Ferg
Contributing Member
Everything posted by Ferg
  1. I think the fact you rushed it shows. Your photograph is skewed so the stitch line may be also. If not you need to make a mark for the stitch line and follow it. Your stamping and carving are well done but I would get rid of the Bucking Bronco unless you carved it, then don't use black as a finish. The Meander tool is a difficult tool to use, you done a good job but the design lacks something. I would need to see it to clarify that statement. ferg
  2. I have some arthritis in my hands accompanied by some cramping when using the knife. Non medicinal: I stop every once in awhile and rub my fingers, notably the base of my thumb. Medicinal: When it gets too bad I take two Bufferin Back and Body. Mostly, I just live with it. When you are 77 years young you expect annoyances. LOL ferg
  3. Welcome to the forum. Just do a search on most anything pertaining to leather inside the forum, you will probably find much of what you seek. ferg
  4. Try these folks, they have many products. http://www.leathercoatings.com/clear.htm ferg
  5. May I suggest you get a "splitter"? You could get the colors you desire by using an Air Brush. ferg
  6. Crystal, I am in awe. Your craftsmanship is superb. Attention to repetitive detail is an art and you have the "Touch". ferg
  7. Welcome to the forum. We like pictures of folks work. ferg
  8. Yes, I have said many times, the Shell Cordovan is one of the finest leathers you will ever use. Fantastically beautiful wallets from these, they wear like iron. ferg
  9. Chris, YOu need to dig a little deeper on this site for the dyeing info. There is a lot. I googled "How to dye Leather" and got about 15 sites with varying degrees of info with two pages. ferg
  10. Mack, Are you pulling the thread through a piece of brown wrapping paper, paper grocery sack same thing? After you apply the wax? This creates heat on the thread and melts the wax into it. You can actually feel the heat between your fingers. I assume the thread we buy pre-waxed is run through a wax pot such as the larger sewing machines use. You could buy some of the wax and a pot from one of the sewing machine folks on here to pull the thread through. That would likely give you the heavy coating you desire. Try Bob Kovar at Toledo Industrial, I bet he has a pot to sell. Buy a pound cone of the thread you like, mount it on a pedestal, run it through the wax pot and onto a hand winder on the other side or use a fractional gear motor connected to a shaft with a large spool. That just might work for you. ferg By the way I believe I bought the linen thread from the Thread Exchange at : http://www.thethreadexchange.com/
  11. Ken, I too am amazed at what some folks regard as professional product in many fields. I have done stained glass and am simply appalled at what is on the market with soldering that is total trash. Not into sheaths so haven't ventured there. I have no doubt the problem exists everywhere. High dollar with what you can get away with seems to be more prevalent every day, sad. For the most part everyone on this forum does extremely fine work. ferg
  12. I certainly agree that the discount is worthy of consideration as is the equipment. I would really need to sharpen a lot of knives to warrant even the $275. A side note: I believe I could build a pretty close facsimile of the equipment. That is not taking anything away from the WE, ferg
  13. Actually I don't care for the waxed thread you buy in the small spools from Tandy and many other sources. When I hand sew I wax my own much the same way you are doing it. Never occurred to me that it was such a hassle. ferg
  14. You must have a Tandy store near you. That would be a great start. ferg
  15. Clever pattern, I like it. Your design? ferg
  16. Bobby, As always your work is as near to perfection as I have ever witnessed. I sit in awe every time I study one of your pieces. ferg
  17. Actually the cordovan shell will cost you about $150.00 direct from Horween. It is some of the most beautiful leather I have ever had the pleasure of working with. Dyed the cordovan color. ferg
  18. Joe, If you want some more of the wood let me know. I may be able to find a chunk in the wood pile, if so it would have been air drying for two years, under cover. Just let me know ferg
  19. Nice pipes Stewart. We have Hackberry trees on our property in Ohio. When you cut with a chain saw the chips are almost white. Other than that it is a less than pretty tree with rough bark and Elm Like leaves. ferg
  20. Oil based are good also. You should allow them to dry for a couple days before you try any water based work with them. ferg
  21. I hate applying dye with a dauber. Try a piece of old T-shirt material, you can get bags of the stuff at Lowe's. Make a wad of the piece about halfway between a golf ball and baseball size. Wear protective gloves unless you wish to wear the color for awhile. Diluting the dye is a good idea. ferg
  22. I am sure this is another instance of "preference". Are you by any chance using water based dye? If so you may want to try solvent based/alcohol. ferg
  23. Chris, She is beautiful. Each one is more precious. I know because I have three girls and a boy with seven grandchildren. ferg
  24. I personally think variations of an Art Form is what keeps the Form interesting. I am neither for or against the beveling, I do like your design without the beveling. I have tried subtle backgrounding inside some "leafy" knife designs, they add interest also. Maybe you have gone a little beyond subtlety plus your beveling needs some work. Your last effort with additional cuts adds another dimension, I like it. Just my opinion. ferg
  25. Nice use of the Meander Tool, ferg
