Wizcrafts
Moderator
  1. It might be able to hem Plonge leather garments (cuffs, hems), but is really meant for cloth. If you are asking if this machine will "sew" leather, as in wallets, vests, belts, holsters, absolutely NOT. It is a tailoring machine, used for hems and cuffs on shirts, pants and dresses.
  2. My buddy just sold his last month. It was good for 16 to 18 ounces of leather, with a #22 needle and #138 thread. The only problem was the pressor feet had teeth on the bottom. It made serious marks in veg-tan leather, but pulled leather through like a tractor.
  3. A Singer 111G in good condition should not sell for much more than $300 to $350. If it is in mint condition, maybe $500. If poor condition, $200. These are now very old machines, but parts are plentiful and not too expensive. Do kick its tires, with your leather and the thickest thread they or you have. It should be able to sew with #138 thread, with a #22 or #23 needle, through 5/16" of belt leather. All of those machines shipped with clutch motors, usually 1/2 horsepower. If the machine was sold to an upholstery shop, it probably has a 3.5 or 4 inch motor pulley. This will not be easy to control at slower speeds required for sewing leather. You can buy a 2" or 2 1/4" replacement pulley and a shorter v-belt online, or from our dealers, for about $20 shipped (for both). A dealer can help you decide what size belt you'll need, after you tell him what is on the motor now. Or, you can save a lot of hassles and buy a SewPro 500GR like I use and have perfect speed control from zero to 1500 rpm.
  4. I do sew thick and thin projects and have machines geared towards those extremes. At work, I sew on an Adler long arm motorized patcher and a Cobra Class 4 cylinder arm machine. At home I have a National walking foot machine, a Singer long arm patcher and a Union Lockstitch harness stitcher. Each does certain things better that the others. But, you asked my opinion for one machine that will do it all. Okay. Collars are worn around animal's necks and should be pre-curved when sewn. Purses have shapes that may or may not need to hang down, below the left edge of the machine. This suggests a cylinder arm machine. I'm not sure how thick your collars or purses will be, but when it comes to a sewing machine for leather, more is better than less. I'd buy a machine that could sew thicker that what I have in mind now, but still sew thin leather. Then, if you decide to sew holsters and sheathes, you will have enough machine to do the job. Since you asked what "I would buy," the answer is a Cowboy or Cobra cylinder arm, compound feed machine, with a servo motor that can run below 60 rpm and possibly, a speed reducer pulley. I am personally familiar with both. Either brand will sew from 4 ounces (using a #18 or #19 needle and #69 or #92 thread), up to about 7/8", with a #27 needle and #415 thread. If your collars will never exceed 3/8", you could get the job done with a "227" type machine. These are based on the ancient Singer 153 types. They have a 10.5" cylinder arm, about 2 1/2" in diameter and a triple feed walking foot system that allows you to sew right up to the left edge of the machine. Using the common series 135x16 or 135x17 needles, you can sew with thread sizes 46, up to 138 on these machines. They can be converted to sew a little thicker material, but not with much heavier thread than #138. I hope this helps. You are welcome to PM me if you have more specific questions about these machines.
  5. That Pfaff 463 is a very high speed, flat foot, bottom feed, garment machine. It can be used for sewing soft, but not sticky leather with thin thread. You would need a roller foot conversion to sew sticky leather, and would need to slow it way down. But, it will probably not be the right machine for belts. The Singer 111 with a walking foot will sew everything you mentioned. You can buy a small 2" pulley if it runs to fast for you.
  6. Babbs; You quoted me but didn't type a reply! Please try again.
  7. You're right; #138 is too thick for your garment overlays. #69 or #92 thread will be fine. If you will be making sharp turns, get the smaller roller foot (set). The big wheel is more for long straight runs. A roller foot on the left allows you a complete view of the tracing lines and the needle. You cannot get a more accurate system for following drawn stitch lines. Just keep the work lamp on the right side of the front, to avoid casting a shadow of the roller.
  8. You can buy the gear puller at Harbor Freight. I don't know if they have sewing machine pulleys. Clutch motors have a keyed 3/4 inch shaft diameter and use a 3/8" to 7/16" belt pulley. Most machines in tool stores use 1/2" belt pulleys. If you put a 1/2" belt pulley on a clutch motor, the 3/8" or 7/16" v-belt will drop deep into the grooves and may flip sideways. I recommend buying a sewing machine pulley from an industrial sewing machine dealer.
  9. Bob Kovar sells pressor feet, including the two sizes of roller feet, for the Singer 31 class machines. These roller feet are also used on the Singer post machines. I used to have them in about 3/4" and 1" rollers. You can adjust the sideways position to place the bottom edge of the roller just to the left of the needle. This prevents the leather from lifting and causing skipped stitches. When you buy the roller foot you should also get the single row feed dog and it's matching throat plate (and an edge guide for the right side). I had one of those machines when I was first getting into sewing leather. I think it was good for no heavier than #92 or 138 thread, with a #22 needle. Thickness-wise, it sewed about 1/4", if memory serves me. But, mine had a spring loaded snapping walking foot system. I don't think a roller foot can hold down 1/4" of belt leather, unless you crank the spring all the way down and use the smallest needle possible for the thread. That would be a #21 needle for #138 thread. You might even be able to feed thread through a number 20 Schmetz needle.
  10. I would gladly take either of those machines! Cost isn't much different between them and they both are capable of sewing 3/4" of material, with a really big needle and thick thread. Both the Adler 205 and Juki 441 sell/sold new for around the $4k - 5K mark. Parts are expensive, but last for decades. The Adler parts were made in Germany, while the Juki is produced in Japan. There are North American parts distributors for both companies. You can expect to pay more for feet, throat plates and replacement gears for these machines than regular industrial machines. Needles are the huge system 7x3 / 794, available up to #27 or larger. Both can sew #415 bonded thread. Both need a truck to transport them assembled, or a real station wagon with air shocks, if disassembled. The feed dog on both is compound feed, with the needle and inside foot moving together, while the outside foot lifts or descends, to hold the material in place. Top speed is 800 stitches per minute, but 600 is safer for the manually oiled bearings. Most leather workers gear these machines way down to about 120 stitches per minute; 2 per second. This extends the lifespan and makes it easier to sew through thick leather, bioplastic, or briefcases.
  11. I think they stopped making the LU-563 machines between 5 to 10 years ago, but I'm not certain exactly when. An authorized Juki dealer should have that info (if they've been a Juki dealer longer than 5 - 10 years). Parts are available everywhere Industrial sewing machines are sold. Juki is made in Japan and is solidly built. A 9 year old LU-563 that has not been abused is worth whatever you pay for it. It is a workhorse. I would go look at it sew before buying it, and see if the stitch length lever floats up at higher speeds and if the reverse position places the needles into the same holes.
  12. Is the class 30 long arm the one you told me sews up and down the arm?
  13. Basting means setting long stitches that are only meant to temporarily hold a hem, overlayed pieces, or seams in place, until the assembly process is ready for them to be finished with normal stitching. Some projects get stapled, paper-clipped, or pinned together; during construction, trimming, darting and fitting. Basting on a machine replaces pins, paper clips and staples.
  14. Babbs; I used to own a Juki LU-563 and found it quite adequate for sewing leather garments and denim jeans. It was a staple of the leather and denim garment and upholstery trades for a couple of decades, starting in the mid to late 1980s. New, the Juki LU-563 originally listed for about $2600, with a 1/2 hp clutch motor and table, but was frequently sold for about $2200 out the door. I worked for a sewing machine company in late 1988 and they were shipping these machines out as fast as we could assemble and test them. The LU-563 has been out of production for many years, so there are no new ones, hence no new price. The 563 has been replaced with a more modern design, known as the LU-1508 series. One of the best features of the LU-563 was that they used a huge bobbin, known as a U bobbin. It is about 25% larger than the M bobbins used in Consew 206RB and Seiko machines and their knockoffs. The reverse lever is large and easy to use. Being that the 563s are up to 30 years old now, you will have to check it out carefully to ensure that the machine is still fully functional and not worn out or shot. If the springs that balance the forward/reverse stitch length lever are weak, as mine were, the stitch length will vary with speed and direction. I actually watched my stitch length lever float upwards on its own, as I sewed fast. The 563 was good for about 3/8" of material, with #138 thread and a #22 or #23 needle.
  15. My leather point needles are marked 135x16 NW
  16. I'll be your Huckleberry... I have a Singer 29k172 darning patcher. The purpose of the darning system is to allow freehand repairs, without concerning oneself about the pressor foot pulling the material. A true darning patcher has a T-bar on top of the read of the head section. The T-bar can be twisted into or out of alignment with the needlebar, in three stages: not engaged, half engaged and fully engaged. Picture of T-bar darning attachment: When the T-bar is turned so that the needlebar hits it, the pressor foot is lifted off the material with the risen needle. The thread tension is not released, because the darning tensioner is not connected to the lifted foot thread release system. This allows you to freely move the work around, while maintaining constant thread tension. The pressor foot drops down long enough to keep the material from puckering as the needle lifts up, but then goes up higher, depending on whether you have set the T-bar to half or full lift. I am able to get consistent 1/2" stitches at full lift and 1/4" on half lift, with minimal assistance to the feeding. Were it not for the constant tension darning disks, the lifted pressor foot would disengage the top thread tension every time the needle raised. The darning system is very useful for basting cuffs and hems. If your patcher doesn't have the T-bar, you will still be able to bast, using the darning tensioners, but must do so more quickly, before the foot drops down on the material. You should be able to get longer stitches than the foot alone gives, but not as long as you would with the T-bar assisted lift.
  17. You need to change to a twisted chisel point leather needle. The bottom is not right. Look for series 135x16 needles. Those are t angled, chisel point.
  18. We have several members who are sewing machine dealers and stock all kinds of parts for most industrial sewing machines. Perhaps one of them will reply to your request.
  19. I hope and pray that our members in Christchurch New Zealand are alright, following two earthquakes today
    1. Ladykahu
      Ladykahu
      My thoughts are there also.
      My family is safe and I hope
      everyone else's is to. (I am a
      Kiwi living in aus)
  20. Wow! How not to run a business! Glad you got it back in working condition.
  21. If you send me a PM I will discuss them with you. Otherwise, I can say nothing more on this open forum.
  22. If you are prepared to spend $1400 on a machine, you can get a Cowboy CB2500, bottom feed flat foot cylinder arm machine (same as Ferdoco 440R), with reverse, for a lot less than that. You could add the accessory foot and roller guide package and probably still be under $1400. They are sold by Toledo Industrial Sewing Machines. Their phone number is 866-362-7397. Several of our members have this machine and love it. It is just one step down from the big harness stitchers and is capable of sewing about 1/2" of dense leather.
  23. I looked up the Singer 331k16 and found that it is a roller foot machine. Unless yours has been converted, it has a large roller foot, with a single row feed dog. This machine is for light weight leather, like shoe uppers. It will probably be limited to sewing no more than approximately 3/16" of soft to medium temper leather, with a size 18 needle, using #69 bonded nylon thread. Perhaps it will handle #92 thread, if you can fit it with a #20 needle. Typically, machines for the shoe industry use #69 thread and a #18 needle, sewing together about 6 to 8 ounces of leather. I had a similar roller foot machine and it was good for lightweight work under 1/4", but not so good on belt leather. I sew guitar straps, using a walking foot machine and #138 bonded nylon thread. I wouldn't recommend using any thinner thread. I don't think your machine can use that size thread (in my opinion), which requires a #22 or 23 needle. I don't believe that this is the machine you want to sew dog collars on. Collars are put under tremendous stress as dogs try to break away and chase other animals. Number 69 thread only has an 11 pound breaking point, which is inadequate for this kind of usage. You are going to need a machine capable of sewing hard veg-tan belt or bridle leather, possibly double layered back to back, exceeding 1/4" thickness. Add the fold-overs for Dee rings and you are up to almost 3/8". I always used number 277, to 346 thread on dog collars, to match the strength required to withstand the tugging that big dogs can apply. These thread sizes require a needle of sizes 25 to 27. You have just crossed over beyond the common industrial upholstery grade machines into the world of harness stitchers. Congratulations and welcome to the Big Dog club! Save some more of the pennies, then start looking over the specs on the big cylinder arm machines. Heck, for collars and leashes you can even use a big flatbed machine, like an Adler 204-370 (or clone). One of our members recently had one for sale in the Eastern US. It sews 3/4" of leather, with a #25 needle, using #277 thread, as set up. See the Used Sewing Machines For Sale section of the LWF.
  24. Based on your photos, I stand by my original recommendations. The Cowboy 227R is perfect for this kind of job. It can even sew the final seam shut, foam in, hanging down over the closely cutoff end of the arm. It has a large hook and M-size bobbin, which holds plenty of thread (#69 to #138) and has just over a half inch of clearance under the raised feet. And, it natively sews perfectly fine stitches with #69 or #92 thread, which the larger harness stitching machines might need to be modified to handle (for very thin needles, thread and soft material). How do you know that these machines are beyond your price range? Call Bob Kovar, at Toledo Industrial Sewing Machines, at 866-362-7397 and ask for the price on the Cowboy 227R. You may be pleasantly surprised.
