Everything posted by motocouture
Meanwhile, managed to squeeze some work in today. Attached and stitched the straps to the back of the clutch. Took a photo of the inside to show where I’ve included some extra reinforcement behind the hardware, straps and mouth of the clutch. Kinda winging it, but the outer is fairly stiff, so I don’t think I’ll need a lot. Also installed the hardware on the front flap, ahead of gluing the lining in.
Great idea! Much fancier than my old wine corks ....
Like the design detail for the pencils, smart.
Thank you! Been playing with my Xmas present to myself, a fileteuse. Edges still frustrate me enormously; I suspect that will be a lifelong process.... i didn’t try the Barge in this keeper, although I believe you can. I would decant some into a small, metal lid screw top jar to store. Bought two of these new containers with the intent on using one for Barge, then was so happy with the Renia that I sent the Barge back to the laundry to sit with the other random household chemicals that we seem to collect.
Not too expensive. I sourced mine from Sorrell’s Notions and Findings (slight delay for shipping, since it was %£$!@ cold here for a while), and from memory it was around $30 for an amount I think I’ll struggle to go through in a year. It’s water-based, but not water-soluble once dry. The bond is good, although I think mine got a little frozen (no names, no pack drill, but someone didn’t bring the package inside straight away while I was away on business travel..... ), which I’m pretty sure doesn’t help it any. That said, it’s been fine on straps etc, with holding right to the edge when edge finishing. And worlds better than sacrificing neurons (the few I have left) to the aromatic presence of Barge. I think you’re right about the Teflon!
@Mokerson I promised a glue review...I’m lovin’ the Renia glue. Was using Barge, but I found it evaporated quickly to a gooey mess, and was scaring my family out of the basement. I’m using two different glues, the temporary bond and the Aquilim 315 permanent contact cement. For storage, I decided to give the TS Boy glue pots a go. They’re obviously made out of something impressive, as my sharpie wouldn’t even stay put when trying to write on them. Despite looking like small toilets, they work really well. Bought a couple of brushes, but don’t use them. Make do with small offcuts of my thin kitchen cutting boards (use them as bag stiffeners), and just wipe them off after use. I’ve posted a couple of pics that show the 315 glue when first applied, then after about 20 mins. I’m a complete novice with this glue, but from my initial experimentation, it seems to works best if you apply to both sides, then let it dry to fully clear before sticking together. After placing the pieces together, I hammer, then press. Found that it’s a little stickier on needles than the Barge, if hypothetically you’re impatient and try to stitch too soon...once it’s dry though, very easy to stitch through, and remove from edges of a little spills over. And, as always, it sticks reaaaaallly well to fingers, too.
Some progress pics from work this week. First two shots are the interior pocket, out of calf with a strip of the embossed calf as trim. The third photo shows the pre-stitched gussets (realized I will have stitched around 8 of those oval slots by the time I’m done with the body of the clutch...sigh...), along with the initial work on the straps.
Side Quiver, first post!!
motocouture replied to CalanColeman's topic in Archery Quivers and Bow Cases
Nice work! Don’t let my hubby see, or I’ll have to make him one (we both shoot Hoyt compounds). Welcome to the forum! -
If you google Cobra buckles (AustriAlpin) they might have what you’re looking for.
Hi Betty, I’ve also used yoga mats to pad MacBook cases, that might work here as a plan B One yoga mat goes a long way!
Travel Guitar Case- Best way to attach shoulder strap
motocouture replied to RKCrowe's topic in How Do I Do That?
Understand completely! That’s what helps make you better at your craft, though -
Just thinking aloud, can you design an attachment point using a D ring and a swivel clip? That way you could disperse the strain with being as concerned about the directionality of the load... buckle guy or hardware elf both have some great, high quality hardware. Pic below of how I did the attachment for a briefcase for hubby. Attachment point here is directional, but could easily be tweaked
