CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. Dwayne, I never heard of a list for the serial#for the Landis one.I think I heard once they quit making them around 1910.
  2. It's already a stretch to get it to sew 207,the tension needs to be tigthed alot,so 277 won't work.It would be nice if it could but they would be prone to jamming & breaking threads.
  3. I thought I had a pic of how we mount them but I must of gotten deleted.When mounting the guide,if you try to keep it to the left & still stay on the flat part of the casting you be ok,just drill only as deep as you need to maybe 13mm,it is pretty thick there.Let me know if you have anymore questions.We took a pic.
  4. Your welcome & let me know if you need anymore help.
  5. Maybe this will help http://www.consew.com/Files/112347/InstructionManuals/230.pdf
  6. Yes,the only manual on Consews site is for the current 206RB-5 everthing is the same but the stitch length adjuster & the RB-5 also has an better oiling system.
  7. This is the older model 206RB-1,parts are still readily available for it.
  8. I made a 220v.3-phase converter out of an old 3-phase motor to run our mill.We had to mount a 110v starting motor on a board & belt it up to the old 3-phase & we turn the 110 on to spin the 3-phase then turn the 220 on & shut the 110 motor off the 220 motor keeps running & will run our mill.
  9. We used to have a couple of commercial laundries that would darn men's work shirts & pants a few yrs ago.But they aren't repairing them that way anymore so I guess it shouldn't be worth anymore than $100.00 Back maybe 10 yrs ago I could of sold it for an easy $5-600.00
  10. It's a darner used for mending shirts & pants,it has no feed dogs so you have to move the material around.Some of the parts will fit a 227 or 153,like the hook which sellls for $95.00 new,the hook gears & even the hook saddle will fit & the tension unit.
  11. Richard,I'm glad I'm able to help you and thanks for the order.
  12. We have them in stock.
  13. We also either side with a smooth bottom,those teeth will mark leather.
  14. We had a customer binding carpet yrs ago that wanted to sew so fast it was burning the thread when they stopped,we made these up & they worked.It will use alot of air but you can vary the pressure w/a valve.
  15. All you need to do is get air on the needle toards the top blowing down,you can get a piece of copper tubing (small 4mm) fasten to side of machine & aim the air towards the needle.
  16. Ian,the one on the left is called a zipper foot,for sewing next to zippers,it can also be used for sewing close to things like buckles,spots & were ever the right toe would be in the way.
  17. Here in the states we have what's called oil dry used to clean up oil on floors,spread it around & sweep it up should absorb the oil,it is like kitty litter (which might work too)
  18. You can use 277,346 & 415.
  19. Yes,the 42-5 bobbins will work,the Siner #7 class walking feet will work,you should be able to use up to #346 nylon thread & sew to 3/8" or alittle more.
  20. The longer arm stands are 7" longer,if you mount the long arm stand on the short base the leg on the left end will be between your legs & you have the make up some mounts becasue the bases where the machine mounts is also longer on the long arm.
  21. We always used the 135x17for cloth & webbing,or 135x16D for leather,you might have to drop the needlebar down alittle.
  22. Quite a few years ago I had one of these I couldn't sell so I cutoff the top of the feed dog & welded the top of one from a GA-5 on it,Adler had the parts back then but it was around $4-500.Then I made a GA-5 plate fit (had redrill the holes & after some more grinding & tweaking it sewed 1/2 "I managed to sell it then.Trox is right you'll have to stop the top feed to make it reverse,cut the slot in the plate longer so it can go up, it would work better (reverse ) if you put a roller foot on it.
  23. To make the needle plate work,the back hole in the plate needs to be drilled,the shuttles don't interchange either,the bobbins are the same,the feed parts interchange.The feed dog will work as long as you have the correct one as it may have been changed over the years(they must of had over 50 different combos for these 45K's)
  24. That looks like an Adler 105-25 mo made for sewing mocassins,you can adjust the top feed to go shorter than the bottom to get a shirring effect.This machine might sew to 3/8" thick max.but you can use heavy thread up to #346.Value I wouldn't think it would be worth much over $800.00.HTH
