CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. Hello, Are you sure your sure your using the correct needle? it should be 21/8" long. Bob
  2. The tension discs in the front are used for darning. Bob
  3. Tom, To time the hook,the hook point needs to be @ the needle when the needlebar raises up 3/32" from BDC . Let me lnow if you have anymore questions. Bob
  4. Less foot pressure will make less feed dog marking.If your feed dogs have teeth on them you can polish off the sharpness will reduce the marking too. Can you post a better pic were I can see the top lefthand corner of the machine,it's cropped off on this one. No,a roller foot cannot be put on a walking foot machine. Bob
  5. Ok,I'll sure let you know if I hear of any. Bob
  6. Hello Eric, That's when I got into this business is 1980.I don't have either model in stock @ this time. Bob
  7. Your turning the wrong screw,the correct one is located behind were the spool of thread is in the pic,it takes a screw to go the the hole to loosen it. Bob
  8. Ferdco took the standard Juki feed dog & needle plate off & put a slotted plate & the lower needle guide on these,the problem we found is the stitch length shortened in reverse w/o the feed dog being there.
  9. Now that I'm fully awake,I'll explain it better.When it makes that noise it can lift the foot (with the leather) up on the upstroke of the needle & when that happens it won't make a good loop for the shuttle to catch & that will cause the skipping & frayed threads just like the timing being off will. Bob
  10. Mark, Sounds to me like your sewing on old or dried out leather,that's what the noise is,try putting some lube on the leather or at least between the 2- pieces & I'll bet the noise will go away. Bob
  11. Mike is real close,although it's more like a Juki 563 or Consew 255 w/a vertical bobbin, around 1/2" foot lift should sew 20 oz of leather,use up to #138 thread & it takes very common pressure feet just like the Juki & Consews. HTH Bob
  12. I'd rather own a Mitsubishi than a Yamata there's a big difference in quality.
  13. If it includes the table & motor yes that's a great price.
  14. If I was some 2000 miles closer I'd buy that Juki myself,your right tnawrot2 that is a great buy!I've seen alot worse looking ones than that. Bob
  15. Yes,that is a walking foot machine that would work for upholstery. Bob
  16. That's probably your best choice.
  17. Yes,parts are alittle more than the other machines,so are the feet,all the above machines I mentioned take the same feet so they are inexpensive
  18. Yes,if that's what you want to do is topstitch seats even 138 is plenty large enough.The Nakajima 280 isn't the best machine for large thread.Get a Singer 111w,211,Consew 225,226,255,206,Juki 562,563. There really isn't much difference between the above models except bobbin size & where it loads.
  19. Since you want to do uph type of work w/277 you need to look @ Singer 144w ,Consew 744 or Adler 220,221 type of machine. Anyone of the above will even use #346 if needed. HTH Bob
  20. Doug, Take your needle plate off & turn your machine in the direction it runs & when the point of the shuttle meets the needle the top of the eye needs to be 1/8" below the tip of the shuttle.The problem with the longer needle is if you have a needlebar thread guide on your machine you might need to take it off so you can raise the needlebar enough to get the timing correct for the longer needles. HTH Bob
  21. A roller foot lets the leather slide through easier than the standard foot. Yes,we stock the bobbin case & bobbins for it. Bob
  22. I'll have to agree @ $300.00 it's a great price & we work on alot of these & have all the parts,needles,thread,servo motors & etc in stock. Bob
  23. We sell the same machine & I'm very fimiliar with it too.The next step would be to check the needle bar height.You need to take the needle plate off & turn the machine around in the direction it runs & when the needle goes down all the way & starts to go up you need to make sure the top of the eye of the needle is about 1/8: below the hook. Bob
  24. just posted earlier today http://leatherworker.net/forum/index.php?showtopic=43014
