You will like it...
Barry King. I bent and broke several Tandy and Hidecrafter ones from doing tipped impressions. I had Barry maker me a couple as customs a few years ago and now he catalogs them. Haven't had a problem with them. I do have a CLT that is beveled and really detailed, but I have the only one I have run across in 5 years. CLT is not in business anymore.
Brent, I will take them all. How would you like paid? You can call me also. toll free number on website through the link below my name. Thanks, - Bruce
- 2 replies
- draw gauge
- cantle pincers
- (and 5 more)
Hide House in Napa, Maverick Leather in Petaluma, Goliger Leather in Santa Barbara.
- 4 replies
- california
- leather supplier
(and 2 more)
Thinking Of Purchasing A Used Adler 205-64...thoughts?
bruce johnson replied to fitabull's topic in Sewing Leather
I had one, heck of nice machine and in the same circumstances would buy it again. -
Unless they have changed, the one I ordered was made by Barry King.
Nail Cups You Say.....why Here Are Some Nail Cups
bruce johnson replied to Rossr's topic in Leather Tools
Ingrid, They are a leather shop item and common in shoe shops. They are a heavy cast iron carousel that holds nails, tacks, and shoe pegs. -
Nice find. Usually the antique people are the ones painting them all colors and using them for candy and nut dishes,. My favorite is seeing them tagged as "cast iron muffin/cornbread pan with cooling stand - $175". -
can you post a picture of them?
Its A Mystery .....at Least To Me...or What The Heck Is This Tool?
Stapler . and I have never seen one WITH staples. The old guys tell me they were used to staple bows and decorations on shoes, and other say that some styles of buttons were stapled on too. -
I missed this thread earlier. I have made these from large round and layer single line creasers that have been worn on the creasing leg. I have done a few other things with old creasers too. I have a few out right now for feedback that have a beadline in the edge and a bevel to the inside of the bead.
They are indeed made personally and individually by Wayne Jueschke outside Elko, NV. He is a one man shop and a heck of a good guy. They are not stainless and I believe are made from "stress proof" steel but not 100% sure on that. His stamps are crisp and detailed - my favorite geometrics and flower centers. One of my friends did production work with Wayne's early stamps designs and you could pass them off as new condition stamps today.
Ray, I will buy that. PM sent.
Regarding the black surface. One of the restoration sites they mention this - and it may be in the fine print on the chelating solution directions too. This is carbon from the original steel that rusted. A fine abrasive or compound on a soft wheel will take that off.
Just another of the Metal Rescue and Evaporust tips. They will get into areas you cannot by any mechanical means. You will notice on the label that it says works better over 65 degrees. True enough, and the warmer the faster the chelation reaction. I talked to one of the celebrity endorsers of one of these products. His tip under condition of anonymity. You can heat these and turn 12 hours into less than 12 minutes. I do this for small parts like bolts and hardware. Put them in an aluminum pan, heat to "hot enough to stick a finger in but too hot to leave it there". Simmer for as long as it takes, a couple rinses of water, and you're good. You will lose some solution to evaporation but there is the time saving element. Strain the solution through a paper towel back into the container and you're ready for next time.
Hanson's silver has them.
This slaughter-free vegtan leather was only offered by Siegels. Steve Siegel downsized his business not long after, and now seems to be concentrating on higher end book binding leather. This doesn't mean country hides went away, they just aren't marketed as such.
Some contact cements are heat activated, Barge is the one most think of but others are too. They can dry and then you apply heat to tack the cement back up. I use a paint stripping gun. A few places that this is helpful. Cement won't stick very well to wet leather. You can apply cement to dry leather and let it set. Dip or soak the piece and when it is right, hit it with some heat and stick it. Good for ground seat build-ups in saddles. It also helps if you are batching up stuff. You can apply the cement to everything at a whack, then come back and heat-n-stick.
Can You Spot Real Rolled Leatherwork?
bruce johnson replied to unicornleather's topic in Leatherwork Conversation
Here's a link to my web page that has the tutorials. Interestingly enough, rein rounders are at the top of the page - http://brucejohnsonleather.com/tutorials/ -
Normally when they twist to one side then a few things can be happening. There should be a way to adjust the distance between the bottom roller and the blade and level the blade vs. the feed roller. On the US made ones there is a stud that goes into the two bottom roller bushing blocks with two jam nuts that can be tightened or loosened to adjust each side. The other thing that twists the piece from one side to the other is pressure. Again, on the US made ones there are heavy compression springs that pressure the bottom roller. If one side has more pressure than the other that can affect feeding. Sometimes you have to back the pressure all the way off then tighten each side a bit at a time to keep it even.
To back up here and update my previous post from August - You can now print postage from home for the small flat rate Priority Mail boxes again. Not beimng able to do that lasted about a week. The word I got it was that they realized it was either a glitch in the website update or the complaints were huge and they had to bring it back. Either way - good to go again.
Dan, I sent you an email. Have one. - Bruce
They are not real common in that large but I get them every so often. I just sold one this morning heading to Australia. I will check to see if any I haven't got to yet in the shop are that big.
Obvious to me that this is a different animal. It is a crankstyle and not common to the US. I would try to see if you can find somebody with one over there or Europe and see if the blade bevel is correct. That blade may well need to be that way by design. Changing to a single bevel may change the edge position. This particular splitter may need that double bevel to clear the bottom roller when it is up against the stops (where the corners have chipped out). Those corners can chip out on US crank splitters too. If you allow the blade to sit back from the stops the distance of the chip, they will work without sacrificing good blade in the center.
Thanks Camano for providing that link. I do have a few half round pinking punches availalbe right now. That page link is here - http://brucejohnsonleather.com/leather-tools-sale/leather-scalloping-and-pinking-punches-sale/ .
