Everything posted by TwinOaks
Welcome to Leatherworker.net! We'll try to answer your questions as best we can, so feel free to ask them.
Take a look at the left toe/right toe feet available. With the right set of feet (choice of outer + the center foot), you should be able to sew to within 1/16th" of a vertical surface.....provided there's room above it for the needle bar stroke. The direction of sewing would determine which side you'd use.
We used to have some monthly 'challenges' that were designed to introduce various aspects of this craft to new members AND to encourage 'old hands' to experiment a little out of their comfort zone. I thought they were a great idea and they really helped the new members learn. As with many things, it appears that our instructors got caught up in their 'day jobs', and we had a declining rate of participation.......in short, they just fizzled out. It's been a while since we've done one, so I'm proposing one. Yes, it's a bit late in the month, but it's never too late, right? Here's the challenge: Produce an eagle's head (source of image is up to the participants).......using a swivel knife and only one other tool. Please list the tool that you use when you post your pics. Coloring is not required. This leans heavily on the carving/tooling side of this craft, which I feel is at the heart of leather crafting. I suspect we'll see a good bit of finger cuts, but I'd also like to see some out of the box creativity. For our new members, this is a great way to teach them to not only think outside the box, but to completely ignore that there ever was a box. As it's late in the month, we'll overlap a bit into February....let's try to get the pics in by Valentine's day. To our members who are just starting out: No one will be criticizing your pictures, so please don't hesitate to post them or think "it's not good enough". We all started somewhere and you might just have the next mind blowing creative technique that we've all been searching for.
What Material Do You Make Your Patterns From?
TwinOaks replied to rmr's topic in Saddle Construction
I wait until the end of "back to school" season and pick up the plastic file folders at wallyworld for about a nickel each. I use these for most of my smaller patterns. For large patterns (both of them) I like linoleum ....same reasons as Tony. -
New Holster Model
TwinOaks replied to malabar's topic in Gun Holsters, Rifle Slings and Knife Sheathes
K-man, I've been reading this and having flashbacks!!! Ah......hindsight is a fine thing, but only once one has the seasoning to see their mistakes. Malabar, I hope you have good success with your holster design. In a year or two, when you're writing a 'thank you' letter to a forum member for helping you learn what works, what sells, and for pointing out where you were going wrong.....gimme a shout. I think I can drag up the letter I sent to K-man doing exactly the same thing. This thread is strikingly similar to the thread in which I made a complete arse of myself...arguing holster design with one of the best in the business. Thankfully, that post was lost in the great crash. -
Nice job on those, and Welcome to Leatherworker.net!
Basket Weaved Belt Rig
TwinOaks replied to Eaglestroker's topic in Gun Holsters, Rifle Slings and Knife Sheathes
It may be the result of too much pressure....maybe it's just the photo. Lonerider - your posts in this thread seem like nothing more than TROLLING. In the first post, the OP says comments and critiques are welcome. Well....there's been some. If you have differing critiques, please include them. If you have a dispute with another member, please handle that through PMs or the 'Report' button, but please don't hijack a thread to pick a fight. -
Consider this: Most of us sew with nylon or polyester thread. Both will stretch, so replacing tanned hide with thread that stretches won't reduce the stretching. It might retard the stretching if you were to use a non stretching thread like linen, but I think it likely that a tension force on the thread would only make the stitches pull tighter into the leather...because the leather can be compressed. So...unless you have a substance inside the belt that will resist stretching, it's likely to stretch...UNLESS the belt itself is strong enough to resist the forces that stretch it. This is probably accomplished most easily by using a double layer of leather, which a lot of us do. It's also accomplished by building the belt the right size to begin with (getting the holes punched at the right place).
New To Leather, Holster Question
TwinOaks replied to Dieselman's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Now that you've got the looseness mostly resolved, I'll also add that the high detail boning (following the exact lines of the pistol) is less important than correctly molding the holster. The boning LOOKS good on a holster, but the purpose is to increase the amount of leather that's in contact with the steel. Increasing the surface contact increases the amount of friction that's holding the pistol in place. Having a deep dent at the trigger means that there's only retention at the trigger. Getting the leather tight around the slide provides tension/friction along the entire length of the slide. When you get the molding and stitching right, then the additional boning just adds to it.....but as you've seen, it doesn't replace it. -
I wasn't referring to the shape of the holster's toe, but to the corner of the leather. After sanding the shape, you can go back with an edger and lightly break the sharp corner left by sanding....or just round it over as you slick/burnish the edge. Either way gives a more finished look. I prefer to go ahead and use the edger to remove the corner, then slick and burnish it. That way there's no question about the fibers of the corner ever standing up and getting fuzzy. -
Excellent results in your tool modification! That is one of the nicer things about this hobby.....you can make your own rules!!
The only critique I will offer is that you need to continue the edging all the way around the toe of the holster. It looks a bit 'off' to have everything else with a nice edge and then have that sharp corner at the toe. -
There's really nothing to add to Dwight's and Katsass' posts, so I'll just say "Welcome to Leatherworker.net!" -
I use the same Osborne as Katsass, but I also modified another one. I accidentally broke the blade, so instead of tossing it out, I just epoxied the rest of the blade back into the handle and filed/sanded it down to the proper dimensions for it's size. Now, it's my "bridle awl", with a blade length of 9/16ths inch and a width of about 3/32nds.
I picked up a belt sander (1x30) from Harbor Freight and have been using it to sand edges and make tools. You can pick up SS bolts at your local hardware store and just go to town on them. After you get your shaping done, you can use the 'jeweler's rouge' to polish it. So far I've made bevelers, matters, and thumbprints/pear shaders. I really need a checkering file to do textured tools, but that hasn't been budgeted yet.
Welcome to Leatherworker.net! Glad to have you here with us.
Belt Blank Just A Little Too Large For Buckle
TwinOaks replied to TooManyHobbies's topic in How Do I Do That?
Welcome to Leatherworker.net, we're glad you found us! For such a small amount, I'd recommend using a rasp or just sand paper to reduce the belt's width at the areas that are effected. If you're really steady with a knife, you could shave 1/2 the overall excess from each side of the tongue, OR, shave the whole belt if you don't have any designs on it (or one that wouldn't be affected by the shaving). -
Thanks Michael, that was very informative. I'll be sure to refer all instances of "running down case law on issues" to you!!!! Outstanding effort finding all of that.
Short answer is if ABC is copying the design of XYZ's collars...specifically the decorative/artistic arrangement of them...then ABC is violating the copyright because they are duplicating the pattern someone else arranged.
Need To Upgrade Webstie: Need Drop Down Boxes
TwinOaks replied to RMB Custom Leather's topic in Computer Help
Have you contacted Kate (CitizenKate) about this? IIRC, she does web design professionally. I believe it's called Studio Two Dogs. -
Cobra 3 or 4, or Cowboy 3500 or 4500. The 3/3500 has a 9 inch throat and the 4/4500 has a 16inch throat. I've yet to see anyone post that having the extra room under the arm was a mistake, so you might consider looking at the 16 inch arm from the start. It's better to have the capacity and not need it than to run out of room if you're sewing something larger than you normally do. The two types of machines are fairly identical, and both come from two of our most reputable dealers that both supply exceptional after the sale service. Cobra is on the west coast, Cowboy (sold through Toledo Industrial Sewing) is in Ohio. The Cobra comes with a bit more accessories than the Cowboy, but the Cowboy is at a slightly lower price. Figure out which one is closest to you to keep shipping costs down, and go with that dealer. With either one you won't go wrong. Both Cobra and Toledo Ind. Sew. have ad banners at the top of the page. When you decide which you want and place the order, please remember to tell them that you saw their ad here.
My Work, And A Question
TwinOaks replied to hallot's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I use Aussie leather conditioner and work it in by hand. It's messy, but the friction and heat is the best way to get the conditioner into the leather. The result is very pliable. -
Holster For Glock 17 W/surefire X300
TwinOaks replied to MadMorbius's topic in Gun Holsters, Rifle Slings and Knife Sheathes
When you make a holster for anything with a light rail attached, it's pretty much going to resemble a pouch. You can get some molding in to help with retention, but since the light is almost always bigger than the trigger guard, your tension is going to be less than ideal. The best option I've found is to mold as well as possible and add a thumb strap. -
Biggest issue will be with the magazines if you're making pouches. 17 mags need almost an extra inch.
