Everything posted by fredk
Dye first then paint the letters. Use 'Mop & Glo' floor polish for a sealant
No chaps, those are not what he is looking for, Imagine a Chicago Screw assembled, but in one piece. A flat head on each side. Some old fashioned military equipment used to attach to belts and straps using them
Thanks for these For others, to educate them; in many English towns and especially so London, trades were grouped in certain areas, all workers in one type of trade were in one district, eg the leatherworkers in one area, butchers in another, goldsmiths in another, and this is reflected today in the street names still existing
Sharp hole punch, Sharpen it and it will cut cleaner. A blunt punch is not cutting the leather cleanly
yup, you got it
ohhh, that is just sooooo nice!
I have a very large spool of thread which is not waxed. After I cut off a length I wax about 3 inches of the ends, taper, thread on needle, then pull the rest of that thread through a block of beeswax. Waxing the ends helps to keep the individual threads together and make a good taper
Unfortunately, with the loss of certain skilled trades the different styles of spoke shaves have been lost. It took me many years to find just a few replacements for ones I had stolen. There are / were three main types of spoke shave. 1. the common flat foot, straight blade type we see everywhere, strictly not a 'spoke' shave but simply a wood shave 2. a type with convex foot and convex blade, sometimes called a 'chair-makers shave' as its useful for shaving out the recess for your butt on a chair seat 3. a type with a concave foot and concave blade - the true wheel-wright's spoke shave, for making square edges round Within these three main groups there used to be a very great range of sizes, eg the #1 now only available with a 2 to 3 inch blade use to be available from 1/2" to about 15", the #2 was available in different sizes and curvatures up to about a 12" blade as was #3
Last time I used Dylon, with the powder, you mixed it into a cupful of almost hot water, when that cooled you mixed it into 1 gallon of warm water. With the liquid pots you mixed one into 1/2 gallon of warm water. End colour was just the same. Adding more dye into the water didn't alter the end colour depth, it just dyed quicker.
Bees wax on its own melts at a low temperature and dissolves easily in many drinks, such as beer. I suggest a mix of food-grade carnauba and bees wax
If its anything like the UK's Dylon dye, the liquid form is just a pre-mixed version of the powder, for convenience
Your choice of leather will determine your comfort ie, upholstery leather will have more stretch to it so it'll be a 'softer' seat, stiff veg tan will give a stiffer seat you could use upholsters webbing stretcher pliers to pull the strips, or use a framer's stretching pliers
No problem with that, no need for webbing insert
From my experience of trying to split heavy thread down - it ain't worth the effort. I could never get any but a good few inches even. I just keep it for where the heavy thick thread is useful. Good thread that I buy is only a few cents/pence per yard, my time is worth more even though I'm a cheappy per hour type
I do not think so. In fermentation of alcohol you want to exclude oxygen and allow the carbon dioxide to escape through the water trap. The CO2 is pushed out due to pressure build up in the jars. O2 cannot get into the jars through the water trap. I think a top with holes, with or without short pipes attached, in a well ventilated area is the way to go
- 54 replies
- vinegaroon
- roon
- (and 10 more)
umm, these are fancy but I use map pins into a piece of cork. The map pins cost about £/$1 for about 25 and the small blocks of cork are sliced off a larger block which cost me about £1.50. The cork pieces do need changing after much use though. Biggest problem I have with them is I keep mis-laying the wee box I keep them in
The paint will mostly flake off after minimal use. Chrome tan is not very good at holding a carved design.
Two natural vegetable tanned belts - Quality comparison
fredk replied to Mandarage's topic in Leatherwork Conversation
1.are they along the line you'll be sewing? they'll go awol under saddle stitching 2. you can use a modelling tool to burnish the leather around them to press the surrounding leather in towards the hole to make it less visible. A little bit of water dropped into the hole will help make the hole close up as well
I'll second JB Weld. I used some as a 'temporary' repair on a valve cover and on a water outlet on my 1930 Austin 7, that was 20 years ago and the JB is still holding. The valve cover is under the exhaust so it gets really hot there. The water through the outlet only gets to about 90 degrees.
Water resistant leather?
fredk replied to ScottEnglish's topic in Shoes, Boots, Sandals and Moccassins
When I used to repair medieval type shoes for medieval type re-enactors I used to glue on a modern rubber shoe sole repair patch. It was just big enough to cover just where the ball of the foot made contact with the ground. It was enough to about water proof the sole and add extra grip, especially on wet grass. -
posting that way imo is just spamming No
other sellers pay to advertise and sell
