fredk
Contributing Member
Everything posted by fredk
  1. Have a Happy Christmas break and a Happy New Year I'll be going off line for a few days from about 02.00 (GMT) Tuesday See you back on the other side
  2. There is usually a link on the 'assembly instructions'
  3. 140* will cook the leather and probably shrink it to uselessness. 80* to 100* is more than enuf. At 140* you are getting into the specialist realms of 'cuir bouilli'
  4. Leather hardens incrementally as temperature increases above ambient or room temperature
  5. Yes it does; drying faster, especially with some heat, will harden the leather
  6. Sell them as is. You'll get at least $25 for each of them. Advertise in your local neighborhood
  7. and skive the adjoining leather to a knife-edge thinness
  8. I have the newer cast aluminium version but as far as I can tell all the accessories can fit either You may want to heed Northmount's warning, above. Another type of sewing machine used manually, with a balance wheel motion, might suit you better
  9. I usually do it once using plenty of beeswax/carnauba wax. Just occasionally do I feel it necessary to go over a second time
  10. I think you are looking at the weight problem too simply Take a 1cm thick belt. It may weight 24 ounces. When held it one hand that weight is noticeable but spread that weight around a 42 inch waist its hardly noticeable I liken it to what I used to tell ppl about my chainmaille hauberk; held in the arms its full 35lb weight could be felt, but as its worn on the body the weight is spread around, some on the shoulders, some on the arms et cetera and then it feels no heavier than a good overcoat
  11. What is your definition of 'straight lacquer'?
  12. I would go with two layers of veg tan leather sewn together with a third layer of suede leather sewn on the inside
  13. Double line stitching isn't really for strong construction, although it will help, but for water proofing. If you look at commercial goods, such as motorcyclists' jackets, you'll find they are double stitched, and they make a good deal of noise about it I don't use a sewing machine so I'd have to say, hand sewn saddle stitching. You can pull the stitches up really tight
  14. I went almost 20 years without high priced tools. I still don't have all the fancy things you can buy. But the one thing I did buy and like and would not be without is my Tandy Pro-press. I use it for 3D/2D stamping, die cutting and now I've adapted some stitching chisels to fit it and I can punch stitching holes. All done quietly. A cheaper version of the Pro-press is available. I have a couple of the skiving machines but never use them, I always revert to my knives and Tandy Super Skiver for skiving. I use the ole' wooden strap cutter. Been using it for 24 years now, just a new blade every 5 years - joke, actually a new blade as often as required I buy a lot of things from China, mainly cos there isn't a dealer anywhere near me and they would have the same tools, made in China, but marked up by 400%.* I buy on ebay and pay via paypal that way I have buyer protection; If the tools are rubbish I can get my money back, but I very rarely get rubbish. I use a small tool for rounding my edges. Its sold on ebay as a leather edger at about £5 each. But I get them in the Beauty section, as cuticle trimmers at £4 per 10. I've bought quality French skivers at under £4 each. Leather dealers sell them for at least £20. Shop around, check different sections on ebay and you'll find good prices. Better than Amazon * look on the back of Tandy packaging, it will say made in China or Taiwan
  15. I think; You would need a double sewing line; two lines spaced a few mm apart, and maybe the leather glued together as well
  16. I use; 2mm, 3mm, 4mm, 5mm, 6mm, depending on what I'm making. But my favourite are these stitching holes pliers (they're the 2mm spacing)
  17. If you use a round point stylus on the paper over damped leather you'll get a better impression
  18. I found it would shrink quite a bit in any direction. It was totally unpredictable
  19. I use the Tandy silver pens and white correction pens on dyed leather
  20. I do the same as DieselTech
  21. I've tried both The boiling water method tightened up this knife scabbard hanger and made it very firm I never liked using an oven. I found the results too unpredictable
  22. a. I don't know anything about W&C b. you can stiffen up modest size pieces of leather yourself. By soaking in warm water then drying fairly quickly between two heavy boards*. Cover the boards in absorbent clean white paper. Your only limit is the size of the boards * or light thin boards with weights placed on them
  23. If its iron contamination, the only way I can see that sort of spread is if some one used an angle grinder near the leather allowing the 'sparks' to land on it. The 'sparks' ain't sparks but very tiny pieces of hot metal
  24. I've used my Singer 15K and 99 to sew thin upholstery grade leather. Its chrome tan about 1mm thick
