Everything posted by BDAZ
I ALWAYS use reversed, toner down so I DO get transfer. Much easier and more accurate than tracing . I usually use 2 pixels so the toner is not visible once tooled. Of course if I want the leather "printed" then I use a robust font. Cya! Bob
- 8 replies
- letter stamps
- align
(and 1 more)
EXACTLY what I was looking for! Thanks! Bob
I think you are asking for trouble. What I use for complex lettering is a laser printer. I layout the text in Photoshop in reverse, print on standard paper then place on the leather and saturate with acetone. I then use my bone creaser to transfer the lettering to the leather. Then I seal and it's good to go. If you are looking to stamp complex text, you WILL, at some point, screw it up and ruin all your work. A name of 5 - 10 characters is fine, I use a 2 ton arbor press. The Tandy letters are self aligning and I use a triangle to make sure the alignment is ok. Cya! Bob
- 8 replies
- letter stamps
- align
(and 1 more)
Sewing Between 1 And 2 Layers Of 5 Oz - Cowboy 3200 Best Way?
BDAZ replied to BDAZ's topic in Sewing Leather
The problem was transitioning from 1 to 2 layers without a major reconfiguration of the tension and all is now working fine. Thanks! Bob -
I found a 100 foot reel of 4mm copper ground wire from my amateur radio daze and wonder what the best way to turn it into rivets? Are there any off the shelf tools to create a flat head? I am trying to save time and money... Thanks! Bob
I was in Winter Park last Thursday..great Sushi bar there.. Enjoy but make sure you have a well funded bank account... It can be a long slippery slope! Cya! Bob
Like dissolves like, so resolene being a water based acrylic will tend to dissolve any of the water based dyes you have used. Use a solvent based sealer on water based dyes. Cya! Bob
Funny, I'm also in Durham for a few weeks for some music gigs..played SUNY Syracuse in a former life. I have met a couplel of the local leather workers at craft shows but I think the right shop in he right place would go gangbusters! Old Time Jam session, good coffee, leather making for kids...kewl! What part of Durham? I'm North off Roxboro. Cya! Bob
After comparing the ingredients of mop & Glo and Resolene, it appears Mop & Glo has a much higher percntage of Acrylic polymers but it also contains a high percentage of Diethylene glycol monoethyl ethers, which is a solvent and used for the cleaning side of the product. I am not sure what affect it would have on undyed leather but would probably affect any oil or alcohol stains applied. Cya! Bob
Where are you located. That's critical as to what sells and what you can charge and how much passing trade. If you purchase inventory, then you can increase your margins to 35% and set up terms like 30 days to pay. You may also look at sposoring a local music session after hours which will attract customers for straps, etc. Sounds like fun challenging and don't forget to have a really professional website. Cya! Bob
Magazine Carriers
BDAZ replied to cleanview's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I take my forms, sand and then rub with paraffin wax, then run a heat gun so the wax soaks into the wood. Both prevents water absorption, possibly promotes faster drying and also make removals easier. Last I install a screw in eye to allow easy removal and a hanging point for the drying rack. Cya! -
Contact Cement Timing
BDAZ replied to ejcrist's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
BTW I only use headliner for gluing sued lining and Barge for all other gluing except for a few special jobs using water based cements. 73 W2PN -
I use the headliner spray glue available from most automotive stores. It's expensive but easy to use and I have had no glue failures to date. Cya! Bob -
Some contacts recommend bonding while both surfaces are still tacky while others, as Dwight mentions recommend dry. I did a repair yesterday with Weldwood which said dry to a glazed finish Not less than 15 minutes and not more than an hour. I use an automotive spray adhesive for gluing linings and they recommend tacky on both surfaces, Cya! Bob -
How Do I Hand Cut The End Of A Bridle Point Or Strap
BDAZ replied to yankeeinoz's topic in How Do I Do That?
Dakota, I use the same flexible cutting boars made out of thin polypropylene. One suggestion is to wipe them down with acetone or MEK to remove the mold release which makes it less slippery. In addition, I write all relevant information on the pattern plus a center line with alignment holes. Cya! Bob -
Depends on what cement you are using... Cya! Bob -
I am not at home or I'd test it first but if wet forming isn't sufficient, try "pasting" the flesh side with a standard water based wood glue. It is a service offered by some leaher suppliers. Cya! Bob
Thanks! Bought a small bottle of Weldwood at Home Depot and repairs completed. Thanks! Bob
Rivet Setting Press/foot Press/die Press- Help Please!
BDAZ replied to Julesinnola's topic in Leather Tools
Michael, that press is made to fit metric grommets, snaps, rivets, etc. You need to buy all this hardware from them (or many other online sources for he same press and dies). I already have thousands of SAE (non-metric) pieces of hardware )mostly Ohio Travel Bag) so I passed even with the very attractive pricing. I purchased this press some time ago and the above is INCORRECT! I use it exclusively for setting snaps and it works perfectly with BOTH Tandy's and the ones supplied by the distributor. The problem with the net is peoples opinions are not verified and turn into "Facts" Buy this press for any US made snaps. Cya! Bob -
This is the one I purchased recently: https://goldstartool.com/Grommet_-and-_Snap_Press_Machine_-_One_Set_Of_Dies_-snaps-_buttons-_rivets.html All other international orders: Please send an email with SKU number(s), quantity needed and your exact shipping address to shipping@goldstartool.com and we will create a paypal invoice with your total. Shipping costs to overseas locations is determined strictly by weight, not the quantity of items ordered. Cya! Bob
I use mine exclusively for snaps and the dies work well with Tandy snaps or their own which I bought with the machine. Cya! Bob
Get a 2 ton or 3 ton Arbor Press. The additional pressure, and especially the extra working space over the 1/2 ton is a pleasure, making it faster to use and easier to line up stamps. You will need a steel plate to cover the die. I use a piece of granite as the base. Cya! Bob
I have a similar one, recommended on the forum which cost $59 with one die set and extras were reasonable. I am veryy happy with it. Cya! Bob
I am traveling on the east coast and 2500 miles from my Barge cement glue pot. My girlfriend's expensive boots has had the glue fail on both soles and I am wondering what the best off the shelf glue would be best. I want to use a contact cement and don't want to risk any adhesive oozing around the edge. I will probably purchase Weldwood contact if no one has a better suggestion. I could drive to Tandy but it is a bit far from where i am staying. Thanks! Bob
Not sure what pat of the world you are in. I'm currently in North Carolina and we have two sessions a week, same as Tucson, where I host one. I also play old time banjo and lots of jams here and Tucson as well. I shot this a couple of years ago. https://www.youtube.com/watch?v=xUMc8WIht4w Cya! Bob
