Content Count
211 -
Calendar
Everything posted by needles
clever idea, nice one
- 9 replies
- card punch
- credit card slot
(and 2 more)
is there a chart that shows what size in mm bobbins are, for sizem, g m z ???
Lined Handbag With Webbing Strap
needles replied to Neillo's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
looking good, -
I salvaged mine from the back of an old garage, been in there for years, right under a hole in the roof, completely rusted solid when i got it., works ok now for small runs, change threads and alter the tension it sometimes has a strop on.
i almost completely replaced the parts to my old 29/71 and it is still tempromental at times, only way is to completely replace moving parts and time it.
does anyone know where to find a user manual please thanks Al
picked it up today.. had a quick play and its great, everything i was hoping....... well chuffed, especially as i got it for a fantastic price..... although wasn't an operating manual with it, only parts diagram and list, anyone know where can find one. thanks again
its a mk 5, and i errr bought it..... looked up as much as i could seems right.... collect tomorrow. thanks for your help mate really appreciate it
I've had parts from college, and some have been wrong size to fitting, even though specific for the machine, had to rework and shim them to fit..... otherwise good service and products though Al
thanks, don't have a number I'm afraid, none given........... my staple of work is repairing handbags and satchels etc, ocassionally thicker things, but i hav also have 29k, looking for something to make a little easier
this is up for sale, are they any good....
Has Anyone Tried Metropolitan Leather?
needles replied to Redochre's topic in Leatherwork Conversation
had good leather from metro and also used aacrack when i needed a whole patent leather was good also.... -
how you getting on with your new toy Joe...?
Hi Joe i put a 40mm pulley on the motor at first which really slowed things down, and of course when using a light right foot, but the real difference cam when i swapped my clutch motor with a machine engineer and a small amount of cash for one of his new serrvo units, works a treat now.... good luck, i prayed daily that i would finish the working day with all my digits intact before the servo arrived.... Al
it could be leather spew..... thats where the fat liqours destabalise and start leaking through, can be cleaned with a spew remover abd rstabalised....if it is, they are often quite greasy to the touch, if wiped with a wet cloth often dissappears but will come back again if not ttreated..... just a thought
same as quirtevans, most of mine used to set up sewing machine and test mixed colours on.......
it might be leather spew, which happens when the tallow or fat liqours which are (used to replace the lost leather fats whilst it was worked in the tannery, making it supple again) these can distabalise and rise to the surface, they feel slightly greasy and are difficultto remove and keep down, if it is spew you need to apply a stabalisng solution, then it will be back to normal. thats is of course if it is spew
i saw something similar a while back, its just if i can explain without making it confusing, i'm god at that. confusing that is. if i remember rightly, they used thinner leather on the outer skin, sewed a line, placed either string or a small plastic rod against the sewed line and slightly strecthed the thin leather over the rod, then sewed that down the side. result slightly raised on teh fron almost no bulge on the inner as the outer thinner leather is stretched over rod, and backing is flat. clear as mud........ I think
Knot For Attaching Bonded Nylon Thread To Needle
needles replied to skootx's topic in How Do I Do That?
sometimes I can't or dont use waxed, on these ocassions I use the same method as celtic knot and the other guys above, but i poke the needle through the threads tail not once but about 3 times before pulling it through. this normally holds enough to sew with. -
Automobile Leather Interior With Some Sheen!
needles replied to rortymogman's topic in How Do I Do That?
PM sent al -
Removing Glued-On "bling" From Leather Bridle.
needles replied to Wenny's topic in How Do I Do That?
you know you want some bling....... -
different chemicals often help to soften and remove some glues, acetone often works well for super glue, naptha, hexane, mineral spirits etc, can help to soften some rubber cements its gonna be try it and see, but only put small blobs of the the blob of glue, wait see if it softens. can sometimes take a lon time to soak in....... tial and error I'm afraid especially as the glue in unknown....... -
Small Lady's Bag
needles replied to MonicaJacobson's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
nice.... I like that.... -
tottally agree with dirtclod..... the other part is most people in business will only use their name recommending someone else when they know their service and products are not going to put their own business name at risk........ years to build one minute to wreck.... sort of thing....... show your work and start selling it, your customer base and confidence will build......sometimes it can happen quickly but mostly it.takes time I'm afraid....
i have been working with various chemicals, for cleaning and stripping finishes off leather etc for years, uptill today i have used disposable masks, when i could be bothered.... friday last i spent the second day that week using high vapour chemicals in a very well ventilated room, on friday night through saturday it effected me unlike before, raging head ache felt sick, a little short breath, dizzy irratable, etc etc....... it has now worn off, but has got to be down to not using effective protection. i have today now ordered a proper dust and acid/chemical vapour filtrating mask..... time will tell if any problems present themselves can only just hope it doesn't, but my fault if it does........ next week onwards, any chemicals including glue, its put on the mask......
