chisel
Everything posted by chisel
Juki LS-1341 - EM.pdfJuki LS-341N - EM.pdfHere you go.
PM sent
CS1000 MOTOR_INST.pdf See section 2.
https://www.manualslib.com/manual/1087074/Juki-Ddl-8700-7.html
It's a Juki rebranded as Chandler. I have a Chandler just like yours and if you tilt the head back and look at the bottom under the bed, it has a Juki part number in the cast iron starting with B-.
Sorry, my mistake. I had the diameter correct but the B-9117-563-000 bobbin thickness is 11.7...I need to buy a digital caliper or new reading glasses. I have black bobbins from 2015 and new chrome ones purchased earlier this year and there are no dimensional differences between them.
The Juki LU-563 bobbins I have measure 27.9 x 10.9. Part number B-9117-563-000 U bobbins I have for a Consew 255 or 339 e.g. are larger: 28.9 x 12.3
Forgive my ignorance, but what's a bobbin shim?
The Singer is a 211 that has been stretched and uses a135x17 needle. Consew 744 is a much heavier duty machine and will sew practically anything. Vs. the 211, the 744 has a longer needle bar stroke, longer max. stitch length, more clearance under the foot, and larger bobbin. 744 uses a 7x3 needle.
That's a high speed straight stitch machine, not a walking foot.
Machine is no longer available.
Issues with Juki 563 thread bunching (may have found issue)
chisel replied to bfranklin67's topic in Leather Sewing Machines
That tab goes in the notch on the underside of the needle plate. After you get that fixed, let us know how it sews. -
Seiko STH-8BLD-3, made in Japan and identical to the Consew 206RB-5. Features triple feed, 10mm max. stitch length, knee lift, bobbin winder, l.e.d. light and more. The motor is a brushless servo with a needle positioner, which has a 50mm pulley for increased torque and lower minimum speed. Includes all original accessories, belt guard, and needles. Machine, motor and table are new, the metal stand has a couple of small paint dings from moving. Depending on location, delivery and setup may be possible. Located in Henderson, KY 42420
Moving Industrial machines around the shop and outside
chisel replied to Dave9111's topic in Leather Sewing Machines
Dave9111, I use a Hoyer type lift for lifting heads that are too heavy for me to handle out of tables, but it doesn't take much of a gap in a concrete floor to stop the Hoyer if it's moving slowly. If modified with much larger and wider wheels, I believe the type of lift in the picture would be better suited for what you want to do. The hook hinges at the top, and hooks under the top cross member of a K-leg as long as the leg is close to the edge of the table. Place the hook in position, crank up and you're on your way. It will work on longer tables, but with so much leverage at the other end, it's best to crank up a little and then manually lift the other end. Let me know if you want any measurements or other info. -
I watched it. My apologies.
Top of hand wheel should be turning toward you.
When buying new, I would buy from a local dealer in case you need support after the purchase. You will be on your own with Goldstar. In Phoenix and a better price than what you quoted: https://raichert.com/product/juki-dnu1541s-shipping-truck-only-call-for-rate-800-422-3153/
things to look for when buying a used machine?
chisel replied to maggielj's topic in Leather Sewing Machines
Definitely test sewing with the machine before you consider purchasing. If you buy it, remove the machine from the table. Don't even try to transport as it is because it's very top heavy as you said. One slip up and it's game over. As you remove the four bolts holding the machine to the table, support the needle end of the machine. If the machine head is too heavy, remove handwheel. Place machine upright in vehicle and strap to walls or floor. Protect with old blankets and pillows as needed. -
If these aren't the videos then hopefully they will help. https://www.youtube.com/watch?v=X6CCxv3i4No https://www.youtube.com/watch?v=wu2OT9MtzMc
Bob, $400 for parts only or parts + labor?
Juki part number 21155502. See pics for thickness but let me know if need any other measurements. $250 including insured shipping to lower 48. PayPal, money order or cash upon pick up in Henderson, KY 42420.
What Wiz said. To illustrate, find spring #16 on rear of machine. Screw #18 presses down on the spring, so loosen screw from top of machine. It's a small hole so you'll need a narrow slotted screwdriver.
Consew 226, 226R-1, or 226R-2. AFAIK those are complete model numbers. Searching here on LW for 226 should get you lots of info.
Consew 226R
Video shows a similar hack to the LMC one that Wiz mentioned: https://www.youtube.com/watch?v=X6CCxv3i4No
