shoepatcher
Everything posted by shoepatcher
  1. what part broke on the Adler? I have parts for Adlers. glenn
  2. thread size and needle you are using? glenn
  3. Y You get a copy of the service manual from Constabulary? glenn
  4. I have one for a 195 and a few for 1295, 1296 but none for 595. glenn
  5. yes original 206RB was a triple feed machine. Came out in early 1980's if I remember. Made by Seiko for Consew as was the 206RB-1. glenn
  6. nice. Needs some cleaning up and some accessories like thread stand. Download the manuals to start. glenn
  7. I might have a copy. In the meantime, download the 1295 manual. the balance wheel on the 595 you got is definitely for an H4. Big! glenn
  8. Might be able to but will be expensive. Parts list will show parts that can be switched. Both 10 and 20 use needle system 81. glenn
  9. then the feed eccentric is out 180 degrees. You have pic of the machine? glenn
  10. Have Constabulary send you copy of the manual. Bobbin winder looks complete. glenn
  11. Maybe Not hooked to a servo motor correct.? glenn
  12. Put the shuttle carrier shaft in the bushing and see if it wiggles. Is so bushing is worn and needs replacing. bushing are pressed in. My late father came up with a way to remove the bushing a with a nut, bolt and big washer. can remove old one and replace with new one with those 3 items. The shuttle carrier should just turn in the new bushing with out any wobble. To take the long drive rack out, there is a connecting screw in an access hole in the back. Screw #89. That release the long wrack. I normally have to pull the replaceable horn to replace the drive rack, The teeth on your drive rack look go. Chances are wear is in the drive pinion and the following pinion. I will also tell you the bell crank is probably worn as well. To replace that you have to take the end of the head off. 4 screws hold it on. You also have to drive the piston pin that connects to the needlebar out. It is a tapered pin that drives out from back to front. glenn
  13. Dremel the corners very light with a sanding disc. Dremel the corners very lightly with a sanding drum.; glenn
  14. yes the gap on the spring to the bobbin case. spring should fit tighter. glenn
  15. If still sewing backwards, the feed eccentric has to be 180 degrees out of adjustment. safety clutch out? glenn
  16. Loosen the lock screw on the spring and see if you can tighten the regular screw on the spring to increase the tension. Spring is up and seems to be catching on the thread. glenn
  17. Derust, clean, oil and see what you got.. she is an old girl. Missing cover plates. Alasdair got any threading info? glenn
  18. clean the machine up first and oil it good to see how it turns,\. Glenn
  19. Push the lever down for reverse. glenn
  20. I have new levers C. glenn
  21. The 29K31 is a big bobbin long arm shoepatcher. Your part number is wrong. Singer did not make a 82202. They made a 82020 needle plate for the big bobbin. I have 82020 plates. Original Simanco plates unused or New old stock. Price is $55.00 plus shipping. I do not have that many. It is compatible with the 29K30 and 31 machines as well as later big bobbin Singers. Let me know if you want it. glenn
