Everything posted by billymac814
I'd just deal through Rob at RMB (bluegun store.com. His price is 39.99 and will ship free on orders more than 12 guns and you can be sure you'll get them and in a timely manner. He may even give a little better price for 25, you never know until you ask but I will say this, he simplified my life a lot as I don't have to track down the gun I need and then hope I either get it or get it in a reasonable amount of time.
I see what you mean by a boot top now. I use a lot of the 4oz and 1oz spools too because this machine only gets used for repairs as well. The one oz ones are good for the not so often used colors, the 16oz spools that I have are shared between this machine and my Consew. I have another Singer patcher just like yours that's in another corner, I keep it loaded with black thread that way if someone comes in needing something done quick (and its black) I'm able to do it right away if need be. I prefer using the Adler though for whatever reason. I don't have any type of thread stand on the Singer.
This is the thing I got, not sure what its called. Ill just mount my burnisher in the chuck and a felt wheel behind it. I shouldn't need to switch anything out then. I think I'm going to mount it on the edge of my bench raised out on 2X4 blocks. I got it from Lee Valley for about 30 bucks, I had the chuck, burnisher and sanding drum so I won't have much invested depending on how patient I am for the motor, I don't want to buy a new one so I might have to wait until I find one used. There was one at a flea market that I was going to buy a few months ago as a spare, I'm going to head up there again this weekend to see if its still there, it was the last time I was there but now that I want it I'm sure it'll be gone but there might be others.
That's the way the mandrel type thing I got is. One side is left hand thread. Its used for buffing wheels and such. I'm going to put my burnishing wheel on one side which is the wood burnisher and below it I have a felt wheel that probably works similar to your fabric covered drum. On the other side I have a sanding drum that I drilled out to fit over the shaft. Here's a picture of my current setup. You must have had yours for a while, it looks a little different from the ones in their new catalog. The new ones come out at a 45* angle to stick over the bench. It also looks like yours has a back shield that probably keeps some of the dust down. I may at some point get one but I think mine will work good, plus my burnisher is smaller in diameter which gets in tighter areas and it has the point for belt slots. I just need to come up with a motor to use, mine only starts if I spin it by hand first so there's no sense in using that motor. Thanks again.
Yep that helps. I currently have my cocobolo burnisher chucked directly onto a motor spinning at 1725 so I figured that would be fine, it is however hard on the motor so I got a thing that is similar to the end of the Weaver setup like you have so ill be able to add a sanding drum on the one side and the burnisher on the other. The weaver set up is a little more finished looking with the covers over the pulleys and belt but I already had everything except this one piece so it was a lot cheaper. I will either need a new motor or to have this one repaired as it no longer starts on its own. I have a customer who rebuilds motors but he's having some health problems right now so I may have to just find another one. Thanks again, I was kinda curious as to what theirs spin at.
I'm having a hard time picturing what it how your thread is sitting. Here's a picture of mine, I have a 6 spool thread stand plus the one on the machine, the rest are small spools that I don't use as often so they get rotated onto the one on the machine. With the thread stand I would cut off the excess anyway so I'm not really worried about thread waste as its not that expensive and would take longer to try to roll it back up. I have heard of one particular shoe repair guy on another forum I belong to that saves the thread he pulls through for hand stitching jobs. I'm not doing that either, ill snip it and trash it. I did use to roll it back up when I just had the single thread stand on the machine but my stand saves me more time than a few feet of thread cost me so its no big deal.
I quite often stamp pre dyed and pre finished leather like English Bridle. No water or anything using Delrin stamps. They work fine, just require more pressure. I have a hot stamp somewhere in transit somewhere in the world but obviously can't comment on how well it works yet. Here's a stamp in English bridle using a delrin stamp, I stamped it in an arbor press.
For Those Of Us, With Not So Good Eyesight.
billymac814 replied to BearMan's topic in Leatherwork Conversation
I used to wear one of those doing tooling when I worked in my living room and the lighting sucked. Now I don't need it so much anymore. I also used it to read at night. I also have two of the lights Tippmann sells for the Boss, they are magnetic and attach right around the needle bar. I have one on the Cowboy and one on the Consew. They work great. -
How Much?
billymac814 replied to billymac814's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I could bang them out quick if I made a design and had dies made and made the same one over and over, that way I could subsidize the design time. The problem is everyone that inquires about a wallet has something specific in mind which means they'd have to pay for all the design time too, it just drives the price through the roof. I think I'll stick to not making them. I do make the occasional card case and simple type wallets, I may look into some other types that I can make over again and if that's not what they want then so be it. -
Which Machine Would You Buy And Why
billymac814 replied to LeatherWerks's topic in Leather Sewing Machines
There's a 103 on eBay but I think they want too much for it. Its just the head and they claim the stitch regulator isn't working. I'd rather get one from Bob that I know will work and has been gone over. Ill email him and tell him to keep his eyes open for one. What is a reasonable price range if I found one on Craigslist or eBay? There is one on eBay but I'm thinking its too much as I'd have to get a table and motor and reducer and potentially have it gone over. Thanks. -
I thread mine but don't lube it. I don't think it would save you an incredible amount of time by not threading it. I had one machine without it and I always felt that it helped keep the thread in the correct path but it worked fine without it too. As of late I've been just tying my new thread to the old thread and pulling it through. It saves maybe a little bit of time but not much as I can thread it pretty quick, I often have to change colors many times each day.
Once wives start seeing money roll in because of it they tend to have a change of heart:-). I met my wife after I was already deep in it but when we got a house together having a workshop in the living room wasn't going to fly so when we picked out our house it had to have an extra room for a shop space. She was also very supportive when I came home with the crazy idea of buying a shop and going full time, in fact it probably would have stayed a pipe dream if it wasn't for her. She actually quit her job before I did and ran the shop during the day and I came in after work and stayed till 1 or 2 am, which wasn't much different than before except I wasn't home working.
I was wondering why I could never see people's location in their profile, as it turns out it is not visible in the mobile version. Bryan, If you want to throw your boss in the car and make the trip to Altoona Ill give you as much info as I can and hopefully get it set up right. You can also give a cowboy a test drive, I will forewarn you though, you will want one.
That's definitely not the same as the picture you showed and what's up with his bangs?. The picture you showed is done with mitered edges and saddle stitched with a curved awl although you could get away with using a straight one too. As Rayban mentioned its in the Stohlman book, it is also in the "Art of handsewing book as well.
Art, What's the difference between the 153w-101 and the 103? -
That kinda reminds me of my old shop space. I think it was roughly 100 sq ft or somewhere near that. I sometimes think I was more efficient there, all I had to do was spin 180 degrees around in my chair and I was at my sanding and burnished area and spin 90 degrees more and I was at my stitching machine. I only had to get up to dye and cut. Cutting was a real pain though as I couldn't lay a side out anywhere and that was why I knew as soon as I got a bigger shop I'd have a big cutting table.
They do look good. Ill admit to not reading the whole post as its kinda long but mine usually are too so I can't hold it against you. I'd rather drop a sewing machine on my toe than hand stitch too much these days but if I did more hand stitching I'd probably look into buying one of these. I think its an interesting design and the angle in which you can place it looks like it would really help push the awl through. I made my own pony when I hand stitched and still use it if I need to. Mine is not anywhere near as nice as yours are. Good luck, I'm sure with craftsmanship like that you'll sell plenty here. Leatherworkers seem to appreciate nice quality tools.
It's probably made out of harness leather or English bridle leather which are usually a little on the softer side. There's probably not much you can do to stiffen it much, its probably too thick to stitch a second layer too unless you split it down and laminated a second piece to it. You could maybe rivet some kydex to the back of it but I don't know how well it would work being just a single layer. Normally stiffners are added in between layers and stitched in. I make my double layer gun belts from 2 layers of around an 8oz glued and stitched together. Its much stronger than one layer of equal thickness as the glue and two layers of top grain make it quite stiff. I don't believe the stitching adds much in strength but its there for good measure. To keep them from feeling "Too heavy and too thick" I skive the billet end down to about half and the buckle end is just a single layer where it folds. This way when your wearing it it doesn't feel too bulky and thick. I've seen where other makers don't take those extra steps and the belt is sometimes nearly an inch thick where its buckles at!
Wow, Buying A Collection Of Machines!
billymac814 replied to Anne Bonnys Locker's topic in Leather Sewing Machines
There's a Junkers and Ruh on eBay right now. I was really considering buying it but that's a lot of money for what will amount to a play toy for me. If I didn't need a few other things more I definitely would but since I'm not I figured I'd let you guys know. It looks to be fully rebuilt and is 750.00 buy it now.
