TLP
Everything posted by TLP
  1. how do I form the leather around a stone cabochon to hold it in place on a leather bracelet? Thanks for any help.
  2. how is the knife holding its edge? the carbide tipped saw blades are not usually very good steel. the saw blades best for repurposing for knives are the non tipped blades which use a better steel and are heat treated to be harder.
  3. Are there standard widths for mens belts?
  4. A couple of observations for what they are worth. Firstly, the micro torch might be a bit on the small side for conchos larger then a quarter. never used one myself but have had students and friends that used them, They seemed to have trouble with larger and heavier pcs. Secondly, I personally would not use a soft plumbing solder to attach the chicago screw. I would prefer to use a high temp silver solder and the appropriate flux for the increased strength of the bond. and finally after silver soldering the chicago screw in place soak the assembly in a mixture of white vinegar and salt to chemically remove the residue of the flux after which you can polish, this called pickling and can also be done with commercially available pickling compounds. A very nicely put together tutorial.
  5. Have a belt that I need to dye a dark black, My mentor was not sure what I should use having never used black. any suggestions would be appreciated
  6. Where can I find the cutting pattern and directions for a Ranger style belt with the narrower sewn on Billets?
  7. Where can I find the cutting pattern and directions for a Ranger style belt with the narrower sewn on Billets?
  8. Recently saw a belt with chevron shaped thread appliques, is this something that is purschased and applied, or is it made in place? did not get a chance to examine the belt and only saw it from a distance.
  9. I would start with 320 grit sandpaper then go to the buffer with bobbing compound, then tripoli compound and finish up with red rouge compound
  10. I use a jewelers saw when I am making stamps, only use the hack saw to square up the bolt heads. I find the hack saw to unwieldy for delicate work. Make sure you use good blades, a lot of the blades that come out of India are not that good. I use Hercules or Laser Gold blades from a jewelers supply house. # 1 or 2 would probably be sufficiently fine for the work you are doing
  11. the next stacked leather handle you do you might want to use a clear epoxy, it will soak into the leather and help to stabalize the handle ( seals and keeps out moisture ) is what I have used for knife handles, was recommended by the company that manfactured the blade in their finishing directions
  12. TLP
    Metal mold maker
    Are there any art / bronze foundries in your area? carve./ mould a pattern in wax and have them cast it
  13. did you ever check to see if the charms were magnetic? if so could silver solder. if brass bronze or copper also could silver solder, anything else would not try to solder. And not to be negative but epoxies like jb weld will not hold up over the long run. (My old jewelry teachers would have fit if I suggested its use) the only sure connection is to use solder or a mechanical connection (ie rivet)
  14. What kind of metal are the charms? anything other then silver, stainless steel or regular steel will be difficult. with the mentioned metals they can be silver soldered to a back pin of some kind and instant concho. with pot metals not so easy, the pot metal will melt before the solder. you may be able of epoxy a post to the charm, but it is almost certain to pop off. you might also try to solder to charms to a post with stabrite solder, a low temp solder for things like pot metal, but would be iffy in that you still might melt the charms first, but it is probably your best and strongest option.
  15. TLP
    Bolo Cord
    was going to use 6 strands
  16. TLP
    Bolo Cord
    What should I use for the core on a bolo cord?
  17. what stamp is used for this pattern
  18. Just learned of a new book out at Amazon, Making Jewelry Design Stamps, runs about fifteen dollars
  19. Its actually a page from Indian Jewelry Making by Oscar Branson
  20. I think you answered your own question, Your other work sells in a timely manner, this does not, time to put this stamp in the back of your drawer. If someone asks for it then Ok, burt otherwise stick with what sells.
  21. How is a silver belt tip attached? The kind that come with the three pc ranger buckle set, the buckle, keeper and tip.
  22. Here is a new pattern for me that I carved from wax last fall
  23. I do cast lost wax in bronze and Sterling, and also fabricate from sheet and wire.
  24. I do belt buckles in Sterling silver and Bronze, and have never had a problem with the metal and leather reacting with each other. Do not know if there is a reaction between pewter and leather but do not think there is as there are a lot of die cast pot metal buckles out there. Are you going to be fabricating (start with sheet and solder on parts) or casting?
