Ferg
Contributing Member
Everything posted by Ferg
  1. Overnight at least. ferg
  2. I am not bashing Barry's knives in the slightest, simply need more than one source for an 1/8" bead blade, preferably fit a Tandy knife. ferg
  3. My first thought was a railroad track. Unless he has a particular font in mind for his name, use one of the "Railroad" fonts. Google for the font. I have used some of those. ferg
  4. That may be better answered by your googling for leather sites. Quite a few of the leather companies sell the tools also. What you feel is cheap/economical may be different with another person, okay? BTW: Cheap is not always the best choice. Many of us on the forum buy from a number of the companies advertising here. ferg
  5. I know you probably wish to make the handle, in case you decide an easier way, access this page: http://www.ohiotravelbag.com/FlipBook/hardware%20catalog%20p210/index.html?pageNumber=136 ferg
  6. Ellen, I appreciate your due diligence but you have disqualified yourself from almost any self employed endeavor. Think about what you have stated as a "No-No". Is there anything left with exception of selling pencils and keyfobs on the corner? ferg
  7. Ferg
    Consew 227R
    Looks as though your belt is out of alignment with motor/speed reducer. It has some damage to the edges of belt. ferg
  8. I have changed my feet to smooth with no problem and it definitely reduces the impressions in the leather. Decided not to grind the feet that came with the machine, may need them for some other type of material. The amount you change the pressure definitely makes a difference. You need to make sure the leather isn't raised on each stitch. BTW: I didn't change the pressure on the inside foot, only the outside. ferg
  9. Thinking about this I imagine it would work to some extent. The glass slicker smooths as you push/pull it across the leather. The rolling pin would probably just "mash" the leather which could work, partially anyway. Don't forget to clean the "dough" off the rolling pin. LOL ferg
  10. You can get smooth presser feet. Try on-line or call Bob Kovar. You may need to back off the pressure on you presser feet also. Mostly trial and error. ferg
  11. Begore we get someone into a real mess here, let's start over. You need to "Case" the leather before you can tool. That means you emerse the leather in warm water plus some other concoctions that folks use, for your purposes just use plain warm water in a pan. Hold the leather under water until you see no bubbles rising from it. Remove and place between two old T shirts. If the room you have it in isn't extrememly dry and warm you can leave it over night. The leather shoudl begin to look almost the same color it did before placing in the water. Trace the design and use your swivel knife to cut the lines followed by tooling and stamping. That is an over simplification but it will give you the idea. There are as many ways to case leather as there are folks doing leather work. Try a simple way as I have outlined then get carried away:) Personally, I have never put a piece of leather in a fridge and I do not like to place it under glass. I have done the T shirt method for many years, it works for me ferg
  12. The "Wiz" has information you should listen to. You are going to be hardpressed with your budget but can probably get a used machine if you are carefull. Bob Kovar and several others have used machines and can help you select one for your purposes. There is no one machine that will do everything. I bought a walking foot machine because of recommendations of Wiz. Read his and other posts very carefully, ask questions. ferg
  13. If you have the money to spare or maybe hidden somewhere, buy the best. I think that is the SK-3. If you want one to try your hand at carving then by all means buy one of the inexpensive Tandy knives. I would also have at least one 1/2" straight blade, one 1/4" straight blade, and a 1/4" angle blade. To be less expensive, just buy one knife handle and a couple seperate blades. Blades are $8.00 with no club membership, good knife, $20.00 no membership. I have the cheaper club fee for Tandy. This year I should have gotten the big one. Tandy has got to be your starting point. They have classes, reasonably good leather, inexpensive stamps, some not so hot but it is a starting point. Educational material out the wazoo and many of the finishes etc. folks like to use. When you get bitten by the "Leather Bug" for sure, you can buy some nicer, albeit expensive, tools. Tandy has several beginner sets that are priced right. Obviously there are other tools you will need to get started. Plan on spending $250 to $300 if you start at Tandy with some starter pieces of leather plus tools. $500 to $1000 if you want to pick and choose on professional tools, no leather. ferg
  14. It wouldn't do you any good to know my Insurance agency, you are 800+ miles from me. Just kidding. This is very much like getting a company to insure a log home, we live in one. They have no idea how safe a log home is in comparison to a frame house and don't care. You need to contact Insurance company home offices first then get an agent. No one can help you with that. ferg
  15. Thanks folks, much appreciated. ferg
  16. To make the needle easier to hold in yor hand when tracing, tap the end of the needle with the eye, into a piece of dowel. You may need to drill a very small hole to get the needle started. ferg
  17. As I have said before, you are an amazing artist and have the ability to transfer your talent to leather. ferg
  18. I do a combination of hand and machine stitching. I agree that renactment product should be hand stitched. I do not agree that everything hand stitched is better. I love to hand stitch. After a very long piece of stitching on my machine my fingers do not hurt nearly as bad just my .02 ferg
  19. Frisket is odd ball stuff to use at best. You might have a problem with it adhering to wet/dampened leather. We used to use it a lot but not for leather. ferg
  20. Bob, This is a little tricky. Where the spine folds, two places, you need to gouge a groove about halfway through your cover leather then skive the side of that groove to a 45 degree angle, as close as you can. That allows the cover and back to fold more square and the cover doesn' t have the tendency to stay open. The liner needs to be cut oversize. When you apply place the liner on the front side up to the groove, lift the front about halfway and apply liner to the spine, then to the back cover. You need to lay out your liner so cutting off extra material won't have any bad effects. You only sew the parts of the liner together that are not going to be stitched when you go around the perimeter of the cover. Practice placing liner without glue before you attempt it with the contact cement as it will stick so you cannot move it. Suede has a soft fuzzy interior. Normal cowhide/calfskin has not been "roughed up" so the edge appears more solid. BTW: Do not use latex contact cement. ferg
  21. I will assume you bought a "Craftsman" punch and not one of the expensive Osborne. You may also want to dampen the leather, it punches much easier. ferg
  22. This might give you some needed info. Also: type into google: singer 591. Lots and lots information on this machine. ferg
  23. I stopped making belts just before discharge from the Navy in 1956. Never was one of my favorite things I wanted to make something that I could use my new Consew 206RB-5. The stitching is with #138 thread top and bottom at eight stitches per inch. Never would have been able to do this without the unending help and support from Bob Park and the "Wiz" whom I have communicated with many times. I wish to thank them both publicly. The outside of the belt is made with 8/9 oz. cowhide from an Italian Tannary that was factory dyed. The inside is 3/4 oz. natural calfskin. The "keeper" is calf skin and has the same design as the inside. Inside design was an idea I had after viewing an image of a blade of grass. Weird huh? Thank you for looking. I wish I was better at this, maybe there are enough years left to attain some of what I am hoping for. ferg
  24. Jeff, The tools with chrome chipping off will cause you nothing but trouble, rusty ones are suspect but you may be able to clean them up. ferg
  25. Scott, If this is your first try, not bad. You need to move your beveler as you tap it with mallet or maul, walking is the proper name for it. I have never used the ceramic blades but I have an SK-3 among several other swivel knives, it cannot be beat. For small work a 1/4" angle blade or even an 1/8" angle blade would work better. The beveling.... you need to look in the forum archives for figure carving tutorials first then consider buying some Al Stohlman books or some of the other leather artists on this forum have tutorials as well as publications. Look, study, practice, practice, practice, did I mention practice?? ferg
