Larry Mahan Saddle Information
bruce johnson replied to kdpearson's topic in Saddle Identification, Restoration & Repair
I am not sure who made the saddles. I would sure suspect it was a factory who put his name on it. In the mid 70s Larry Mahan was a pretty savvy marketer with his name on a lot of things - hats, boots, clothes, etc. Kind of the "new fashion look" of the wild shirts, woven coarse jute straw hats, and fuzzy felt hats. The broken Ralide tree fits with that time frame too. Seems like the ones just sitting have about a 20-25 year lifespan before they just breakdown and crack. Ralide might be able to hook you up with a replacement tree. -
What sort of sander do you use for edge sanding
bruce johnson replied to UKRay's topic in How Do I Do That?
Ray, I wouldn't be without two - benchtop and Dremel. I like the benchtop belt sander with a 4x36 belt. I have it mounted backwards so the free part of the belt extends over the front of my bench. I can get down into the inside curves that way. It is pretty forgiving on trueing up edges and mild shaping. Because it is a lower speed and the belt is moving more, it doesn't heat up and scorch like a Dremel will. The top is good for trueing up flat edges like a the edges of my frames. I use the Dremel some too for tighter areas. You just have to be careful to use a light touch and keep it moving to prevent scorching. -
In need of a new shop toy: a good handheld mini-vacuum
bruce johnson replied to esantoro's topic in Leatherwork Conversation
Mine is a ShopVac 1X1. Looks like the WalMart one may have replaced it. -
Make that two votes from this house (I am voting a proxy for Rundi too) for the 1 gal Shop Vac. All the other Shop Vac attachments I have like extension wands and ends will go on them. One of my local sewing machine/vaccum repairman says - "Enough suction that if they had one in the OB, childbirth would be a pleasure, and a lot faster". -
Calf Roping Camp Stool
bruce johnson replied to Double U Leather's topic in Furniture: Inlays and Upholstery
Tough deal about the injury. Hopefully the surgery went well and the rehab and PT go well. On the bright side, he'll have a really cool stool to rest that leg on while he heals. I like it. -
Help with "Chase" style splitting machine
bruce johnson replied to patches's topic in Leather History
Glad it helped. If you get down this way, give us a call first and we'll be sure to be around. -
Looks like a cool one. I don't split anything that is finished size other than straps. Pullling them may distort the shape. Put one end in, lower the top roller and as you pull it should settle down into place. Turn the piece around, lower the roller and pull that end so it is two passes from the middle somewhere going each direction. You can leave a little excess to grab with pliers. With my hand issues in the past sometimes I used a pliers in each hand on wide pieces. -
First off, post a picture so we can see it. I have a few varieties, but here's how mine are set. I set the bottom roller so there is a scant 1/16" between it and the leading edge of the blade. I set the top roller so it is dead center over the top of the bottom roller. The bottom roller adjusts with the 3-4 machine scews in the back of the frame. The top roller adjustment is done with the two stop screws on the front of the posts. If yours has the spring latch, adjust it so the latch catches when it is in position. There are two screws about half way back on either side of the frame. These will raise and lower the position of the bottom roller. It all depends on how much you want to take off. I don't have mine set real deep, but play with them to see what works for you.. (Aside - I bought one from a guy who sold it because he could never get it to split. Ends up those screws had been taken out, and the bottom roller was higher than the blade.) I get better results and longer blade life by taking thinner splits and maybe 2-3 passes than to take skirting to 4 oz in one pass. Some of the older styles don't have a bottom roller, they have a sheet of thin spring steel that sandwiches the leather between it and the top roller. Check to see that the top roller is level with the blade edge. If yours has the two knobs on top with a connecting rod, simple fix. You unscrew the set screw on one handle, slide it off, and twist the other to raise or lower that side until it is level. Slide the other knob back on and tighten it back down. That is about it. I like the fact that with both rollers, the leather has no place to go but into the blade. It won't ride up the bevel and chop off. The blade is protected with the two rollers. Important safety disclaimer. Becareful replacing the blade. A few months ago I was setting the blade back into one and watching the screw holes to line it up. I brushed my fingertip over the edge and the first idea I had that anything was wrong was the blood pooling on the blade. The dime sized piece of finger tip was sitting there on the bottom roller. I have a flat spot on that finger. I use the DMT diamond stones with the folding handles to sharpen mine. I lay the blade on the edge of the bench and and work from the back. I talked to a guy who took off part of a finger by holding a stone from the front and pushing up into the blade. I strop mine on a wheel. -
Breast Cancer Awareness
bruce johnson replied to qarawol's topic in Collars, Cuffs, Leashes and Leads
Excellent idea, and my 2 cents worth. Offer them for $10 and donate $5 for each one, and explain the other $5 goes for materials so you can afford to keep making them and raising money. If somebody can't swing the $10, give them one and bless them for raising awareness. I don't do bracelets, but have done other things. I am attaching a picture of one that is very popular at silent auctions and benefits. It is a plastic case similar to the goat string cans I order. Inside is a mirror and a couple of shelves and I'll get some pics of that. Some carry them as a hardside purse and others as a cosmetic case. You can get them in other colors, but I always keep pink on hand. I order them from Latta Mfg at (800) 232-3967. I order from them because they exhibit at the leather shows and so I try to support them rather than order from someone else. The color has washed out in the picture, but it is bright pink with the pink crystals. This particular design has always brought $150 or more. I have asked Smith Brothers about doing pink rope cans too. Not so far, but I see a demand there. Tough Enough to Wear Pink, -
Other than a couple knives, I'd fill in the set of edgers, I'd get the #2 and #3 in the same style you have. I have never used a stitching punch, but since you have a catalog coming from Bob Douglas, you might consider one of his awls. I haven't used one from Jeff Cook, but you only need to read the awl thread on the forum here to hear about Bob's. To mold with, Barry King makes a nice one. It has a bullet point on one end and a rounded point on the other. Norm Lynds makes a nice wooden burnisher. They are not a necessity, but handy when you have a pile of work to do. I don't see round punches on your list - I like the mini and maxi-punch sets from TLF. Interchangeable tubes. Just chuck them into a drill press and apply a light touch with a stone to sharpen them. You can heat them with a torch and squeeze them with a pliers to make a set of oval punches too. I also don't see overstitch wheels on you list. Again depending on what you are doing - a few might be the best. Probably start with a 6 and 7 for sure, drop down to a 5 later for heavier work or up to an 8 or more for finer as you progress. My wife Rundi took the "Intro to Leather" class in 2006 also. She had fun, and learned a lot.
Josh, Sometimes a guy can find old letters in different fonts from printers. What I use for small letters are ones from Harbor Freight or other industrial suppliers. They are pretty cheap and hold up for leather. Like a lot of HF items, they are over-stated and under-rated for what they are sold for - metal in this case. I think they have them in a few sizes. TLF used to sell a set of small letters too. They still might.
One of my favorite shows is All Around Performance Horse on RFD. They seem like real guys and feature stuff I enjoy watching. Tonight's episode included a visit to the National Ranching Heritage Center in Lubbock Texas. Looks like the museum enjoys plenty of space and has some great displays. One of them is the saddle shop display of Tooter Cannon. He has had some mention here in the past. Here's a link to the main website - National Ranching Heritage Center a link to the Tooter Cannon display - Tooter Cannon saddle shop and another to the history of saddles - A Century of Saddles. This place sure looks like a "don't miss if you get close". I'd appreciate it if anyone visits to take some pictures and post them here.
Ed, I'm with Kevin, when it totally dies get a new one. I used to go through them with some frequency. I had one that lasted about 11 months into the year long warranty. They sent me a replacement. About 10 months later it crapped out. I sent it back and they determined I was a commercial or industrial user and the warranty didn't apply. After I bought the last one with the "disposable mentality", it has lasted about 4 years.
untilThis is for the Elko Leather Show to be held in Elko, NV July 17th-18th. It will be held at the Elko Convention Center. There will be several of the vendors we see at the other shows, plus a few new ones. Leather, silver, tools, machines, and related products will be available. There will be three classes offered. Charlie Liesen will be doing a 2 day braiding class. Al Gould will doing a 2 day carving class and it will doing a project. These classes are $200 each. Joe Benner will be teaching a saddlemaking class that will run 2-1/2 days. The saddle class is $375. For more information or to sign up, email Paula at capriolacowgirl@hotmail.com or telephone her at (775) 738-5816.
This is for the Elko Leather Show to be held in Elko, NV July 17th-18th. It will be held at the Elko Convention Center. There will be several of the vendors we see at the other shows, plus a few new ones. Leather, silver, tools, machines, and related products will be available. There will be three classes offered. Charlie Liesen will be doing a 2 day braiding class. Al Gould will doing a 2 day carving class and it will be doing a project. These classes are $200 each. Joe Benner will be teaching a saddlemaking class that will run 2-1/2 days. The saddle class is $375. For more information or to sign up, email Paula at capriolacowgirl@hotmail.com or telephone her at (775) 738-5816. I was asked to put this in the calendar section also. For those who haven't been to Elko, here's my thumbnail sketch of some of the details. We've stayed at the Best Western, and it was fine. The Red Lion is across the road, and several of the usual interstate motels are there too. Downtown are the Commercial and Stockman's - both historic old style casino-hotels and good breakfast (Basque chorizo and eggs - ). Good Basque food and lots of it - The Star or Bil-toki. The Western Folklife Center is there, very good museum type displays from some greats of our time and the past. A worthwhile visit, and a good group.
A jig is used to set the twist and stretch stirrup leathers and fenders. Some people refer to them as a stirrup leather stretcher. A few guys make them commercially and some guys make up their own. Basically assemble the fenders and leathers, wet them up, put the top of the leather over one bar, the bottom bar goes through where the stirrup bolt would be. You then add tension, usually with a screw mechanism that spreads the two bars. A drawdown is a saddlebuilding stand with some way to pull a seat down tight with a strap over the top. You can again wet the assembled leathers, put them on a saddle tree, turn the stirrups out and run a piece of post through them, and apply tenson to that post. It will set the twist and stretch them. A homemade way to do it is to wet the leathers still on the saddle, turn the stirrups out, and run the post through the stirrups with a bucket hanging between them. Add weight to the bucket - water, an anvil, whatever. Let everything dry under tension.
When I make up a pocket or anything with a gusset, I make registration marks first. I match the front and back and make little hash marks on both especially at the corners. I then will test fit the gusset to one or the other and hold it in place with binder clips. Transfer the hash marks to the edge of the gusset. Remove the gusset, fold the gusset at each hash mark and transfer to the opposite side. Apply the glue and when tacked up, align everything using the hash marks. It sounds more complicated than it is. I have twisted my fair share of pockets and zippered planners and it is because the front and back aren't lined up and the gusset is longer on the face vs. the back. Prepunching holes before fitting makes it harder to my mind. I'd line it all up, glue it and then punch or just go to sewing with an awl.
The boot and shoe guys mix it up various formulas and ratios of waxes and rosin. I have heard it referred to as coad. It helps to lock and seal stitches. It almost approaches doctrine with formulas and types of wax and rosin to use, and then how it is worked. www.thehcc.org has info in the archives. Rosin is available with many rodeo equipment suppliers in black and white rosin, depending on remaining pitch or terpenes or some other chemical I never really undertstood. Roughstock riders use it to tack up gear and gloves. It is almost doctrine with them too about whether black or whote rosin is better. **Big hint** Don't let your girlfriend try to clean out your gearbag. Rosin socks play hell on a load of wash and the machine too.
Can't say for sure on the Elna. However I tried a new Singer 550 at the shop that worked on my 31-20. It sewed some petrified skirting and also 3 layers of chap. They call it a "commercial grade" but there is way more plastic than any commercial machine. It is a machine designed for home use.
I put my Blevins on like the twisted leathers in the picture. Pins in, 180 degree twist or fold, and they point out. I install them opposite for straight leathers - pins out. Otherwise when you go to buckle them on straight leathers the pins point in, and the excess stirrup leather is under the fender leg.
I haven't owned a Rose, but everyone I know who has one wouldn't give them up. If the blade has been neglected and rusted or pitted that is one thing, but if it is good, they are the first grab. I haven't seen any hard dates on when they were made, but the suspicion I heard is the the later 1800s. Here's a link to old makers I find useful - Old tool makers.
Dan, The ones I took apart had smashed fishing sinkers spaced out between the two layers.
