Everything posted by Beaverslayer
	Now to place the gusset in the right position. You want to set the gusset down on the shell, then by folding the edge over on the side, so that the outer edge of the shell you see a small thin bit of the garment leather showing. Straighten the gusset so that all the way along the edge the space is the same. Next, do the same thing to the top corner, moving the gusset up or down to get in the right position. And again do this on the bottom of the gusset. Now that the gusset is in the right place, using your gel pen, mark the inner edge of the gusset on the insed of the linner. To do this, you want the mark to be just underneath the edge of the gusset. Hold your pen on an angle when marking. Now apply a liberal amount of glue to the area that you've marked off, also a liberal amount of glue to the inside of the gusste. Place the gusset onto the shell, using the line to be sure it's in the right position, roll this seam real well to make a good bond. Now, fold the outer edge over the gusset, and make a mark where the inner edge is. Measure the distance from the outer edge to this mark. It should be right around 1 1/4". Whatever your measurement is, this is the one you want to use to mark all along the outer edge as shown in this picture.
	You want to mark a 1/2" space all the way around the outer edge of the vest. Next, sand this area, all the way around also. Then with a damp cloth, remove any remaining marker lines, so you have a clean area. You will also have to cut some long lengths of the suede into 1 1/8" strips. Makes these as long as possible, as we do not want to have to put splices on this. I always start on the side of the front section. This is where most of the mitered corners are, and we want to be sure they are fitted correctly. First you want to just snip out a bit of the corners, not too much, just a bit. Then, as we did previously on the gusset pieces, apply a bead of glue to the vest shell, and also a 1/4" bead of glue to the suede side of your strip. Place this so as the 1/4" wide bead is at the inner edge of the glued area. Now, apply glue to the area as shown here in the picture, leave abot 1/4" from the edge, so you have a clean area to grab a hold of. Fold this over, and press and roll the seam. Then, flip the vest over and as we did on the gusset, apply glue to the underside, fold over the edge and press and roll the seam. You should have a nice finished edge now, that looks like this. On the curved area under the arm, you will have to work the suede a bit so it takes the curve, try not to get too many little creases in it when you do this area, if you have to just stretch the suede a bit, too lessen the severity of any crease.
	"Now that's a KNIFE" very nice. Ken
	VERY VERY nice looking Beeza, that's going to be one nice seat. Sorry about the blister. The "pebbler" your using, where did you get it from? Iv'e looked everywhere up here and even Tandy had no idea what I was talking about. Ken
	Nice looking saddle. You guys that do these are amazing, the things that you must have to do to make one of these just boggles my mind. That border around the basket weave, is that don with just one tool, if so, which one? Thanks for posting the pics. Ken
				Headknife sheath
Beaverslayer replied to TwinOaks's topic in Gun Holsters, Rifle Slings and Knife Sheathes
First off, great job on the sheath. What you need to do when lacing something thick like this, is to make the edge rounded somewhat. You can do this either with your belt sander, or with a sharp knife. Next, the reason your lacing has the spaces between them, is that the lace is not wide enough. If your hole spacing is 1/4" you need to use 1/4" lace. If you have made 1/4" hole spaces and you use 1/8" lace there is going to be a gap between each lace. What I tend to do on something like this, is to round the dges, then if I'm using 1/4" lace. I will mark the holes a wee bit closer than 1/4" apart...just a wee bit. then you will have no problems with a gap. You also want to use short pieces of lace and splice the seam, use pieces of lace no longer than an arms length, this will reduce the "lace wear" as your are pulling it through each hole so many times. Hope this helps. Ken -
	Okay, now we want to trim the excess liner from the vest. Be sure to let all the seams dry and bond for about an hour before doing this. If when cutting the liner extra away, the seam comes apart a bit, just apply some glue to the area that's come apart and re-roll the seam. Using scissors, hold the liner between your fingers and gently pull it away from the shell and cut the excess liner away. Follow along the entire edge. When you get to the are that is where the lace seam is at the top of the back, you may have to cut a bit of the suede folded piece away, just before where the lace seam starts. You want at least a 1/2" wide space all the way around the vest. The same with the front vest panels as the back. Trim all the ecxess away. Also look on the shoulder piece and trim any overhang away from there as well. Here you have the liner fully glued and trimmed in place.
	Starting at the top of the back, where your reference marks are where the back lace is, mark on the shell 1/2" from the edge of the shell. If you like you can do this before hand, and mark all the way around the shell, as you are going to need this as we glue the liner in. The reason I'm just showing you this much, is because we only want to glue so much at a time. Apply a 1/2" wide bead of glue to the first section that goes under the arm. DO NOT apply glue to the nylon mesh. Now gently, and without stretching, lay the mesh down and press it down with a flat hand. Then take your roller and roll this seam REAL good. We want the glue to soak into the nylon. Then carry on and apply glue to the side section of the shell, press down and roll as before. Now do the same thing on the other side of the shell, just till you reach the end of the underarm section. Once you've reached this point, fold the mesh ober and out of the way as shown in this picture. Apply a bead of glue for about 6 inches or so, then with a flat hand gently lay the mesh down so that it sits nice and flat, roll this seam. Now with the last section folded back again, apply glue to the remaining section, lay down and roll the seam. You've most likely noticed that the liner is a bit bigger than what is needed and are probably asking yourself, "Why not make the liner the right size to start with?" Well, it's simple, if you did make the liner the right size, there is NO ROOM for any errors. Leather tends to stretch a bit whether we want it to or not. This is the best way to do this and you have no worries about the liner not fitting the way it's supposed too. Carry on glueing the front of the liner in the same way we have done for the nylon mesh back. Work your way around from the shoulder piece till you reach the "V" at the bottom front. When you get here, fold the "V" back out of the way, apply your glue, and press down. Remember what I was saying about "Press the Air out?" you will notice it here when you are placing the front liner down. When you are pressing the liner down around where the front pockets are, you will want to sort of press the air out of the pockets, so the liner lays at the best possible place it can. If you didn't do this, the liner is going to be smaller that it supposed to be, and will make the front of the vest curl at the edges.
	Starting on the top of the neck, apply a bead of glue about 1/4" wide, you can be wider if you want, but 1/4" will do. Apply this bead from one reference mark all the way to the other. Now on the liner, apply a bead to the same marked off section as the shell. Align the "Centre" marks up with each other and gently press together. Now carefully lay each side of the neck liner down, making sure that when you do this you are not stretching or pulling the liner. Align the marks and press down. Be sure to roll this seam with your roller to make a good bond. Now, apply a bead of glue to the area where the nylon meets the suede, up to the reference mark you have on the shoulder piece. You want to be a bit liberal with the glue right where the laced seam is, put a bit of glue on the back of the lace as well. Also run a bead of glue on the liner. Gently align the liner with the reference mark on the shell, and lay this piece in place. Using your hand in a "flat on table" way, gently press the air out of this area (you'll get what I mean by that when you do this). Roll the seam good.
	Thanks all for the compliments, I just hope that at you are all learning something from this, and if anyone has questions, feel free to ask, I will answer any and all questions, no secrets here. Okay we are going to tackle about the hardest part now, installing the liner. Lay the vest shell out flat, then lay the liner on top of it so it lays nice and flat, position the liner so that it is lying where it aligns with the shell. Now on the neck section, make some reference marks on the shell and the liner. Be sure to mark the centre of the neck on both pieces, we want to be sure that we glue this in the right place the first time. Mark the place where the top of the seam of the back piece is on the shell. This is an important mark. Place these reference marks on both sides of the shoulder piece. Also mark about 6 inches up from this mark on both the shell and liner.
	I think what to do here is to apply some resist to the area that is not "Mistake" and then re-dye the "mistake area, and have it blend in as a mussle shading, like Drac has said. Then I think the problem will go away. Ken
	Welcome to the forum Ron, great looking sheaths you make, very well done. Is that croc inlay on the first one? Oh yeah, GREAT last name you got there. Ken
	Well in my opinion you've done a great job, very appealing look to it, the colors work well together. Ken
	To weave with lace you want to make your laces 4 times the length of the outer edge of the area to lace.Start at the outside edge, and run your 5 laces through from the back on the 5 outer holes. Glue the tails down and roll. Now on the front, you want to take the bottom 3 laces and lay them to the side for a minute. The last of the top 3 goes into the second hole on the bottom edge. The next lace goes through the next hole on the bottom, and then the lats one through the next hole.The take the second of the bottom 2 laces and run it under the first lace, over the next and under the next, then through the second hole from the edge. The last lace goes over then under, then through the next hole.DO NOT pull these laces tight, just pull them enough that they lay flat to the vest back. If you pull them too tight they will bunch up the vest back and make things go all funny on you. Now flip the vest over, and the 2 laces that are at the top edge, bring them back one hole each and pull them back to the front of the vest. Flip the vest back over, and the first lace on the top pull under then over then under, then through the next hole. The last lace over, under then through the last hole. Thus will give you all 5 laces on the bottom edge, and at the backside of the vest. Flip the vest back over, and with the first lace, go back one hole and pull to the front. Then do the same with each of the next 4 laces until all 5 are back in the front. Continue on until you've reahed the middle of the weave pattern. It's hard to explain with out actulally pointing to this, but when you reach the middle 5 holes, DO NOT go back a hole and pull to the fron, you only do this on the outer edge of the weave. Cut the tails off and glue down as shown here. Now if you flip the vest over and look at the top right of the weave, you will see that there is a stitch missing, the same is with the bottom right. Take 2 of the left over pieces of lace that still have needles on them, and use this to fill the missing stitch. This picture shows you the back view once you've put the 2 stitches in place. Now cut and glue these tails down also. You can make these fairly long to help them from coming loose. In my experience they are never a problem if glued down good. Once done this, take your roller and roll this weave real good to help lay the weave in place. Here's what the weave should look like on the front and back. Now you can continue on to the other side, just remember that you want it a "Mirror" image of this side, so do everything the same but backwards...Here's a picture of the completed weave. There will be a lace that runs along the outer edge of this, once we are finished the vest. So it will not look like it is jusy hanging out there where it shouldn't.
	Okay, as I said before, I want to put a weave pattern on the back of this vest. What we need to do is to make a template so we can not only mark the holes, but also see just what it's going to look like before we punch holes through the back of the vest. Then, once you've made the template, lace one side of it just to get the feel for what it will look like. Better to do this, than to punch all the holes, lace the vest and find out it just does not work right. You will always want to use an "odd" number of laces for this, using an even number makes one edge of it look way diferent than the other and it takes away from the whole look. Once you've decided that it's all going to work okay, then cut the lace out of your template and use it to mark the holes on your vest. Make sure that you have it centred where you want it. Once marked, then punch the holes.
	That's the kind of pop-up I was refering to, just couldn't remember the name type. You do have to be careful on the size of picture that pops up though, it tends to screw up on smaller screen sizes. Ken
	Looks real good busted, just hope the wife don't find out where her yoga pad is going. Ken
	I believe I read somewhere's in the "Braiding" section here on the forum, that you can use a nylon cord (rope) from Home Depot. Check that section of the forum, there is quite a bit on braiding. Ken
	I'd also be leary about sending them back before recieving the new ones. You could be waiting a LONG time for the new ones, as I'm thinking that they may not be selling real Nikon batteries, and your the first to say something about it. Also, as OutBack has said, you can file a dispute with both E-Bay and PayPAl (if you used PayPal) to cnacel the transfer of your funds until this is settled. Ken
	When you attach your "Makers Mark" or "Label" centre and glue it to the front of the liner. Flip the liner over, and with your roller roll the area where it is glued. This will show you where to place a piece of suede to use as bulk for lacing. Cut a piece of suede to fit the area including lace hole and glue it down. Then you can punch holes and lace in your label. Here's the completed liner. Now get a good nights sleep, as tomorrow I think we may have a big job ahead of us. Thanks again for all the compliments, and hope you are all learning as we go.
	We want to use a 1/4" hole spacing on this seam as well, also the thinner lace. Start by making a mark 1/8" past the top of the pocket, then every 1/4" past that. Mark fro one side to the bottom middle, then the other side to the bottom middle. Start lacing the same as you did on the front pockets. Glue down the tail, and also the first loop on the backside. When your reach the bottom middle, glue tha tail down as shown. Here's the completed pocket.
	First off...IGNORE the 2 1/2" demension in this picture. You want to mark where the inside pocket is to be placed. If the person is right handed, then it goes on the inner left side, vice versa if they are left handed. Place your template 2" from the outer edge, and 4 " up from the bottom point. Mark all along the edge but only a small dash at to top corners. Now, just to be on the safe side so you don't get glue on places that it isn't supposed to be, mask off the entire area that we are going to apply the glue too. Then apply glue to this area, and also the outer edges of the pocket. Once you've placed the pocket and rolled the seam, flip the side over and you should see the outline of the pocket in the backside of the suede. Do the same here with the tape and glue as you just did on the front of the pocket. A;so cut some 1/2" strips and apply glue to them as well. You want this glue seam to be 1/2 on and 1/2 off the seam of the pocket. This will give the suede some bulk for the lace. Here's what the backside should look like when done.
	Take the template you have that we used for the liner on the outer pocket. Use this as your template for the inside pocket. You want to lay it out as shown in the picture. Just make a small mark at the top on each side as references. Flip the template over, align with the reference marks, and finish marking the pocket. You should have a piece of suede that looks like this. Now apply a bead of glue all the way around the outer edge. Fold the piece in half, using those 2 reference marks as your guide, press together and roll the seam.
	We are going to make the liner sides now and attach them to the rest of the liner. Using the same template you used to make the front panels of the vest, mark out and cut a left and right side using your suede. When you are marking the "Yolk" at the top, add 1/2" to the piece, as shown in the picture. This is needed to attach the two together. Here's what the piece should look like. Make an opposite one for the other side. Now on the front of the side panel, mask off the 1/2" extra lip and apply glue. On the BACK of the shoulder piece, mask off a 1/2" area and apply glue. Now press the two pieces together, be sure that you have the front panel facing the proper direction. Then roll the seam. Now on the back of the piece we want to add some 1 1/8" strips for added strength. Cut and glue down these strips just as we have in the preceding steps. Now, take some more 1 1/8" strips and apply glue to backside, fold over part way as shown in the picture. Then fold the other half over, roll together for a good bond. Cut hte strip so it follows the "V" of the yolk, and apply glue and press and roll together. This is to add some bulk to the suede for lacing purposes. Mark, punch and lace the same way you did the yolk on the outer shell. It should look like this when done. Then do the same with the opposite side liner.
	Welcome to the forum, those look real good scott, keep up the great work, and thanks for sharing. Ken
