Bronson
Everything posted by Bronson
Those aren't imperfections. A knife maker friend of mine calls them "subtle variations in the hand-crafted product." Bronson
Iwb Holster - Looking For Feedback
Bronson replied to particle's topic in Gun Holsters, Rifle Slings and Knife Sheathes
First...damn you make nice stuff. Second, it looks like you may be cutting it a little close on the spacing between the grip and the top of the rear wing. I'm currently looking at redoing an IWB holster I made for a friend. It works just fine for my slim girly hands but his manly meat-paws don't have enough room to get a comfortable grip....my holster had about the same spacing as yours. Bronson -
Re-Dying Exotic Remnants?
Bronson replied to Bronson's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Good to know. Thanks, Bronson -
So I wanted to try my hand at some exotic inlays/overlays so I ordered some of the remnants from Springfield leather. Anybody have any luck re-dying exotics that have already been dyed? I'll probably try to use most of the stuff as it came to me but was just curious if there is anything I should do or watch for if I want to try dying some of it black. Thanks, Bronson
Comptac also sells their clips. http://www.comp-tac.com/catalog.php?cPath=21&osCsid=kihanoaa487fp17v1dp008fs50 They're not difficult to make. Bronson
Some advice given to me from a $$ savvy friend was to start two businesses. The business that actually makes the end product will be an LLC so your personal finances will be protected in case of lawsuit and the second businesss will own every single piece of equipment and lease it to the LLC holster making company. The LLC should have as close to zero assets as possible. Bronson
My local range had one for rent and my impression was pretty much the same as yours. I also experienced a pretty interesting failure that I've never had with any other revolver. The extractor slipped over the rim of one of the empty cases. I couldn't get the empty case out and I couldn't force the extractor back over the rim. I ended up putting a pencil down the front of the cylinder and knocking out the empty case. It was the worst malfunction I've ever had in a revolver. Bronson
My goodness that is a beautiful holster. I would much rather see something simple in design but with outstanding workmanship than something flashy that is poorly made. Bronson
What Thread Size For Holsters
Bronson replied to NC Holster Maker's topic in Gun Holsters, Rifle Slings and Knife Sheathes
A U.S. Quarter is about 1/16" thick. So you're saying that you use thread that is as thick as three U.S. Quarters stacked up? Bronson -
Hand Stitching
Bronson replied to Cattle Hide's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Get the book, it's all in there. Bronson -
Holster Making Guide
Bronson replied to Wayward Shrimp's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Would you knowingly build a house on an unstable foundation? The belt is the foundation of your carry rig. Bronson -
Pull The Dot Snaps?
Bronson replied to Sixer's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Perfectfit.com has the kit (with dies) for $106.00. You'd still need the special pull the dot die though. I never had luck setting the pull the dots with the little punch and anvil doohicky. Bronson -
Question About Sting Ray
Bronson replied to troop's topic in Gun Holsters, Rifle Slings and Knife Sheathes
A beautiful holster like that for a Glock?! Talk about putting lipstick on a pig Bronson -
Pull The Dot Snaps?
I have access to one of these snap setting tools where I work http://www.seattlefabrics.com/Press%20Snap.jpg It does require a special die (part number PNS-PTD, second from the bottom) . You may be able to find it cheaper with a little searching. Bronson -
I do it just a little different than gregintenn described. I too use a manila folder but for simplicity I like to have the crease in the folder always follow the top of the slide so I draw the belt on the folder at a 15 degree angle to the crease. Half of one, six of dozen of the other Bronson
1911 Holster Design Question
Bronson replied to Haystacker's topic in Gun Holsters, Rifle Slings and Knife Sheathes
To me it looks like it would be altogether too easy to snag the muzzle or the front sight on the lace. A corollary to Murphy's Law is that not only WILL things go wrong but they will go wrong at the exact time you need them NOT to. If the gun can get snagged, it will...at the worst possible time. Bronson -
I've got one of those....but I don't have it setup yet. I've been using sanding drums in a drill but I've slowly killed the drill because it's not meant to take sideways pressure. I've just picked up a cheap Harbor Freight straight shaft electric die grinder to replace the drill. It is made to take sideways pressure so hopefully it'll last a little longer. I think I'll need to hook it up to a dimmer switch or something though because it's only got one speed. My process right now is to put the rough drum in and sand it flat & smooth. Then the fine drum goes in to smooth it a little more. Then I cut the stitch grooves and after the edges are bevelled I smooth/round the edge by hand with some 220 grit sandpaper before burnishing. Bronson
I cut my stitch grooves after I've glued both pieces together and sanded the edges flat & smooth. Then I cut the groove around the edges on both sides because the adjustable stitch groover will give me the same distance on front and back. The trick to this is to do it after you've sanded the edges flat but before you bevel the edges. For the stitch grooves that follow the profile of a gun I do the same as Shooter McG. Bronson
Holster 1911
Bronson replied to tourglide90's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Read around here on LW.n as there are some other methods that also appear to give great results. Bronson
