                Posts934
Everything posted by KnotHead
	for 8 inches. I usually start out with about a yard and a half for the oops factor. Brian..
	The braid just seems to go really fast when you get it going. That's what I like about these braids. You spend less time doing the actual braid than you do the knots. LOL... Brian...
	Thank you for the very kind comment Peter T... @GrampaJoel Thanks for the very kind comments. I like reading these replies very much. The ten strand whip makers plaits come in different varieties. Under 2, Over 3, Under 3, Over 3, and so on. But all of them remain a round braid. I braided mine with and under 2, over 3 sequence. Reason being is that I have found that the way the under 2 rolls in on itself at the bottom of the braid tends to fold in leaving the outside of the braid(Over3) with chance to fan out and bend much easier, or more naturally. It is also a quick braid once started. So I'm spending less time doing a braid. Now I have experimented with this type of braid and tweaked it on several occasions to reach a desired effect for draping around a neck line more naturally. It's a simple braid of Under 2, Over 3. I think this might be in several books. But I am uncertain of that. You might be able to find it in a few of Ron Edwards books. But again I am uncertain of that. @bucksnort; Thanks for the very kind comment Buck. Mean a lot to me coming from a place winner at the world leather debut. Congrats again mi amigo.
	I started this one while I was in Sheridan for the world leather debut. This one is headed for a new found friend from florida that I met in Sheridan. 17part 8 bight Pineapple with 1.3mm whiskey tan and an offset saddle tan lace. 10 strand whip makers plait for the loop done in rectangular plaiting. Brian...
	Looks like I'm doing the bottom part over again. Ho hum... Brian
	LOL... You're too funny Buck. See you there bro.
	So am I. LOL. I'm getting tired of looking at it. LOL...
	Got me an idea brewing. Only 4 more things to do. What do you think so far? The necklace braid is a modified whip makers plait. The pendant part is another modified whip makers plait with 2 transitions in the braiding. This should be interesting to see if I can actually finish it off and still make it look pretty. LOL... This is what happens when I'm left alone with my leather for too long. LOL... Brian...
	  Braiding Or Another Decorative Technique On This Ornate Case?KnotHead replied to Stewartjlh's topic in Braiding It appears to me to be a mixture of Austrian quill embroidery and applique work.
	Flat piece of leather. Soak it in water for about 30mins. After soaking I then cut a 1 inch diameter circle. Inside that circle I cut a 1/2 inch circle (A doughnut) in other words. Then I put the circle over a tapered rod like a pool cue and pushed it down till it stopped and could not go anymore. I then used a plastic zip tie to hold down the bottom most edge of the leather circle and waited for it to dry. After drying I then dressed up the leather. Brian...
	Is there any scientific data to support that? Brian...
	From the album: Misc Leather Works This is a seamless leather ring about 1 inch. I got this idea from Peter Main who posted his on his FB page. A real interesting story behind to. A good little puzzle that I had fun with.
	I like the slits better. But that would require more lace and more time. I usually scribe a line at 1/8th from the edge with my dividers and then chisel my slits right below that line. The chisel in other words will just touch the line that is scribed. I also angle my chisel at 45 degrees. It is also better to chisel while the leather is wet just as you would in tooling leather and it is also much easier to lace when the leather is at the right temper as in tooling also. I use a fid to open the slits just wide enough to fit the lace through without any friction to the lace. Brian...
	You should be okay going around the smallest turn. Space your holes 1/8th apart and 1/8th from the edge and you'll get much better coverage through out the whole project. Brian...
	Nice work. Brian...
	A 5 part 4 bight base knot - 4 bight is divisible twice. A 7 part 6 bight base knot - 6 bights is divisible 3 times. A single string version of the gaucho will work on the second one quite well. Gauchos are dependent on the bights being of an even number or the numbers being of an even type value. I have only encountered this once or twice and only because my braiding mentor brought it to my attention some years ago. So I had conducted a little bit of research into that matter. The 7part 6bight base casa knot seems to be the most popular with this simply because people tend to tie this knot more often than not. It's been some years ago that I worked on this research and the data is some where on one of my hard drives. Of course this will take some digging through about 10 hard drives. Gaucho Knots - Quoted from Tom Hall (Introduction to Turks Heads) page 127 " Gaucho knots are regular cylindrical flat braids with a constant column coding throughout the knot. It must have gaucho bights on each edge of the knot. Gaucho Fan Knots - Again from Tom Hall's book (Introduction to Turks Heads) page 125. I am hoping that this helps out. Brian...
	Mathematically that will not work. Simply because the 7x6 is both row and column coded. Brian...
	Thank you all for the very kind comments. Brian...
