Everything posted by Tugadude
I'm not suggesting that anyone is an expert after one day's study. What I am suggesting is that if you teach the proper technique and the student learns what the threads are supposed to be doing in the holes, they can fairly quickly get a decent-looking stitch. I think for some, stitching s a mystery. Sometimes they can get a decent result, sometimes not. And the trouble is they have no idea why. The mystery or mystique of the saddle stitch doesn't have to be a thing. It is a process. Yes, there is also an art to it and the more you practice and learn, the better you'll get, but good results can come from simply doing it right. That's my point. I helped someone that was struggling. They had no idea why they weren't getting results. I helped break the process down into the basics and when the lightbulb went off, you could see it. They had read and watched, but never did get the salient points until we walked through it. Their stitching went from a "D' to a "B" immediately. Yes, there are always going to be more challenging projects. I wouldn't teach a beginner how to sew calfskin gloves for example. But let's try to remove some of the "smoke and mirrors" from stitching. It is a skill that can be learned. Maybe it takes years to master, but results don't have to come slowly with proper training.
I urge you to check out these threads. They should help you sort out your struggles and get you on a better path. And I am convinced that a beginner, with zero experience could produce a decent-looking stitch in one day with the proper tools and process. Nigel Armitage himself has said that he has had students that learned the saddle stitch well enough in one day to be able to turn out aesthetically-pleasing work. Sure, there is still lots more to learn, and they should continue their education to include the proper use of an awl, etc. but they can get the basics down fairly quickly. There just isn't any reason to accept rubbish. There is help to be found.
Well, that helps a bunch. I'm sure it is quality leather and will suit your needs quite well. Since watch straps are quite small, in comparison to wallets and bags, a shell could yield a ton of them. At some point, you might wish to dive in and try one to see how it compares and whether it is ultimately worth it. If you've already used shell, disregard. Springfield Leather was selling some shells for decent prices. Don't know if they still are, but you could check their site. Make sure to come back and post some of your finished work. Would love to see what you come up with.
I'll be keeping a watch on my local store. They may be opening next Monday, as the county in which they are located is going top begin opening up by then. If they do leave the business there will be quite a void to fill. I've always believed that they had a niche where they catered to beginners and intermediates. Sure, they did do business with producers, but there are a lot of people who first laid hands on leather courtesy of Tandy. Being able to bop in and grab a bottle of color or some hardware was a joy. Not having them would definitely be felt.
I am assuming the horse butt you are getting includes the outer layer of epidermis and subsequently will have a grain to it that is somewhat apparent.
French style hand stitching process - where is the mistake?
Tugadude replied to justanil's topic in Sewing Leather
Notice how the thread in the "good" examples runs from the bottom of the slanted hole to the top of the slanted hole. It is this dynamic that results in the coveted "zig-zag" aesthetic of saddle stitching. Your method isn't achieving that. Needle priority, which one goes in first, and then where the second one goes afterwards makes a huge difference in the look. It also is difficult to keep tension when you don't have good technique. Every stitch should be tensioned similarly in order to achieve a good, consistent appearance. I urge you to review the Nigel Armitage primer on the saddle stitch. edit: Just wanted to offer encouragement. There are a lot of people on this forum that have followed either Nigel's or Ian Atkinson's advice on the saddle stitch and it makes a big difference. Remember it is a process. Learn and understand the process and then practice and I'll be you will amaze yourself at the results. -
Another thing to think about is how you punch the holes. Did you glue the leather together and then punch all the way through? If that was difficult, due to the three layers, Nigel Armitage has a video showing how to punch individual layers and have them line up. I rarely have to do this because I don't tend to stitch very thick leather, but it can be a real help when going through multiple layers of 8/9 oz. for example. The backside is always a bit of a challenge. Some people find that the backside of their work actually looks better, which is not the usual case. Nigel also talks about how to improve the look of the backside of your stitching in some of his videos.
Looks pretty good for a newbie. Stitching is part process and part practice. You need both. When I started I had little to base my progress on and I got decent results. Turns out I just got lucky because I was using bad technique. Now I obtain consistent stitching because I follow procedure. There will always be certain leathers that will challenge you but stick to the process. I own a set of those irons too and I like them very much. Go check out the 'Sewing Leather' part of the forum and look for the "sticky" topic on irons. It has some helpful info.
I checked all of the likely suspects and came up empty also. I'm thinking your approach is either tell the customer that there is no choice of color (if they insist, tell them to supply their own buckle!) or purchase the stainless steel buckle and see if you can find someone that can put a coating over it to make it black or brass. There has to be a way to do it, whether it is economical or not is a different question.
This article should help provide some answers. Some of the characteristics that make shell unique is the lack of any outstanding grain and its ability to be polished to an almost mirror shine. https://ashlandleather.com/blogs/inside-ashland/horween-genuine-shell-cordovan-vs-chromexcel-what-s-the-difference
Justanil, there is a "sticky" topic designed just for situations like this. I encourage you to check it out and to especially read what Nigel Armitage says about the saddle stitch. As far as "how to", I encourage you to check out his videos. Yes, it appears you are struggling a bit. For one thing, I don't know how you can stitch with the clam oriented vertically. I know I would have an issue with that. In practice, you want the clam to be oriented so that the stitching line is horizontal and the slants pointing down towards yourself. Stitching towards yourself is the norm. -
WILL SOMEBODY PLEASE GIVE ME A DIRECT ANSWER TO MY QUESTIONS
Tugadude replied to bryan4christ's topic in Member Gallery
Suggest you go to the 'Marketing and Advertising' part of the forum. Lots of interesting threads and good information there. For example, this one from Johanna: Regarding asking people for their advice, it doesn't surprise me that people in the business would be reluctant to share information. Some are very generous while others (probably most) are more protective. In my opinion, the leather business doesn't NEED any more leatherworkers. What it does need is innovative companies providing quality goods. Companies that move the ball down the field rather than walking over already trodden ground. There has been an explosion of sorts in the "minimalist wallet" segment over the past few years. What will be the "next big thing"? Find it or create it and you just might find your niche. If you're just going to make belts, bags and holsters, the market is flush with those already. Just my opinion. -
Recommend you check out Nigel's video on sharpening a saddler's awl. Some good advice therein.
Maybe attach the male part of the tuck to a short strap and attach the strap to that "liner". I could picture it being easier to open and close with a little strap to give it some slack.
There's no reason you couldn't take the magnets off and replace them with tuck clasps. Once the flap is closed, the tucks are hidden underneath. I see this all the time with briefcases that have real buckles that show on top while the flap actually is secured by tucks that sit beneath the straps that go through the buckle. Similar deal here maybe?
Leather envelop for mailing a letter back and forth
Tugadude replied to wheeldawg's topic in How Do I Do That?
Or perhaps a 'button and string' envelope with a wax seal added? -
That's a great story! I just think it would be good for the OP to know exactly what they are getting into. If they are going to have to pay a huge premium as compared to standard letter rates, it would be helpful to know in advance. -
https://pe.usps.com/businessmail101?ViewName=Letters I would check out the link above. I tried to find specific information on what materials are OK, but came up empty. I'm wondering whether the leather envelope, no matter the size, will be a lot more costly to mail if it cannot be processed like a "regular" paper envelope. There might be a way to reach out to the USPS to get clarification. I would find out if you can even do it before proceeding too far down the path. -
This is an interesting and somewhat polarizing question. Traditionalists would tell you that what you are doing is NOT a saddle stitch, no matter how good it may or may not look when you are finished. There is more to saddle stitching than how the threads lay in the holes. As 'threepets' correctly stated, there is not way to properly tension the threads the way you are doing it. That might be O.K. on small leather goods which don't face much wear-and-tear, but it could be deadly (literally) if used on saddlery. Saddle stitching is as much about the process as the resulting aesthetic. There is a company that produces leather goods and posts some really nice videos. The name is Corter Leather. They recently did a video which shows the way they stitch, which is similar to what you describe. They also tend not to use a pony, favoring just holding the items in their hands. Again, there is nothing wrong with that, but it isn't saddle stitching. It just isn't. I always recommend watching Nigel Armitage's videos on the saddle stitch. Ian Atkinson is another good one to watch. They both explain the importance of proper technique with the saddle stitch, but they are also not so strict that they don't see the benefits of the "new" stitching chisels that help beginners learn to stitch. In the end, use what works for you and for your products, just don't call it a saddle stitch. Edit: But by all means, you can legitimately refer to it as "hand-stitched".
That is some work to be proud of right there.
- 18 replies
- swivel knife
- homemade
(and 1 more)
I'm constantly impressed by the various talents here on the forum. Very nice job on that! Is the one pictured made from steel?
- 18 replies
- swivel knife
- homemade
(and 1 more)
Very cool. You mentioned magnets and it got me thinking in a direction I hadn't before. I've seen where folks place magnets on clams or ponys to hold needles, etc., but I never considered using magnets to hold the jaws together. Mush of the stuff I do is small. Watch straps, small wallets, etc. There is no reason why magnets wouldn't suffice to hold these kinds of lightweight items. So no need to clamp anything at all, quick and easy. Then if you are doing a large bag or something that needs to be clamped more securely you would then rely on whatever mechanism you have at your disposal. Interesting.
Extremely well done. You are really 'rocking it'! Is that a chunk of marble, or am I taking it for granite? Sorry, couldn't resist. It is actually quite cool. Not sure of any practical use, but it is an attractive paperweight.
Funny you say that because that was the first thing that came to mind. When I was a kid, Pier 1 Imports used to sell the pet rocks. What a weird thing those were. Of course Chia Pets aren't far behind.
