zuludog
Everything posted by zuludog
For skiving typically narrow or small areas & edges I skive by hand using either a Japanese Leather Knife, which cuts by pushing, or an English style paring knife, which cuts by pulling I'm sure a skiving machine would do a good job, but I have neither the space nor the money for one, so for slightly larger areas I use a David Razor Plane - find it on the Net, or there are similar makes I use this to skive the fold over on belts, and sometimes the pieces for knife sheaths, which are fairly small & narrow, though obviously it would struggle to skive something like a shoulder You could also try a French Edger, though I haven't used one myself Corter Leather, Leathertoolz, and others have YT videos showing that they can achieve excellent results with a Japanese Leather Knife. Vergez Blanchard and others make a skiving knife that is rather like a broad, hand held chisel; just play around with suppliers & videos. Both my JLK & skiving/paring knife are home made, from an old plane blade and a piece of 25mm industrial hacksaw blade. I established the cutting edge & bevel with a bench grinder & oil stones, but now to keep them sharp mostly I use a strop, and occasionally wet & dry paper on a sheet of glass with a splash of water, working from grit 1,000 to 5,000 in increments.
Search the Net for George Barnsley and sons Ltd. They are one of the last traditional British leather tools manufacturer, and based in Sheffield, which is an excellent recommendation. They have various knives and other tools for leather work Contact them about sales & export if necessary
I've just remembered -- Search YT for 'Nigel Armitage pouches'. He shows several types, from simple 2 piece front & back to more complex designs Oh, and most people try a few different combinations of stitching chisels/needles/thread when they start, before they settle on what suits them; like I said, it's all part of the fun! Even though chisels should cover most of what you do, now & again you might need an awl. Search t'Net and YouTube for choosing & using a saddler's or diamond awl, but that's another topic.
Welcome to the Forum, and welcome to the fun! Yes, choosing stitching chisels, thread, and needles is confusing, and you can easily be overwhelmed & lost. I have made similar cases/pouches for my stitching chisels and small knives, though not for a multitool, but the techniques would be the same. Here are a few comments I would use 2mm thick leather and 0,6mm synthetic thread The only #18 needles I've seen on the Net are Tapestry Hand Sewing Needles, and they look too big for leatherwork. I use John James Saddler's Harness Needles, item code L3912 size 002 - but make sure you get size 002 and not 2/0 which are too big. I assume you are in the USA; JJ needles and suitable thread are sold by Rocky Mountains Leather Supply, but perhaps other Members will have their suggestions Stitching chisels with 3 to 4 mm spacing is about right. French or European chisels have prongs with flat sides and flat tips; Japanese or diamond chisels have prongs with a diamond cross section and pointed tips. Diamond chisels are slightly easier to place and make a diamond shaped hole. French chisels make a hole that is a slit and need a bit more care about placing, and some people think they give a neater stitch, though there's not much in it. Both types of hole don't actually remove any material so they will close up after stitching. The cases for chisels will probably be simple & flat. For bulkier items like small knives and multitools you'd probably need to look at wet forming or a pouch with sides or a gusset, like a belt pouch. As you've probably realised there are several videos about this, Search YT for Making a Belt / Multitool Pouch but start with something simple! Remember you shouldn't hit stitching chisels with a steel hammer, you will need a soft mallet, such as wood, hide, or nylon. Neither should you hit down on your cutting mat; I use a plastic kitchen chopping board or an old magazine. In the Sewing Leather section of this Forum there is a Thread(!) about stitching chisels
I've just Searched the Net for 'custom knife makers usa' and there are loads of references; I'm sure you could find someone who would make exactly what you want. Or ask the same question on a knife making forum
As with JB Bodger I would have thought that some kind of marking knife or kiridashi would do the job. The link refers to a British supplier, but it shows the sort of thing to look for; I'm sure you can find an American supplier. I have made my own from a piece of 25mm industrial hacksaw blade https://www.workshopheaven.com/hand-tools/knives/marking-knives/ Search YouTube for 'kiridashi' to see more examples I know that some of the members of this forum make knives; perhaps if you posted a request someone could make what you want?
I started out with a Stanley/utility/box cutter knife. I've since acquired and used various clicker knives, a Japanese Leather Knife, and a George Barnsley head knife. They're all sharp and work OK but I find I keep coming back to the Stanley knife It's a model 199A, which I don't think they make any more. It's a fixed blade and the handle is slightly slimmer than most Stanley type knives. I got it from a second hand market stall, cleaned it up & painted it. I've picked up 2 or 3 blades that fit well without any wobbling, and I just keep sharpening & stropping them; they seem to cut better when they've been resharpened than when new.
Hatchet sheath—any helpful advice
zuludog replied to Jaxx1024's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Search YouTube for 'making a leather axe sheath' There are several videos; such as this one, but there are others -
You could do worse than to start with key chains, or key fobs as they're called in Britain. Depending on how far you want to go, they can show you - pattern making, cutting out, stitching, edge bevelling & finishing, carving, dyeing/staining, and use of the knife, and other tools Search YouTube for beginner's leather tools, techniques, and simple items such as key fobs, bookmarks, & card holders
Yes, I hear that Sinabroks tools are good. There are other top quality makers of stitching chisels, pricking irons, and other tools, such as KS Blades, Doldokki, Crimson Hides, and Amy Roke, but they are all expensive On the other hand, I've been using Craftool & Craftool Pro stitching chisels for over 10 years and they're still in good condition; find them at Identity Leathercraft Whichever you choose, you shouldn't hit chisels, irons, & punches with a steel hammer, instead use a soft hammer or mallet, such as hide or nylon. A nylon maul is fairly standard for leatherwork but I prefer a mallet, and there's only one way for you to decide John James needles are good, get JJ Saddler's Harness Needles L3912 size 002 and 004 from Artisan Leather. For any thicker thread than 0,6mm I use Stitching Needles SKU 1227 from Identity Leathercraft There are various makes of thread on the market, and most leatherworkers try a few before they settle on what they like. But you've got to start somewhere, so try these - Waxed Nylon Thread SKU 1195 from Identity Leathercraft; I think it's underrated and a small roll is cheap enough to try Ritza 25, aka Tiger Thread is very popular but usually you can only buy full rolls, which makes it expensive to buy into. I think Artisan Leather's own brand of waxed braided thread is just as good, and reasonably priced. They also sell Yue Fung thread, which is excellent All these threads are synthetic. Linen is becoming less popular, but some people prefer the way it feels/handles, and that it is natural. The French brand Fil au Chinois is the market leader, but there are others. Try linen to see how it compares, from any of the suppliers I've listed. Don't buy unbranded linen thread from Amazon; some is OK, some isn't, and you only find out the hard way. You'll need dyes & edge finishes; there are loads of videos about leather edge finishing Tokonole is good; Fiebings Edge Kote and their oil/spirit/pro dyes are easy to find and as good as any Here's a suggestion - do your Searching, Surfing, and shopping around; make a short list of items you fancy, then come back to us for comments & opinions
DIKMAN - you took the words out of my keyboard! That's a full tang blade; you would fit scales to each side. I think it would look good with pale wood like yew, hawthorn, cherry. Search YouTube for 'full tang knife handles' and you'll see the sort of thing
Have a look at this Thread, I've listed several UK suppliers, so you can see the sorts of things available
What you've asked is a piece of string question, but here's a start -- I use a Japanese Leather Knife, but they're not so easy to find in Britain now that Etsy UK have stopped selling knives, but they still sell other leatherwork tools; Search accordingly, I think they sell Palosanto and Vergez - Blanchard, which are good makes You could do worse than look at https://www.georgebarnsleyandsons.co.uk They have loads of tools for leatherwork, and they're Made in Sheffield - 'nuff said? Tools for life? I'm using a Stanley knife that was my fathers, and I know that dates at least from the 1960s; well the handle does, if not the blades. Get one anyway as you'll have enough things to buy when you start leatherwork, and a Stanley knife is as good as any to start with. Search secondhand stalls and see if you can find the model 199A handle; it's no longer made, but I think it's more comfortable to hold than the current types Have a look at YT videos by JH Leather, Ian Atkinson/Leodis Leather, Nigel Armitage, Leathercraft Masterclass, they tend to use good quality tools Have a look at videos of making items you'd like to, perhaps wallets, belts, knife sheaths, and others, and you'll see what other people use. Also videos on beginners tools for leatherwork, there are several videos. For all of these videos you'll see that the tools chosen are similar, but slightly different, reflecting the preferences of each person https://www.metropolitanleather.com sell Osborne tools, which are good. I have tried a few makes of awl blades, but have settled on Osborne You do need a certain number of tools to start with, but don't splurge a load of cash getting lots & lots of tools at first. Just get the minimum, then add more as you go along, and as you gain experience you'll be able to make a better choice yourself, and you'll probably also get to hear the pros & cons of various makes
Thought you might like to see this ...... as if I don't have enough already, but I'm tempted https://bladepoint.eu/collections/bladepoint-knife-blades/products/bladepoint-ghoul It is being sold in Britain by http://www.moonrakerknives.co.uk
Hmmmmm ....... I wonder .......... At the risk of sounding like John Cleese, have you actually done any leatherwork or saddle stitching yet? It's not as easy as it looks, at least not to do it neatly; remember that the people who make the YT videos such as JH Leather, Ian Atkinson, Leathercraft Masterclass, Corter Leather, Nigel Armitage and others, are experts and they've been doing it for years. And the finer or closer the stitching, the more difficult it becomes I suggest you get an awl with a small blade by Osborne or Pro Atelier Plus; 0,35 to 0,45mm synthetic thread, and John James L3912 saddler's harness needles size 004 . Then make a few card holders and wallets, and see how you get on As far as a clamp or a pony goes, if you want to make shoes, you may as well get a full size saddlers clam, aka saddlers clamp, from the start Add this to all the other stuff you'll need and you'll find that it adds up to quite a lot of money, but that's usually the case for most hobbies/sports/crafts when you start Oh, and remember you'll need leather as well!
An Osborne #41 is a fine saddler's awl blade. Try one, and if you want anything thinner or narrower you can always thin it on a sharpening stone Pro Atelier Plus have some fine awl blades by Condor, and you can have them ready sharpened & mounted if you wish. Why not try the smallest blade by Osborne or Condor, and see how you go, they're not that expensive. But I think you might find they're narrow enough As the name implies, a round awl has a round cross section, and again as the name implies it is also called a scratch awl It is used to mark out shapes & patterns on leather; to enlarge stitching holes; to tease out & adjust stitching; and various other poking & prodding jobs in leatherwork. They're cheap enough.
KEY -- I've just noticed that Artisan Leather are selling pricking irons at half price in their Clearance section. I haven't used them, but they look good, and pricking irons would be OK if you want to use an awl Oh, and you'll need a sewing clam or pony as well
I've used a few different awls, but have settled on an Osborne #42 blade in a simple pear shaped haft Traditionally you buy a separate blade & haft then fit them together yourself, which is fiddly, but you only need to do it once - either by knocking them together, or drilling & gluing with epoxy. Or shop around and buy an awl ready assembled There are several YT videos on assembling & sharpening an awl JH Leather's recent video 'awl you need to know' is helpful, also, she does stitching with an awl in many of her videos Here are some UK suppliers, not in any particular order - https://www.metropolitanleather.com https://www.leather4craft.co.uk https://www.artisanleather.co.uk https://www.proatelierplus.com https://www.identityleathercraft.com https://www.georgebarnsleyandsons.co.uk https://www.sfleather.co.uk https://www.jwoodleathers.co.uk I do leatherwork as a hobby, and I use diamond stitching chisels, so I don't need to work quickly, and I mostly use an awl to complete or open up existing holes. This means I put down my awl if I don't need it. But if you're going to use an awl for stitching, you should probably try holding the needles & awl in your hand together, so you might find a haft with a narrow neck is better for this; search for appropriate videos.
Here are a couple of tips for using stitching chisels - Lubricate the prongs by rubbing them with beeswax now & again, to make them easier to place & remove Hold down the leather with a small block of wood up against the prongs when removing them, to avoid distorting the leather & stitching holes. Sand the corners of the block to avoid scratching the leather This video shows how to use the separate pricking iron and diamond awl; she uses this method in other videos
Welcome to leatherwork -- and the Forum -- and to the fun! As you've mentioned, sorting out chisels & pricking irons is confusing; here's my explanation -- PRICKING IRONS Have short stubby teeth; you hit them lightly on the surface of the leather and make marks to show the position of the stitching holes, but you make the holes themselves with a saddler's awl aka a diamond awl.. This is the traditional method, and although it looks easy, you need experience and concentration to do it consistently and neatly. For that reason many people have moved on to -- STITCHING CHISELS Have longer prongs so you both mark the position of the holes and make the holes themselves at the same time, which is easier, but not completely foolproof, so you still have to concentrate and be precise. A further complication is that they have evolved into two types - French or European style which have flat sided prongs and flat tips Diamond or Japanese style which have prongs with a diamond cross section and pointed tips The diamond style are easier to place, but some people think the French style make a more attractive stitch, though there isn't much in it You can, of course, tap these sort of chisels lightly and use them just to mark the holes, similar to the pricking irons. If the combined thickness of the leather is too thick for the prongs to penetrate fully, usually about 7 or 8mm, you can complete the holes with an awl. For both types the prongs are set at an angle to the main body of the chisel LACING CHISELS Have larger flat prongs set in line with the main body of the chisel - you don't want these for sewing with thread I suggest you start with diamond stitching chisels with 3mm spacing, and take it from there. I don't know many suppliers in the USA but these would be as good as any to start - Diamond Stitching Chisel Set from www.weaverleathersupply.com Craft Pro Fine Diamond Chisels from www.tandyleather.com - I use these, bought them when Tandy had a store in the UK Whatever you get, you shouldn't hit chisels with a steel hammer or that will damage them, so you will also need a soft mallet, such as hide or nylon There is a Thread about stitching chisels at the start of the Sewing Leather section in this forum There are YouTube videos about choosing leatherwork tools for beginners, and also watch videos on making the items you want and you'll see how other people do things. They are similar, but slightly different, reflecting the preferences of each leather worker.
Thought you might find this mildly amusing - For members outside the UK, the department store Marks and Spencer, often just called M&S, stared to do this distinctive style of adverts on British TV a few years ago. And JH Leather has several excellent videos about leather craft
Hello SCOTTENGLISH, this is a reply to this and your other recent question about Japanese awls......... and do I detect a note of frustration there? I was both disappointed and annoyed when I started to do leatherwork, and found out that you had to sharpen awls before you could use them, but the problem is that with awls and some other leatherwork tools you run into The Law of Diminishing Returns It is fairly simple and straightforward, and therefore fairly cheap, to bash out a basic tool, but getting it sharp and working well takes more time, effort, and usually hand work & sharpening, which costs money, so the price goes up considerably. It is only the expensive custom made awls that can be used straight out of the box, like Crimson Hides, Palosanto, & Doldokki where you're looking at £60 to £100 for an awl. In effect, you're doing the makers work for them in order to keep the price down to a reasonable level Most people are not willing to pay such high prices, and are therefore willing to do some of the work themselves Traditionally you buy the awl blade & haft separately, then mount & sharpen them yourself. The usual method is to knock the haft onto the blade, which I always think is a bit crude & prehistoric. Then you have to sharpen & polish the blade, which is time consuming & fiddly Instead of knocking in the blade I sometimes drill a small hole in the haft and glue in the blade with epoxy glue Some suppliers have ready mounted awls & hafts, but you would still have to sharpen them However, although I haven't actually used one yet, I think that if I ever get another awl I'll use a haft fitted with a chuck or collet, like this https://www.metropolitanleather.com/Buy-Tools/Buy-CS-Osborne-Co-Tools/Palm-Awl-Haft-No.142 I've tried sharpening a few awl blades, but the one that needed the least work was an Osborne #42 or #43, (can't remember which), about £9 and the simple bulb style haft about £3 or £4 Have a look at Metropolitan's website for Osborne & George Barnsley awl hafts & blades; and YouTube for mounting & sharpening an awl
That little shield you use when removing your stitching chisel ...
zuludog replied to OldCanuck's topic in Leather Tools
Ah! Of Course! It's a Thingy! Perhaps I'll get round to making one, one day. -
Yes, you've got the right idea. There's no specific size or design, just make it to suit yourself - longer, or with the base and/or one side of the U wider to make it easier to hold down I vaguely remember seeing that sort of thing on a video or two, and from suppliers, but not very often, I think most people make their own I would make it from acrylic sheet or Perspex, clear or solid colour but you could get the design right with wood, and I think any hard, close grained wood would last a while anyway I, and I think other people don't cut a U shape & slot, just hold down the leather with a small length of wood placed right up against the chisel. I use some wood that I cut to make knife scales for full tang knives but this piece had a couple of faults in it. It's yew, but as I mentioned, there are many alternatives. It is 130 X 45 X 12 mm Whatever you choose, sand/round off/smooth the corners & edges so you don't scratch your leather. Oh, and I don't know its proper name either! -
Huh! Yes, it's a clicker knife, reasonably priced, and most leather craft suppliers have them, such as Weaver Leather Supply.
