carver
Everything posted by carver
I strop constantly seems like on every cut . I have 8 different head and round knives most take a great edge just won’t hold it like this Leather wrangler swivel knife . I have probably used it for 40 plus hours of actual cutting and it is still sharp ... ( this is my full time job ) . looking for a round knife like that .
Looking for a new round knife something around 4 inches any recommendations ? I have I stolman not impressed a gomph and and an Osborne that are my main knives but looking for something that holds an edge longer . have an old rose but the blade is 5.5 inches just too big . do use it for skiving . All take a great edge but the stolman . just don’t hold them as long as I would like . Bought a leather wrangler swivel knife and it holds and edge for ever and got me to thinking there had to be better round knives . Any recommendations?
Weavers sell a pour on product to harden soft leather like belly . I haven't used it but have seen it in their catalog . Maybe give them a call and talk about it there is usually somebody around who can give accurate answers . Hot water will make it stiffer on a temporary basis but if it isn't immobilized it will eventually become limber . I have done that on some holsters . I was told by an old timer to dip it in boiling water but have been afraid to try that . But he insisted it wouldn't hurt the leather . I tried drying a piece of scrap in the oven at 300 degrees and it burnt the leather and caused it crack . I only left it in about 5 minutes .I have sandwiched kydex between layers of leather to stiffen up notebooks I made and it worked much better than the traditionally used cardboard .
I have used the Tandy pro dye and fiebing on suede saddle seats it didn't really rub off but it does make the leather stiff . Was trying to dye a yellow seat black best I could get was dark gray which it looked nice that way saddle was black . It just didn't have a feel customer was happy though . Actually that's why I came on here too see if their were any better alternatives for dying a saddle seat . I will give angelus a call
Lambskin Dog Collar - Question On Finishing Seams And Lining
carver replied to lightingale's topic in Sewing Leather
My Toro very rarely will miss the holes in reverse so you should be safe . the trick is not to flip the reverse lever until you are on the up stroke about 1/4 inch from bottom position of needle if your really worried about it just flip the lever to reverse and run the wheel by hand . you can adjust where the needle is going that way . also make sure you are picking the foot up so the leather is free to maneuver and not mark up the surface of the leather . on that thin of leather I will make the edge a folded over seam so their is no edge to need finishing or another way to explain it make your bottom layer look like the top layer without the core. like where you folde it over at the hardware I dont know how far your sew line is set in but if you have enough room you may be able to slide a thin piece of plastic or even card board between the 2 layer and use a round knife or sharp knife to clean up your liner leather. make it more even . Nice collar I like your design -
need to be pretty close to square the above companies dint carry them so still looking for a supplier....... If I was smarter I could post a picture of the hobbles
if your stamp has a lot of detail the steel stamps hold up well and can give great detail the delrin also work well but wont hold up as long. Delrin are cheaper to buy both of these would be to make an impression in the leather. I wouldnt try branding with a stamp .
thanks guys I hadnt look here in a while had given up getting a response and if you find some more somewhere just message me THANKS AGAIN
I am looking for a supplier of approximately 2 in square metal loops around 1/4 in round stock and welded . preferably stainless they need to be pretty strong as they are for a quick change horse hobble. mast used to carry them but they are out of business and weaver doesnt have anything that big
I doubt you did that with the sprayer it looks just everyday wear and stuff being stacked on it as already mentioned I use an air compressor to blow the loose the dirt off then blue foam cleaner and water and a tooth brush to get down into the tooling grooves . the foaming helps lift the dirt . and brush gently for the really stubborn dirt down in the tooling grooves I use a hand held pump srayer and on the tightest setting and squirt the dirt out . then let it dry out completely at room temp this can take several days depending on the humidity, after its completely dry I will put a product like Bic 4 on it restore the fats in the leather don't saturate the leather with oil light coats for restorations . If its a work saddle the power washer works just stay back a little . the water wont hurt the leather as long as you let it dry out and replace the fats in the leather without saturating it.
- 17 replies
- help
- saddle restoration
(and 2 more)
I bought my first new machine and its the best money I ever spent from Steve at cobra . any problems were caused by me and Steve straightened it out over the phone . I bought a second new machine from another vendor and have regretted it since it got to my shop . the machine is fine the after the sale service sucked and even the president/ owner of the company was a total ass. Steve STILL helped me straighten it out even though I didnt buy from him I have learned that the sale price of the machine isnt always the only cost involved . Great customer service is also part of what you are paying for and going forward I wont be trying to save a few bucks .... and it ended up costing the same anyway just to get it do what a cobra would do. and when you screw up a project because the machine isnt working right there is yet another cost. CALL COBRA . and I promise Steve can talk you through any problem you may encounter .
I bought a used 1750 rpm 1 horse motor off Craig list years ago mounted it on a board with a on off switch . . I make discs out of hard 100% wool saddle pads. Weavers leather sell padding I believe .the synthetic pads will melt I am told . center punch the disc then turn it on true it up with a rasp to get it truley round because never seem to hit dead center for the arbor to go thru . it works pretty good for stuff I dont need a hard glass finish on but doesnt compete with a hand rubbed edge in my opinion
I have one it works fine as long as you keep the blade sharp . .... the blade gets dull pretty quick and has to be re honed seems like maybe a steeper angle on it would help . what happens is the edge on the blade starts to curl and chip. That said it must not bother me too much because I use it almost every day. I had a guy in the shop bumped the blade with the side of his hand and he had to get stitches. I had asked him several times to to move away from it and warned him several times how sharp it was.
I would like in as well
Adult area on Leatherworker.net
carver replied to Johanna's topic in Announcements and Administrivia
sign me up please -
thank you Itch getting tired of setting them by hand and need a better method
has anybody used the Weaver little wonder press to set spots ? how well does it work ? any problems with it ?
I am looking at buying a tacsew t111 . to make show chaps and repair horse blankets and sheets. has anyone used one . are they reliable? any problems with them?
if you are just getting started you cant beat the al stohlman books carried by tandy . they are inexpensive and well illustrated. I would recommend the titles- how to carve leather and leathercraft tools the carving leather is pretty basic but it explains it pretty well.It shows you some patterns and what tools to use to achieve the effect and and the tool one shows picture of the tools and how to maintain them and how to make a few such as a strop and awls. . the books might keep you from buying some tools you don't need to get started . its where I started 50 some years ago in cub scouts now I do it for a living. THe BEST tool you will have is your imagination . I see some people come up with some pretty cool techniques that they dreamed up. BUT you need the basics first GOOD LUCK
You will make yourself crazy trying to use webbing for this . Try net material . for smaller quantities ebay is probably your best source . it comes in 1 to 4 inch squares and soccer netting i would be the place to start although it may be a bit light if the bags will receive heavy use
No weaver doesnt carry what I am looking for I had bought a bunch of stainless square rings a few years back from Mast and finally ran out . I use them to make a quick change attachment for horse hobbles and have never been able to find them anywhere else . that and Weaver is starting to get a little proud of some of their hardware ..... that or I still expect 1970 prices . So Im probably just not very realistic but its sure getting hard to make a profit .
How Can I Reduce Thickness Of Leather Without A Splitter?
carver replied to thekid77's topic in How Do I Do That?
use the safety skiver then sand to smooth out any high areas. use a sanding block. to help maintain keeping it level . its a lot of work if your doing a very large area but it works well if you dont have a splitter -
I put mine in a cordless drill or my drill press turn at low speeds or you will burn the metal . it its not real dull I hold wood mounted leather strop to the ege if its pretty dull I will use a diamond stone or even a fine file . the trick is to adjust your sharpening media to the correct angle. I find this process allows me use both hands and I can control the angle better than I could trying to use a strop or sharpening stone by hand . Caution against too much pressure and dont go to to fine of a angle or the edge collapses and you have to start over.
Harness has so much oil and wax the dye doesnt penetrate very well. , then it wants to rub back off on everything it touchs at least that was my expeirence. I have lined headstall with harness and then sewed veg tanned to it and dyed the veg tanned and that works well . it would take a lot of dye to do a whole harness . I stamp all my stuff made with harnes and it takes and hold the Stamp pretty well. A customer brought me a harness leather headstall that I made 5 or 6 years ago to make them a duplicate.and the stamp still showed legibly..
