My 1st attempt at a cover for my Bible
bruce johnson replied to Jordan's topic in Books, Journals and Photo Albums
Jordan, The Bible cover turned out great. Ya know, I never looked twice at that cross meander stamp when I see it by itself. Seeing it done gives me a new appreciation for it - good job. Regarding the other cover with the heart on the front. I don't always think outside the box. I am sitting there thinking "OK, what IS that heart stamp?" Then I saw the hourglass meander in the corners and it hit me. Good job. That can't have been real easy to keep lined up, and you pulled it off like champ. Congrats. Looking forward to seeing more. -
Ed, I tried one. It is designed for bookbinding. It will do leather up to maybe 4 oz pretty well. The blades that come with it are sharp, but won't hold up for long, or stand up to leather with more body like latigo. They are designed for bookbinding type leather. Several of the bookbinding websites sell them (or used to). I looked at one that was bought with a set of bookbinding tools and was told to bring it back if it didn't work for me. It was for $150. Sometimes they show up on ebay. What you really need for your leather is something stouter. A handcrank skiver with a rerally sharp blade will do latigo and firmer chrome tan like diamond-tan OK. Not good for soft chap. The Landis or American B (?) both have a smooth top feedwheel, and won't mark leather. The blade has to be sharp and the blade adjusted right or softer leather will bunch up against the blade. The ideal machine is a bell knife skiver. This machine is designed for just what you are expecting one to do. They are a bit pricey - low enders on ebay from $900. I have a used Fortuna. These are kind of like a sewing machine, you have to make friends first, then dance with it. There is a thread on bell knife skivers in I think the sewing machine section. It just depends on how much you need one, and how good it needs to be whether you can justify a hand crank or bell knife. I have both and wouldn't be without either.
I am not home to check, but I recall the Weaver model is pretty pricey. I turned the crank on one, and they are a good machine. The only new ones that I know of. You can probably buy an old Landis or American from one of the reputable dealers in used equipment for about a third the price. Shipping should be the same new or used. Another source might be Pilgrim Shoe. They have a ton of parts and have bench machines listed on their site. Pretty knowledable folks when I have talked to them. As far as being worth the money. I hven't ever seen one sell used, but the old Landis and Americans bring the same or money back when you go to resell them. I would wager you would take a hit on reselling a Weaver you paid new price for.
Use it up, wear it out, make it do or do without!
bruce johnson replied to Johanna's topic in Leatherwork Conversation
Warren, While you are at the print shops, ask them for particle board. I get it at the same place. Once all their workers have a lifetime supply, it is free to haul off. Some of their paper comes in on pallets and the particle board is put on top of the boxes and then the pallet is strapped. The particle board prevents the load strapping from digging into the paper. I use the particle board for cutting on, especially with the roller blade knife. Once it has chipped out and rough, it is yet recycled. It goes to the glueing table or I put it on my oiling/dyeing table. I think I have related that I oil with a paint roller. Any overflow absorbs into the particle board. Once the oil has pretty well saturated the board, then an oil saturated board makes a dandy fire starter. I am sure about three of these will burn a wet mule. -
Larry, I buy them in the 5 blade pack. Shop around and you can find them cheaper at places like Michaels or department stores. They are more costly buying them singly. I never sharpen them. Use them until they don't cut clean and toss them. Mine go a long time. I usually chip one before they dull up. On a tight crner I have snapped off a section sometimes. I think cutting surface plays a part here. I cut on partical board for no other reason than I get it free. I probably go through a blade a month, and use mine a lot. I am not sure how safe I would be resharpening a round blade. I would forsee the bleeding gash in my palm. That makes the disposable description of the blade even cheaper. I don't like cutting on the self healing mats they sell for them. More drag and seems to dull faster.
Thanks for all the replies so far. Keith, by the way, I do ask a lot of questions sometimes, but I figure lay them all out and let it roll. Just a few disjointed ramblings and observations. I am with Keith on thicker leather absorbing wrinkles better. That is how I was originally taught - skive the area where the swell base meets the bars to maybe 9-10 oz and not any thinner. Too thin and the wrinkles don't absorb, they fold over. Still flat, but a rough look. I like low center of the belly right in the middle. Usually the thickness is consistant side to side. I found when I used low neck, one side was thicker. One side always laid right in and the other side wanted to fight. If I am going to fight one, I want to do it on both sides - then just go ahead and welt it. One thing with doing a lot of repairs is that I have cut covers from about everywhere but the butt. I have had some shoulders lay in nicely cut vertically, not every one though. Not enough to make me want to cut them all there either. I also was taught to visualize the excess in thirds. Pull it down and tack so that about one third of the excess is towards the front of the swell and 2/3 to the rear. I have talked to guys who go half and half and welt more than I do. From where I cut the ones that work - that front third is denser so will take up less slack and there is more fudge room over the groundwork to work wrinkles into. Case with warmish water. Seems to work a little better. Working out wrinkles - can o' worms. In the Bruce Cheaney videos he tacks a strip on the side down low where it be covered, and then pivots it around and uses it to beat against working from top to bottom. ("wiping strip"?) I was taught to nail at both ends. Divide the excess in half and put a small nail in the middle. Work that excess in each "bubble" as much as it would compress, then divide that excess in half, tack again in the middle and so on. All the time dividing the bubble rather than chasing it side to side. Jesse Smith taught last year to tie surgical tubing (heavy elastic) in a double wrap around each side of the swell like a big rubber band on each side. Work the slack down under that elastic and it pretty well held it. That has helped some of mine, in conjuction with a few nails. It will sure suck one in tight on the bottom sometimes. I have had some I was about to give up on, came back a couple hours later or next morning, and the temper was just right - one pass of the slicker or tap and that bubble is gone. Some swells just don't lend themselves to unsplit covers. I have found that the thinner forks like the BW and the barrel racers are bears, undercuts and severe leg cuts ditto. JUst plan on welts from the start. The low TM roper swells are cake - no welts. I can usually do the Dee Picketts, Bowmans, Olin Youngs alright. I am with Andy, slick forks are the way to fly. Anybody charge extra to cover or recover swell forks vs. slick forks? Upcharge for welts vs. no welts?
Warren, I routinely cut up to 16 oz with my 45 mm. I use a 48" rule as a straightedge. The blades go quite a while too. Where I think they really shine is cutting soft leather like chap or deer. There is no distortion from stretch like with other knives. I also use the scalloped and wave blades sometimes to cut overlays. They will track a pattern edge well for that too. I used to have a 60 mm, but cut myself a few times on it. Lost it and don't miss the bleeding.
Tiffany, Right about that. Every time I talk to Bob, I come away smarter about new and old tools, and how to take care of them. When you get ready to upgrade edgers, Bob makes some dandy Bisonette edgers. My wife likes them a lot. I prefer another style, but use hers on occasion (especially when she is not looking).
Krains, You can buff off any seams or pits from the plastic mold it was formed in. That said, Osborne makes a real bone folder that I use a fair bit. I just got a wooden one made by Riley Cornelius. They are members here on the forum. It has a nice shape and the edge varies from fairly crisp at the tip to a nice round edge. The variance allows you to use what part you need for the effect you are looking for. Nice tool.
Pete, I vein opposite just "because". LOL. It just makes it look rounded and "cupping" away from me. By just making a light short impression (I use the thin scalloped veiners) on the cupped side, it gives me that illusion. When I do it with the veining the same, it makes it a little more "same old, same old". try both ways and see what gives you the effect you are looking for. I look on veining the same as decorative cuts. You can take exactly the same leaf and totally change the effect of cupping toward you or draping away from the stem by just changing the direction of the veiner or the cuts. My thoughts are that by changing this up within the same piece, can add some dimension of leaves coming toward you and others going away. It can make a pretty flat pattern kind of pop a little. Mix in some front and back leaves, and it will really go somewhere.
Pete, The leaves all look interesting. You are doing fine. On the one you want to have the 3 leaves, and make the front one showing the back. I have done that some. Not much of what I do lends itself to embossing, althought that is a really neat idea. What I do is to tool the back leaves totally opposite of the faced leaves. In other words. On the leaves I show the front of, I usually pear shade the convex scallops, some guys go out to the edge, I still leave a little halo. I vein "tip down" usually, with the veiner blending and flowing into the leafstem, not "cupping". I undershot the concave scallops of the leaf margin. On the back facing leaves I pear shade the concave scallops and do go to the edge. I make my veiners "cup" and not do as "long'' of an impression to give the illusion of roundness. I undercut the convex scallops and then lightly lift them with an undershot. Deeper at the tips and fade from there to each concave scallop. I normally use a lined shader on the front leaves, and smooth veiner for the back to further separate the look.
Changing gears from trees here. Randy's post on the Hamley saddle and his comment about "Someone took a lot of time to form those swells" got me thinking. I had an old guy talk me through it several years ago about covering some swell forks without welts. I took a class from Jesse Smith last year at Wickenburg, and he had some more tricks that have helped. I have still been beaten by some, and then gone ahead and welted them. I really don't have anything against welts. I think mine turn out well enough, but just don't like to do them if I don't have to. I would like this to kind of go in a few directions. What kind of swells can you more consistanly not welt? Particular selection of leather? Skiving or casing tips? Forming and compressing tips? If you do welt, do you use a single welt, folded welt, or blind stitch? Laces instead of a welt? Welts to the front, down the sides, or pulled to the rear? Tips and tricks are always appreciated.
Steve, Bucking roll are an "add-on" for slick fork saddles. The swells (part of the saddle the horn attaches to) in a swell fork saddle sticks out a little on both sides. It serves a couple funstions. It gives you something to kind of lean into when your are standing up and forward leaning out to rope. Some swell patterns allow you to get your legs underneath them to secure if a horse goes to bucking. I look on them as a sefety valve. If I am loose and going forward and my horse stops short, I want something to stop me before the saddle horn does. Human anatomical considerations apply. Swell fork saddles come in a bunch of different styles, but are all characterized by having these "swells" sticking out to the sides a little. Slick fork saddles don't have this. Originally all saddles were slick fork, being that the swells or forks were really made from the forks of tree branches. At some point someone tied a jacket across the front to inhibit his forward movement. In the later 1800s, a guy developed bucking rolls, little add-on pads that went on each side of the fork. A further development was swell forks - originally reported to be a croquet ball sawed in half and each half screwed into the slick fork - adding swells. Then forks were actually made with a swell pattern and no longer carved from tree forks, and the two camps of though divided into what we have today - the swell fork guys and slick fork fans. It used to be more regional. Swell fork most places. The slick forks kept popularity in the great basin and Northwest and areas influenced by them. Now with guys moving around, horse training clinicians riding slick forks and selling them, it is less defined. Bucking rolls were stuffed with hair, wool clippings, some guys use synthetics, etc. though a flap in the bottom. Anything to pack in there and give shape. It takes a while to pack in there, some packing then mashes down in use and they need more stuffing or they get raggy. If these foam inserts work as expected, you just build your rolls around the foam core and you are done. To compare, swell forks are more solid, less forgiving when you smack into them. Bucking rolls are softer, but not as solid to lay into. I am attaching a picture of a moderate swell fork saddle, the one with no bucking rolls. The other is a slickfork with rolls, you can see where they attach, and kind of what they do.
I don't much use Xray film to glue to in an effort to prevent stretch while tooling. I do use it a fair amount for stiffeners for some things. It works well to sandwich between a soft out layer and liner for things like business card cases and checkbooks. Adds stiffness without bulk. Just rough up both sides with coarse sandpaper and cement in place. I mostly use this for exotics without much body or chap leather. Warning - I told one guy about this and he used it in the entire piece. You just want to it to stiffen the sides. Use patches on both sides and leave the fold area open. Otherwise it won't fold. For some padded or plugged inlays, I use it as a backer. Cement the padding and the inlay leather down to the Xray film. Secure it with binder clips, tape, whatever and sew around the inlay. Then I trim the excess film off the back, and then glue in a liner and edge stitch the liner in place. It makes a cleaner look inside than stitching the inlay in place through the liner. -
Most all my cutting patterns are made from printer's press blankets. I get them from a local print shop across the alley. They are used on offset presses. One side is rubberized, and the backing is a durable cloth. The rubber side down doesn't slide around on the leather. Toss a bench anvil or shotbag on it and it stays put. They have enough body to run a knife right along the edge or not move with a tracing stylus. I can write things on a the cloth side with a Sharpie. I can ID what it is, what gusset and zipper length are needed, handle size, etc. I can rivet pieces together for longer things like back cinches. It sews on my machines. I have sewed up trial pieces and mailed it to guys as test patterns. I did a over the saddle horn cordless microphone holder for a mounted rodeo announcer, and it had to be just right. That made life easier. Mock up cell phone patterns are easier, too. They cut with knives or heavy scissors. I originally got the idea from Bill Gomer's video. He made saddle seat patterns from them. I make all my patterns from it. These are not cheap new, over $100 for some sizes I am told. When they start to wear out, they toss them. My guys clean them with solvent before they give them to me. Every so often I find a stack of them in the back of my truck at work. They also work for drawer and tool box liners. -
Old Hamely Saddle
bruce johnson replied to Randy Cornelius's topic in Saddle Identification, Restoration & Repair
Randy, I have an old Hamley catalog reprint along with shreds of a real one, and saddle E203 is the Daisy Mae, as Ronny said. The picture they show in the catalog has a 12 or 13 petal flower used. I am sure they could have used whatever flower a customer wanted. They also show other saddle models with 7 petaled flowers in that pattern, and a five petal with the squarish tips. That "daisy basket" pattern was pretty commonly used back then by several makers. I would suspect from the numbering that it is an old McMillen stamp too. The border stamp sure likes a commonly used McMillen pattern (want to say a #328). I have a couple old stamps that were reported to be McMillens and matched up to catalog impressions, but no numbers. Not sure if any McMillen stamps were ever numbered themselves. Regarding the "triangle" tree. At least in the 1942 reprint, Hamley's still had their own tree shop. Someone with more knowledge than me knows, but I am recalling that Duff Severe went to work for the saddle shop and his brother went to work in the tree shop after the war. The catalog shows the E203 as being built on the Improved Association tree. But they have a saddle model called the New "Triangle". It was model #580X. The Firefly, was model F616 and was built on the "regular triangle tree". These trees both had the fork of the low form-fitter with a 14" swell. The difference between these two "triangle" models was the cantle dish and slope. The picture of yours looks to me all in the world like their Association. The triangle saddles pictured have the typical undercut swells and backsweep of their form-fitter swells, and welted swell covers. Some of the improved Assoc models they show were welted, and some weren't. It would take someone better than me to do a swell cover on a form-fitter and not welt it. Doesn't look like yours is welted. I'll bet you breakfast yours is an Improved Association tree. -
Old Hamely Saddle
Randy, Call up Hamley's. They have the records. Not sure if they still do, but they used to have a place on the website to look a saddle up by the numbers. Last year I bought a Hamley association saddle hull from "fleabitpokey" on the forum here. When she brought it down to me, she had done the homework. They had sent her a copy of the original order form, the receipt when done, and a certificate of authenticity. It was from the late 20s. Pretty cool. Eventually I am going to retore it for the museum display. We don't have one from Hamley's on display. Yeah, the trees in some of these old ones are good. The one in my Hamley looks good, as does my great-grandfather's Duhamel saddle, and an old Porter I have. I am restoring an old Rowell right now that doesn't have half as good a tree as any of those. -
Tracy, We are starting to sell them in our local cowboy museum (www.oakdalecowboymuseum.org). I had to pay retail to support the cause, but you can't wholesale outfit your wife all the time. The info on the jewelry is at www.saddlebaroncollection.com.
This is sort of in the spirit of leatherwork. I am thinking that most leatherworker's wives wouldn't mind a set of these for her Valentine's Day. I mean you can only make so many purses, right? She already got one of Ryan Cope's wife's saddle blankets for Christmas. Keep a secret, you are seeing them before her. I am thinking this will be a bigger hit than the clicker dies I got her a couple years ago.
Art, Something like $12.95 per set in low number quantities, $7.00 for the pattern pack. He is going to make a DVD to show how also. I ordered a couple sets Monday, and should have them today. I'll let you know.
Janet, It looks to me to be pigskin or an embossed pig pattern on cowhide. Some of the places that stock topgrain pig in colors for garments could help you out. Not sure what TLF carries, but places like HideHouse could be a source too.
Harvey, Clay is right. Probably better check with David and see if you are still on the list. You may be moved to platitudes unbound.
Andrew, To jump in here on the Alder, I used to have a 205. It is a good machine and I am sure would sew with bullet holes after a nuclear holocaust. That said it had no needle guide or center foot, and the feed dog hole was a fairly small target for a needle capable of sewing 346 to hit. It would sew doubled 9 oz latigo reins all day. It would sew new saddle skirts and normal back cinches all day. I made the mistake of building some wide calf roping back cinches based on an old style I used. I used doubled skirting for the bodies, and 10/11 oz for the tunnel loops. The ropers loved them because they are dang sure stout. The top side stitches looked fine. The bottom stitches due to needle deflection wiggled all over and missed the bottom groove in random patterns when it hit the 3 layers. If the needle missed the feeddog hole and snapped, it was pretty impressive. Tended to skip on some relining of skirts due to needles holes not quite matchining up in the skirts/plugs. Needle deflection was an issue with it. When I got my Pro 2000, the bottom stitches match the top, and I don't even think about it. The 205 is now side seaming boots in Oregon. I think 3/4" would be a real generous allowance for the Adler I had. I know a guy who had a Sewmo 205-370 clone, and that was his experience too. Good up to 1/2" and then it is a push.
My granite actually does have the guy's picture photo etched on it, and the dates. They broke a corner when they reset it. It is kind of eerie to see him smiling there, and I pound on the bottom side (smooth, but unpolished and will stay that way). Another source for granite I recently found was the local Habitat for Humanity outlet. Contractors donate leftovers and scratch and dent stuff. Basically a thrift store for building materials, and they have several pieces of granite countertop. It was around $3 a square foot as I recall.
N PORTER TROPHY SADDLE
bruce johnson replied to broncobuster's topic in Saddle Identification, Restoration & Repair
Bronc, Most of what I have on Newton Porter is at home. Originally the shop was in Texas. Moved to Phoenix where most of the reputation was built. A pretty famous old shop, and some refer to the style of carving they did as the "Porter" style, others call it Arizona style. A lot of the big names in leather carving from the middle part of the last century cut leather at Porters. I am not sure when the shop closed. I have an old geometric stamped Porter saddle that while cute, is not high end collectible. Porters were pretty fanatical about maker's marking their saddles. It is marked in 5 places. I also have an unmarked floral stamped saddle can be matched to one of Porter's standards too. Probably an ex-employee made it. The geometric was appraised at about $1100-1200, which I thought was pretty generous. The unmarked floral saddle the same or a bit more due to the silver on it, which is older than the saddle. Those old quilted saddles were before my time. I am not sure of the whole time frame, but have seen them listed in old Western Horseman ads from the early or mid 60s. Not sure the seat repair helped the value any.
