating of layers, but at the cost of almost half the previous clearance under the foot. That is why honest dealers sell them as "even-feed" attachments (for quilting). If somebody wants to sew leather vests using the piecing method, a 15-91 will do the job. It gets a bit strained sewing larger pieces together. If you only sew thin leather projects (under 3/16"), using #69 bonded nylon thread, or cotton or polycore home sewing thread, a Singer 15-91 is a viable alternative to an industrial sewing machine. I was able to find #20 needles for mine, allowing it to handle buttonhole thread, or even #92 bonded nylon. I no longer use my 15-91, and will gladly sell it to somebody who has a use for it. -
CarolB; The guys are trying to well you something important, when they mentioned that your machine has a safety clutch. This could be the crux of the problem. The clutch may have disengaged to protect the hook, after a thread jam. If so, you will need to hold down a button and rotate the handwheel to re-engage the drive to the hook.
If you continue using #277 thread in that machine you may wear it out in no time at all. You may wish to consider replacing critical bearings and moving parts in advance. See if there is a titanium coated hook available for it. Use the best needles money can buy; not Organ brand, with the longest amount of needle below the eye. The slower the taper of the needle, the less stress it places on the machine as it pounds through the dense leather, with a very large needle and thick thread, with which it was not designed to sew.
Yes, I use Tool Magic, which is sold at craft stores like Joann Fabrics. Methinks Harbor Freight Tools may also sell something like it, to coat the jaws and handles on pliers.
What type of machine are you referring to RedDevil? The stitch length variance you describe always occurs on top feed only patchers. Is the machine a Patcher? If so, your only recourse is to pull the material back as the foot feeds it, giving it a little assist. How much this helps depends on how worn out the feed mechanism is. A factory tight Singer Patcher cannot give better then 5 stitches per inch, and this would be into about 1/8 inch of leather. This drops as the thickness increases, unless the foot pressure is rather light. This behavior can also happen on a needle feed only machine, or a double feed machine without a feed dog, but under high top pressure.
Toledo Industrial Sewing Machines and Keystone Sewing both probably have the parts you need.
If the leather band is under 1/8 inch thick, I would use #69 bonded nylon thread, with a #16 needle @ 8 stitches per inch. If I used a #18 needle, I might stretch out the stitches to 7 per inch. A Singer 31-15 is a nice machine for sewing watchbands. Use a narrow Teflon zipper foot with a slot in the center and an edge guide to keep the needle about 1/16" to 3/32" from the edges.
Techsew, a.k.a: Raphael Sewing, in Montreal is a Juki dealer. Also, I used to work for Toronto Industrial Sewing Machines. I don't know if they are still in business, but they were a Juki dealer.
I am guessing that a small patcher bobbin, tightly wound with #69 thread, would sew about 3 or 4 medium length dress belts. It will certainly sew patches onto several vests.
You can do all the things you described in your list of projects, on a patcher. The small bobbin goes a lot farther when loaded with #69 thread. If you decide to use #92, keep a couple bobbins pre-loaded. Buy an extra bobbin case or two. The thickest you can sew on that machine is about 1/4 inch, or possibly up to 5/16 inch, depending on the toughness of the leather. The only real concern you'll have is the tooth tracks left by the presser foot. Also, as the thickness increases, the stitch length decreases. So, you might be getting 5 to the inch into 6 ounces of leather, but only 7 or 8 per inch in 1/4 inch of leather. It depends on how tight the feed mechanism really is and the lift setting for the foot (max).
9" 16" 25" Good N Bad,, Input Or Thoughts
Wizcrafts replied to Greystone's topic in Leather Sewing Machines
Okay. I love the stitches laid down by the Union Lockstitch machines. They can be made as loose or tight as one wishes. It can be adjusted for a very light pull, to avoid splitting the cords on linen thread, setting them nicely on the surface. Change the presser foot to the one that has a blade on the front and the stitches lay below the surface. Change the needle bar to the S model and insert the blade and you get a recessed thread channel cut into the bottom. Set to the other extreme, the Union Lockstitch can pull bonded nylon thread so tightly, that it gets recessed into the top grain of the leather, with using a channeling foot. This is a true harness and saddlery machine. Add the fact that you can feather the clutch for one stitch at a time, up to 15 per second, and you have the World's fastest needle and awl stitcher, capable of the tightest stitch in the industry. Oh yeah, the bobbins are 2 1/2" diameter by 3/4" thick inside, tapering to about 3/8" at the top opening. A full bobbin holds about a football field of #277 thread. Operating and re-adjusting a Union Lockstitch requires a learning curve. Ditto for backtacking with one. I do it all the time, but it takes experimentation and some operator trickiness. It's an acquired technique. Then, there is the trick for ending the last stitch with the top thread looped under the work, but not around the bobbin. Baby steps... A weird comparison would be the Union Lockstitch is kind-a like driving a stick and clutch car, where you really need to understand the machine to use it successfully. By contrast, operating a Cobra or Cowboy or Techsew 441 clone, or Adler 205 is like driving a car with an automatic transmission. Set the tensions, choose the correct needle for the thread, load the bobbins, raise the feet, insert the work and sew. Wanna change stitch length? Turn a round nut in or out and the stitch lever moves up (shorter) or down (longer), making shorter or longer stitches. Wanna back-tack? Raise the stitch lever all the way up and voila, you are now sewing backwards, into the same holes. I have sewn on a Randall Lockstitch machine. I would describe it as a quasi religious experience. There was no edge guide, yet I had to maintain a fixed distance from the edges. Then, I had to sew a second row 1/8" in from the outside stitches. The only way to do this is to perform a Vulcan Mind-Meld with the machine and merge into it. I know this sounds like bullshit, but it isn't. It laid down the most perfect stitches I have ever seen, with liquid-waxed, 4 cord, yellow, Barbour's Irish linen thread. The machine makes a sound when it sews, like "tapokita, tapokita ... all day long, machines going tapokita, tapokita. -
Until I got my 16.5" cylinder arm Cowboy CB4500, I used my Union Lockstitch for all heavy sewing. It has a 12" body depth, sews slow or fast and is modified to sew 7/8 inch. I use #277 most of the time, although it can sew with #554 with a #4 needle and #5 awl. It is needle feed, jumping foot. It's also for sale. The Cowboy is what is known as a 441 clone, a modified copy of a Juki TSC 441, with triple feed. Mine sews 7/8 inch, with up to #415 thread. I usually use #277, as that is what I stocked up on for the Union Lockstitch, but it handles #346 just as well. The 9" throat depth 441s are used by folks only sewing along edges, or rather narrow work, like small holsters and animal collars and harness. Most people buy the 16.5 " arm 441 machines. I sewed a saddle on one yesterday. They are great for wide patterns, like Western holsters, weight and gun belts with stitched designs, or other large items that have a lot of internal stitching. The 25" models would do just about anything you can imagine. You could sew buggy fenders and tops on them if you know Amish or Mennonites. Campbell Randall lockstitch machines are the Creme Dela Creme of harness stitchers; a step above my Union Lockstitch. They are awl feed, jump foot machines The Adler 205 can be modified to sew 3/4 inch and is a very smooth harness stitcher. It is available in 12" and 16" models and sews with #346 thread. The CB2500 and GA5-1 type machines, based on the Singer 45k25, are intermediate thickness stitchers, with bottom feed only. They handle #346 thread and sew to about 7/16 inch. The teeth leave marks on the bottom layer, but they are okay for flat straps and tack, where the bottom is not usually seen. -
If you intend to sew 7/16 (28 oz) to 1/2 inch (32 oz) of leather on a regular basis, a CB2500 or GA5-1 is not the right machine for you. You will be sewing at the maximum capacity, under tremendous foot pressure. A triple feed 441 clone or an Adler 205 or its clones are the better machines. These sew over 3/4 inch, so a half inch won't over stress the mechanism. They can handle up to #415 thread.
That is what I suspected. 28 ounces is 7/16 inch. You have crossed over into the realm of the heavy stitchers. Furthermore, when sewing this much thickness, one would want to use #277 thread. This is within the realm of the medium-heavy stitchers, like the CB2500 and very heavy duty 441 clones. We are supported by member dealers who have advertising banners that appear on top of every forum page. Reloading a page brings up a new group of banners. You can get an idea about the machinery being sold to leather workers by reading these banners and clicking through to the various websites. Once you take an interest in a particular (new) machine, ask for opinions and tips. I guarantee that somebody on this forum will probably have that brand and model. If you choose to get into used machines, anything goes. Some are diamonds, some are stones. Unless you buy a machine from a reputable dealer, you alone will be responsible for all costs of repairing it, should anything go wrong. Contrarily, all of our member-dealers have an excellent track record of supporting their customers with sewing problems. Prices vary a little, by brand, model, accessory package and shipping. In the long run these differences are insignificant, because you will get a quality machine and exceptional after-sale service, when needed. These big stitchers will last decades, if oiled regularly and not abused.
Toledo Industrial Sewing Machines and Techsew are members of this forum also and they both offer leasing through a third party. I think you will find that most of our dealer friends can work out something affordable for you. Machine-wise, there are plenty of sewing machines that can sew 1/4 inch, with say #138 thread, or maybe even #207. But, if you meant that you want to sew 12-16 ounce layers together, creating up to 32 ounces, this calls for the bigger 441 clones (Cowboy, Cobra, Techsew), or at least the GA5-1 and CB2500 type machines. Prices for these machines ranges from about $1300 for the CB2500, up to $2700 for a loaded 441 clone (Juki TSC 441). Perhaps you could be more specific about what you intend to sew and the size of thread you want the machine to handle.
Trox; Your links to the guide supplier, in the big reply, are broken. Could you please repost the links to the supplier's website, making sure that the complete URL is inside the Link field? I would like to see their stuff too.
Beware email scam with subject: "Re: URGENT" which contains JavaScript code to exploit your computer. Read emails in Plain Text to avoid this exploit attack, or others like it.
willisb; Check your bobbin case on the inside end, with the bobbin removed, and see if it has an anti-backlash spring. If so, remove the spring. I'll wager that this cures the over-tight bobbin thread problem.
Not likely Ferg. He stated this: "The thread spools out of the bobbin fine while I'm holding it, but once in the machine, the tension is far too high and is somewhat jerky when I pull on it." Something is pinching the bobbin thread as it feeds out of the bobbin case, past the shuttle carrier and up through the hole in the feeder or throat plate. It might could be the feed dog itself squeezing the thread. Once he hand-wheels the machine with the throat plate off, the cause should reveal itself. Thought! If the bobbin itself is slightly fatter than the space between the clamped on bobbin case and interior of the shuttle, the thread will be squeezed tightly.
I find that many vertical axis shuttle machines can start sewing without holding back the threads, but horizontal axis shuttles cannot. Hold back the threads for a few stitches, or until you backtack over the starting stitch For example, I don't need to hold back the threads on my Singer 66-1, or my Janome New Home embroidery machine, my Kenmore 158.19142, or my Singer 29k172 patcher, all of which have vertical axis bobbins. I do have to hold the threads back on my Singer 15-91 and 31-15 (both class 15 machines), on my National walking foot, my Cowboy CB4500 and my Union Lockstitch machine. The thread holding or not holding procedure seems to be dependent on the geometry of the shuttle.
