Everything posted by fredk
Maybe the original is Wookiee hide?
I would use 1 to 1.5 mm upholstery leather for this. Sewing; place two shaped parts grain to grain, sew edges with a saddle stich, turn inside out, pad out with wadding. Fold over and glue the strap lengths Can't see signs of stiching around that bit on the front. For that I'd cut out the shape on the main piece and glue the insert in place on the inside, pad it out a bit with wadding, then glue a thin lining leather, eg pigskin, over that wadding and the insert part. Assemble as above. If the original was leather and the insert on the front was sewn; I suppose it was done by cutting out the area, leaving an edge to fold inwards, the insert and welt were sewn to that edge [grain to grain], folding the sewn part against the inside of the front panel. That would keep the stiching hidden
Historically; sword scabbards were not made of wood and covered in leather, very few were, most were just thick leather From studying actual scabbards for both swords and daggers found in London and Dublin digs there can been seen evidence that a scabbard/sheath was folded over, sewn with flesh to flesh joint then put on the blade and twisted round until the seam was along the back centre of the blade; thus no need for welts. The sewn seam was trimmed down and sometimes hammered flatter. I refer you to archeology dig records publications from the Museum of London and National Museum of Dublin A cardboard or thick paper pattern is a must for this project I think.
Another vote for LePrevo. I've been using them for nearly 17 years now. Never a glitch.
I've only ever needed to cover the base of a snap a couple of times. On those I glued the head of a rivet onto the base with the wee short stemmy bit fitting tightly into the centre hole of the snap's base
Bobbin Storage! What works for you?
fredk replied to JerseyFirefighter's topic in Leatherwork Conversation
How about a bobbin box, like this one http://www.ebay.co.uk/itm/TRIXES-25-Bobbins-Spool-Storage-Case-Box-/391409322411?hash=item5b21d049ab:g:a40AAOSwLnBX2q6g -
You don't need to be a whiz at wood work to make your own molds. Get some cuts of MDF [medium density fibreboard] from a DiY place and use a heavy duty knife [like a Stanley Utility knife] and rough sand paper to cut and shape, Then smoother sand paper to even out the curves. Then a few coats of quick drying varnish to seal it from the damp. You can shape up a block for a bag in about half-an-hour MDF is available in thickness ranging from 1mm to 25mm so even if you can't find the excact thickness you want/need/like layers can be glued to gether to make it up. You can even glue thin shaped bits on to the main block to raise portions during the molding
oooh yes, didn't feel like pacing it out today
I saw 'Belfast' and thought, 'eck, thats only 20 miles from meee!' Then I saw Maine, so add another 2,806 miles to that
Wheat pasture doctoring bag pattern
fredk replied to T Moore Medicine Hat Saddlery's topic in Patterns and Templates
They are also known as a Gladstone bag and date from the late 1890s -
I'd say you couldn't go far wrong getting some of the Al Stohlman books. There are books which have small projects in them, books on how to stitch, how to lace and many more. Al's books are well written, full of illustrations and guidance on how and why to do things. They are available through Tandy stores and also from on-line book sellers.
How do you color in fill laser engraved lettering
fredk replied to Katlyn4jc's topic in How Do I Do That?
Try using a gel ink pen. Just let the pen follow the engraved lettering. Seal after the ink had dried. -
Depends on what its needed for I've only ever made two very basic ones. For one which someone wanted for out-door cookery demos I used 1.5 - 2mm chrome-tanned upholstery leather. A bit I had was just about the right size. No pockets or anything required, just a strap to go around the waist For the other which was for a blacksmith, again for out-door demos, again no pockets, just a strap for the waist, I used 3 - 4mm veg tan, which was oiled with my beeswax/neetfoot oil mixture for the finish. Last I saw that was serving the blacksmith well.
Dart Carrying Case
fredk replied to Bob Blea's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Very excellent work so it is A thought about the elastic; what about using thin-ish belly leather. I find it has enough stretch in it to be slightly elastic and will conform to various diameters. I used some as a pen holding loop on somat, it was stretchy enough to accommodate a few diameters of pen sizes I only use velcro on the cheap throw-away items made up from scrap. For my regular items its not allowed, has to be a proper closure fitting. -
Seal the leather first, then use a gel ink pen, then seal again when ink is dry
I had two pairs of these ~ one with four teeth and one with two teeth. I binned [trashed/tossed] the two-teeth one as the teeth weren't hardened and just bent as they bit into the leather [ 1.2mm / 3oz approx] I've bought a second four-teeth pair and intend to reduce it to a two-teeth one Handy and quick to use once you get used to them, and as advised above keep your awl handy as sometimes the teeth dont punch all the way through
Acrylic paint on leather
fredk replied to Wulfing's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Here is a knife scabbard I made just over 10 years ago. The paint on it is acrylic made by Humbrol, its meant for plastic model kits. AFAIR it was first undercoated white then the colours and finally the work got two coats of Future acrylic floor 'polish'. This has been out and about February thru November, two, maybe three events per month, rain and shine ~ mostly rain here in N.I. Its been thrown in and worn with chain maille armour. Its not been looked after. Now it needs a repaint. When new; 10 years ago Now [just a short time ago actually] Now that i know about stuff like Resolene, if I was to do this again [and after its repaint] thats what'll get coated with to see if that protects it even better Once acrylic paint is dry it won't smear when Resolene is put on it. Normal acrylic paints can only be softened with an alcohol, eg IPA or Meths, or Vodka -
Daughters Project
fredk replied to Mattsbagger's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Way to go young dudette. You got yourself an apprentice -
Basically, no rules on varnish. I use a quick dry acrylic gloss varnish. A very thinned [with water] first coat, a second slightly thinned coat then around three or four top coats, lightly sanding in between each. I'm not looking a decorative gloss finish just a good water barrier. MDF soaks up the thinned varnish like a thirsty camel. It takes plenty of coats of varnish to get the surface really sealed
I sent an email directly to him and got a catalogue back within 30 minutes
I use MDF and varnish it. A lot of varnish to waterproof it. MDF is very easily cut with minor hand or power tools. Even a medium duty knife will shape it easily. MDF has no grain so it doesn't leave any grain imprint in the leather
Bestest I can do for you; http://www.ebay.co.uk/itm/2pcs-Brass-D-Shackle-DIY-Clasps-Ring-for-Keyring-Pouch-Belt-Loop-Fastener-Clip-/371839178764?var=640825166987&hash=item569357980c:m:mvpFrnNL6-GzXppqq4_f2JQ But if you go to a quality DiY store which carries decorative brass chain you may find them there cheaper. They are similar to Gyves* for attaching chain to chain or to hardpoints * aka D shackles, a similar but more O shaped version is a Bow shackle. Available in stainless steel, painted steel and brass
