CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. Do to the rotary hook design in the Consew 230 it won't sew the heaver threads & thickness as the 31-15 will. The 31's are a great workhorse of a machine no matter how old it is you can still buy parts for them. The Consews rotay hook makes it a higher speed machine like 4000 stitches per min great for sewing thin stuff like shirts,drapes & etc. Bob
  2. They usually have 3-sets of gears in them,the stitch length is controlled by a knob under the left end of the machine,you it has 3 detents on it that stops on each different stitch length,you pull the knob it out or push it in to change the stitch length. Bob
  3. You might be trying to use to large of thread,this machine is limited to the largest size of #92 or smaller like #69 or #46 HTH Bob
  4. I can get gears f/12 pr in.It can use #138 & sew close to 20oz Bob
  5. Kevin, It's a tossup.The Adler of course is made in Germany very good quality but parts are very costly & any attachments you need will almost usually have to be handmade,the 618 is a very common machine,feet & parts are much lower cost & there's more of a selection. We do stock some knockoff Adler feet but they still cost almost 2x as much as the more common 618 feet. You might want to try sewing on both & see which one you like better. HTH Bob
  6. Jeremy There stitch length is controlled by gears,usually real short like something like 14,16,18,22,24 pr in. They were made for shoe uppers. Bob
  7. Doug, It's a light duty tailor type of machine.Some parts might be hard to get. It's best to stay away from a Mercury unless it's cheap enough that you can use the table. I found the old dealers price from 1995 HTH Bob
  8. For 207 use #23 Here's a chart: http://www.tolindsewmach.com/thread-chart.html So how do you like the bigger machine? Bob
  9. Have you oiled everything on it?Don't forget to open the side cover on the left & oil all the pivot points. Now this type of machine has a walking foot & they push each other up & what happens is there will be more resistance when the back (or outside foot lifts) because there's some foot pressure on it.Lift the foot up & spin it over by hand & let me know how it works. Bob
  10. Congrats on the good buy.It sounds like all you need to do is loosen the center foot screw & turn it alittle.Your correct about the foot pressure screw if you look in the back you'll see the leaf spring that your adjusting & how when you turn it down you get more pressure,don't use the little black screw on top.On the clutch motor,they have a cork pad in them & sometimes the face of the flywheel in there gets rust on it so it grabs,there's 3-screws you can takeoff & take the clutch unit of & put a tablespoon size of grease or vaseling on it to make it slip better. Leather point needles are 135x16 you can look here: http://www.tolindsewmach.com/thread-chart.html to match your size thread with the correct size needle.You should be able to find them. You can go to Consews webiste & copy off the manual look in the resources part. Since it's been setting don't forget to oil everything that moves on it & it should be a great machine for you. Bob
  11. Put it on a long stitch & check to see if it hits in the front or back,if not you can loosen the screw in pic#1 & adjust it there,If the feed dog is hitting then you'll need to loosen the 2-screws in pic#2 that are underneath. HTH Bob
  12. The first one is a used Juki Lu 562 - from the little bit I have found to read about them it sounds like they can sew up to 20oz of leather and are an overall good machine. This particular machine has not been used in over a year, the gentleman that used it had an upholstry business and has passed away. I spoke to his wife about the machine and she said it is in good working order. She is asking $650 for the machine and a couple tables he had to go with it. Is this a good price? Would this machine work for what I do? My guess is not being used in so long it would need a good servicing. Correct? Take sample of what you want to sew & try it out,that's not to bad of a price if it sews ok,you should oil it too before you sew on it,esp the hook & bobbincase area. HTH Bob
  13. Richard, You need to loosen the 2-screws on the collar that you get to through the top plate. Also make sure you sand down any burrs on the shaft were the grooves are for the handwheel screws or it won't slide off. Let me know if you need anymore help. Bob
  14. Nice looking work there. Are both the feet lifting & clearing the material as the feet are walking? Bob
  15. This site might help you: http://sew24.blogspot.com/p/downloads.html Bob
  16. I knew I had a pic from a Cowboy 3500 we installed one on. Bob
  17. Yes,you have to move the gears (big one) & hooks in adj the hooks so they are real close w/o hitting the needle.
  18. If you still need a manual go to Consew's website,click on resources & copy off the one for the 206RB-5 your machine is very similar to it. HTH Bob
  19. They can take alot of heat,I've sewn fast before & when you stop it will burn the thread in two.That's when you know you have to slow down or start lubing the thread.We have rigged up air coolers that blow on the needle & cool them & then there is also coolsew needles that are supposed to run cooler. HTH Bob
  20. Kevin, Here's the threading diagram.Most people use a cold wax or nylon thread so the heaters won't be needed. I'll bet your gonna have fun running that monster?? Bob
  21. Here's a pic all the little spring does is keep the fish hook little part against the collar so when you turn it backwards to re-engage the clutch it pulls on this part,when it's missing use your finger to push it against the flat spot on the collar. Let me know if you need anymore help. Bob
  22. Glen, Yes,the knob on top is for the foot pressure.This machine is better suited for sewing upholstery & canvas than leather due to the feet & feed dog s marking,yes,you can work with it & make it better BUT you might be better off getting a compound walking foot needle feed. HTH Bob P.S. years ago I used to sell these new & they are a good machine.
  23. Ok,with the size 69 if you want a nice fine looking stitch you can use a #16
