Here is a picture of my current Patent Leather Countersink for recessing stitching or running a sharp crease line.
Saddlers Bench/ Stitching Horse
bruce johnson replied to Old Coach Saddlery's topic in Leather Tools
Good looking narrowed up jaws on that. Looks like it'd be nice work on. -
I'll get a picture of mine tonight and post it here.
Great work yet again!
To make slots in the tree I used a rotary cutting bit on a Dremel. I remove the rawhide between the holes to let in the strings so there isn't a lump and then revarnish to help seal them.
I like how Big Sioux Saddlery did the folded leather and did a lot of repairs that way too. That makes a nice smooth look and is stout. I am attaching pics of one of my own saddles. I put a tab on the front for the breast collar dee and another tab coming up off the back for the cross-over rope strap buckle. The right side just has the front breast collar dee tab. I just like how the breast collar hangs on this horse mounted up higher. I used really good latigo and did my bleeds down tight. The strings are through the tree but not the skirts. I put slots in the tree to run them through instead of drilling round holes and that left enough wood to feel good about screws and nails having a solid bite. I also attached a picture of a tab on a leather concho. This is a saddle I did without strings so there is plenty of wood to screw into. I did a screw above and below the concho screw so they wouldn't be in a horizontal line and chance splitting the grain in the tree. I did more of these on cowboying saddles than arena saddles.
So maybe Craftsman tools aren't what they used to be either, but you can hand a damaged one to anybody in the Sears hardware dept. and they'll give you a new one on the spot. They don't wait to see what happens when they send it back to the maker. I guess I'd expect any seller of a "name" tool to do the same and then they can deal with the manufacturer. You can look at a punch with a rolled end and tell if a guy tried to pry open a can of paint with it or the thing wasn't up to snuff to begin with. An old man told me once, "A cat that breaks a leg catching a mouse probably wasn't much of a cat to begin with". Seems appropriate here. As far as creasers and edgers, no need for repetition so I'll defer to my friend in South Dakota. Let's just say Osborne must have lost the old tried and true patterns somewhere along the way.
Paul. Problem is that you are also rubbing abrasive against the cutting edge and will dull the edge or roll a burr back up the edge.. Roll your edge on a strop to do the outside or chuck it up and hold your strop against it on a lower speed drill press. Inside you can use a narrow strip of leather rubbed with compound. Push it through from the top of hole and rub it around the inside edge as you tension it and slowly pull it through. This will pull the burr away from the edge and rub it off leaving a clear edge.
- 3 replies
- sharpening
- round punches
(and 1 more)
What about using an overstitch wheel? The other option is a Patent Leather Countersink. This is an old line tool designed for just what you are talking about. It is a handled push tool with a raised center ridge. You push it along and the ridge depresses the stitch line while the shoulders of the ridge while slick the cut edges of the groover. They are rare to find but easy to repurpose from a more common tool like a creaser. Handy thing to have.
Blanchard Of Paris Plough Gauge: Advice Needed
bruce johnson replied to Medi1979's topic in Leather Tools
He is trying to use a Dixon type blade with one slot in a Blanchard which likely uses a 2 slot blade. Most of the Blanchard frames I get have a screw on the back edge of the blade slot that catches the rear slot on the blade. The front slot catches a little nib further forward in the slot. Interesting plough gauge. Besides being very pretty, it looks to only be marked in inches. Most I get are marked in centimeters with the occasional one dual marked in cm and inches. If you run into a snag and just can't get a Blanchard blade, I have a drawer of them here. -
Dixon Slim Line Pricking Iron. Few Questions
bruce johnson replied to mrtreat32's topic in Leather Tools
Kevin, The descendent is Chris Williamson. He is a nice guy. I had posted a picture somewhere of an old Dixon plough gauge I have. He emailed me for better pictures so he could show his grandmother. Kind of neat. . -
Fixing The Backside Of My Machine Stitch...
bruce johnson replied to Reds Leather's topic in How Do I Do That?
The overstitch wheel is used after sewing to clean up the backside stitches. Yes, you need to have the size wheel that will match your stitch length. If you have good wheels with good points they will follow the stitch line even if it wanders a bit. The problem I see is that most of the modern made overstitchers have gotten so poor that the points are shallow and blunt even on the 5/6/7 common sizes. They will not press into the hole or round over the stitch. I have attached a picture of a pretty good old #7 wheel. It'll still do the job 100 years later. -
Overstitchers can sure help clean up the appearance of stitches on the backside. Here's an oldie but a goodie example I have of the backside of two stitchlines. The one on the left is as came out of the machine, The line in the right was rolled with an appropriate sized overstitch wheel. -
What Is This 'braid' Detail And How Is It Done?
bruce johnson replied to linstone's topic in How Do I Do That?
It looks like a continuous two strap bleed knot/slit braid. The two straps are riveted through each other and the collar at each end. Basically you cut a slit or hole on one strap, feed the tag end of other strap down through and pull snug. Cut a slit or hole in the second strap, feed the tag end from the first up through and pull snug. Hole or slit in the first strap again, down through, and keep on slitting and pulling until you get the length you need. A light tapping with a smooth faced hammer will help to smooth and set the braid once you are done. -
Please let me know when they will be for sale. There are several I am interested in.
Tor, The Newark stamp will make yours an oldie for sure. I have had some of the round handles that had a rosewood looking handle and some with a hardwood handle. Most of the older ones were pretty tight. The varnish is still pretty shiny on this one, so it may just have been never handled much. I got one a while back with a similar handle finish and it had the receipts for some of the tools all from the 1950s. A little spit and rub on the maker marking will help date it. One of my friends likes the blades that flex. Whenever I get a few together I send them over to him.
Pictures aren't showing up, but consider it sold
The steel ferrule and handle material look more recent to me. Hard to pinpoint a timeframe for me on that one. Sloppy fit? That tells me recent. My impression on some of these is that the blade material tended to be thinner and maybe a little softer. Some blades will actually flex a bit.
Osborne made round handle knives. They have historically been priced less than the oval handle knives.
Bidding On Ebay For Leather Stamping Tools
bruce johnson replied to WyomingSlick's topic in Leather Tools
WyomingSlick, The history on these pictured is that they were owned by the late saddlemaker, Wade Warren. A few years ago his family had contacted the Cowboy Museum about donating his tools. I went up and saw the tools and what they had. He lost most of his tools in the fire when Visalia Stock Saddle Co was in Sacramento and these are what they had with no background other than "This was Uncle Wade's stuff". They had some catalogs and receipts, only these stamps and striking stick, stitching horse, and a saddle - a Visalia "Warren Roper". One receipt was from MacPhersons and had stamps listed on it. That is the first I had seen these frosted stamps. One guy I asked at the time said it looked like a Parkerized finish. I am not sure on that. Just recently they donated everything to the museum, but I have not had the chance to go in and look at them again yet. If the paper is there, I will especially be interested in that. Since then I have bought two sets of tools that had some of these stamps. One set had about a dozen frosted along with other stamps (McMillen looking and several Ray Hackbarth). The other set I got a couple months ago. It was a little wood box with two drawers and hinged top lid. The top had some modelers and misc stuff. One drawer had maybe 20 stamps - a couple McMillen looking, preletter CTs, and 4 of the frosted ones that had taken on a green color to the coating. The other drawer had 14 no mark nice stamps with a hand written note "Stamps from Frank". One guy who worked the AZ shops told me they sure looked like Eberle stamps. That is as close to provenance for Eberle stamps I have come - having a note that said "Frank" on it. Now the interesting rub. When Visalia burned and closed, Wade Warren moved up to Grass Valley. Other western tradesmen were there. There was and still is some silver and leatherwork done through that area. The first set of the frosted stamps I bought came from an antique dealer in Nevada City, the other side of the mountain and a 3 minute drive from Grass Valley. The last set I bought came from a guy in Grass Valley who got them at a yard sale. It is interesting that all I have seen came from one close geographical area. I don't think it means much other than they all were probably buying from the same source. If you remove the coating, the metal is a bit different than other stamps. It is a softer finish and sort of matte like polished aluminum. Stamps are definitely steel but just have that look. -
I checked some here and all were right at 8-1/2" long and diameter varied slightly between 1/2" to a scant 9/16".
Frosted like these? I have had several. No markings on any of them. These I know the history of and they are from a maker who bought them in the early to mid 60s. -
WyomingSlick, Those did clean up nice! I had guessed there were 10 Hackbarth stamps at the time in that set, so I was close. Thanks for the follow up on them. Now to add a little more. I guess I made you pay on that earlier set from the Midwest too. The far left side front row stamp is a Hackbarth. The two just inside it are suspicious, I am 50/50 the cam is. The seeder or small center on the far left back row is a bit suspicious too. If you don't mind saying, what was the breakdown of makers there? I had a bigger scheduled bid there too and that was when the big set of mixed tools got offered to me. Two days later the other stamps and knives were closing on the Tucson set and I get an estate deal. We both had a hell of a couple days! -
Good work yet again Bret, Sure like what I have from you.
I will take them all for that. Please let me know how you'd like paid.
