CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. Ok,I just found out what I thought & it's a fake! Ron's correct they never made a short arm.
  2. No,there isn't any that will fit that I know of,but on your 206 the center toe can be ground back to the center of the hole & that will help.
  3. I don't want to step on anyone here but I wanted to let you know we pretty much have every part,screw,nut,bolt,needles,feet & etc in stock for this Singer 111w machine.
  4. It was made for doing the same as your 12F welts on shoes & boots,although you can also repair tack on it your limited to the 4" workspace.
  5. I have one that sews real good & I'm trying to get $750.00 for it.
  6. On the top of the machine in the center you have a spool pin,right behind it is a large knurled nut,this is your foot pressure adjustment,turn it to the left & if you get it to loose the machine will start skipping.
  7. Great machine for chaps or up to 20 oz. of leather,uses up to #138 thread easily,207 if you work w/it. Forget breast collars on these machines,you need something heavier. The 225 is a small bobbin w/o reverse,the 255 is a large bobbin w/reverse
  8. Trox,to make things easier I changed my name to CowboyBob. Even though I'm a Juki Dealer they never seem to tell anybody much about thier machines,unless I ask,so I'll give them a call tommorrow & find out the story on the 441's.On Juki's other machines they always have a model riveted on.
  9. Andrew, The are built in different factories,there is alittle bit better quality in the Consew,but we have sold alot of both of them & they hold up very good.
  10. Some of the older Chandlers were rebadged Adlers(105-64)most parts are still available,then there's the newer ones model #305(made in Japan) that are still needle feed like the Adlers & take a few different parts than the Adler& most parts are still available for it too.Either one will sew to around 3/8" or so.
  11. Yes,I would recommend the 206 also,it's built better.
  12. Glad to help.
  13. I have sold both of these machines in the past & do not want to sell them now.There is a reason (build quality) why they are so much cheaper than a Consew.
  14. Looks like a great buy.Years ago we used to rebuild alot of them & they would sew an easy 3/8" or more of leather.
  15. Sean, I have sold a few of these yrs ago and some of the parts,screws and etc.will be hard to find and for that kind of money you should be able to get a used 206.
  16. We have them in stock in packs of 10
  17. Yes,lower the needlebar the difference between them which will be 1/4"
  18. Yes, you could replace the needlebar if you want to use the 135x8 leather needles,BUT you can use the 16x4 needles which are real easy to get if you lower the needlebar the difference of the distance between the two.It really isn't that hard to do,just turn the machine so the needlebar is all the way down,mark it where it comes out of the casting it rides in either w/a magic marker,file or even a hacksaw(just a small mark) then look under the side cover & find the screw on the needlebar clamp that will be towards the bottom & lower it the amount needed. Sounds easy huh?
  19. Ok,somebody must of raised your needlebar up to use 129 needles as they are small @ the top,leather needles in that size are very hard to get.You probably should lower the needlebar down to use a shorter needle like the 16x4 which you can get in a leather point real easy.The shorter needle will work better as it won't flex or break as easy.
  20. Is your needle your using smaller @ the top where it goes into the needle holder than the 135x5?
  21. We always sell 135x5 for this machine,they measure 11/2"& are 2,20 mm @ the top,the 126x9 measure 13/4" & are small 2.00mm & normally used in the walking foot machines,it could have been changede over the years to use either one,so measure yours & buy accordingly.
  22. Rich, That canister is a lube pot for thread lube,if your not sewing real thick or fast you don't need to lube the thread.Yes,the 5100 is the same,if you go to our website on the Cowboy 4500 page towards the bottom is a threading video.,
  23. When it gets jammed up like this put some oil all the way around the hook & like Eric said then undo the belt & rock it back & forth.
  24. Take the belts off the reducer & spin it,Darren is right I've seen the bearings go bad too.
  25. For the tension to work properly it needs to be around the one you mentioned on the side 1& 1/2x or else it'll do just what you say it's doing.
