Mablung
Everything posted by Mablung
Cartridge Belts: Curved or Straight?
Mablung replied to ZARDOZ the GREAT's topic in How Do I Do That?
The pre-curve bit is a lot more about creating a shortcut around the break-in process for a standard gun belt going through one’s belt loops. I doubt strongly that it makes a considerable difference for a separate cartridge gun belt, though I could be wrong. I’d not worry about it, personally. Now to fit the loops along the belt, if you go ahead and pre-curve it, I’d be more inclined to simply leave off the loops along the middle couple inches of the belt. That’s where the curve will be, so just leave those out, unless it’s critical that the loops cover the whole surface. -
You can use it for the long lines like you’re talking about, although it is a figure carving tool, more than anything, but that’ll get tedious.
The Tandy double beveler is a walking tool, or so they say. It’s technically possible to get a clean bevel with it (I’ve seen the manager of my local store do it in a class I took), but how anyone gets good enough with it short of asylum-worthy obsession with it, I couldn’t tell you.
Almost assuredly.
With nothing else to do I finally got around to it ......
Mablung replied to Gezzer's topic in Show Off!!
You, sir, are a rotten egg. -
I like it. That insert is a neat idea, too.
Fredk has this right, I think. Not sure there’s any other belt design that could conceivably qualify. Western gun belt rigs and ranger belts use essentially the same construction, with the main belt piece and billets.
Items for Sale, Services, and Wanted are all subforums under Marketplace. Open the Items for Sale subforum to find the machinery one I mentioned.
Marketplace > Items for Sale > Machinery—Sewing or Stitching.
Couldn’t have said it better. I work in a professional field and cringe whenever someone purportedly selling to that audience writes poorly, from basic matters of style to tone to word choice. Quality writing (which doesn’t have to be showy) makes a critical difference, especially for those selling to people with a grasp of communication exceeding that required to talk like a Zoomer on a YouTube short.
Sandal mid and strap opinions
Mablung replied to okiwen's topic in Shoes, Boots, Sandals and Moccassins
I made some sandals recently with 9 oz. shoulder as the sole. For casual use, that’s fine, esp if one glues a piece of rubber to the bottom. Don’t bother with a shank or stacking more layers than necessary. All that will do is make it hard, inflexible, and uncomfortable. Shanks are there for shoes with a separate heel where the sole drops to the toe, like in a dress shoe or cowboy boot. I guess some high-heeled “sandals” may have a shank, but it wouldn’t be straight like a popsicle stick anyway. Get that basic pattern, and then the world is your oyster as far as design goes. A good pattern to start with, if you don’t have one already, is the Dieselpunk.ro pattern. -
For your purposes, an Economy grade 8-10 oz. double shoulder from Tandy would be perfect. Not going to ever win any beauty awards or take tooling well, but that’s okay for this purpose. It’ll take a beating and keep on going, which it sounds is the primary characteristic you care about.
Had never thought of using acetone. Thanks for sharing, @Littlef
- 18 replies
It’s the same one I posted a while back, when I first bought and sharpened it. I’ll take some closeup pictures of the handle soon, hopefully tonight.
Small pruning saw? I like the colors.
I think it has a small brass pin peened over the handle as well, but I don’t recall off the top of my head. I’ll look at it tonight.
It’s not even close to that loose, mostly just a little displaced and allowing the tang to wiggle ever so slightly. I’m not worried about it, but an ounce of prevention is worth a pound of cure.
Does anyone have a good line on methods to tighten up a ferrule that's working loose? I have a bad habit of pressing down a little firmly on my round knife and have loosened the ferrule slightly from leverage. It's not even close to becoming a problem, but I want to know how to fix it in case I can avoid a future problem and so that I can fix a problem that arises. I've looked through here but haven't found anything addressing this particular point, so figured I'd ask in case someone could save me a little time searching hither and yon without really knowing what I'm looking for.
Thanks, all! @Aventurine and @Aven, he really liked them, and so did his mom (my sister). I look forward to seeing them get scuffed, dirty, and well-used. Thanks, @TonyV. I look forward to making many more for him!
Vinegroon
Mablung replied to rleather's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
If you look in the Dyes, etc., subforum, you’ll find a lot of discussion of this issue and related issues. -
Snap button and rivets for thicker leather
Mablung replied to Swedbeans's topic in Leatherwork Conversation
That’s thick stuff, but a Line 20 snap with either a long post or using a French edger to inset the snap pieces should work fine. Rivets come in varying post lengths. Just look at the hardware specs, and it shouldn’t be too hard to find something that fits. -
Can’t imagine why they use only six colors…
I use Barge, especially for shoe applications. Tanner’s Bond works okay for that, too, but Barge is way better. I use Tanner’s Bond or the Tandy brand Eco-Cement, or whatever it’s called, for things that don’t need as strong a hold.
- 18 replies
I made my toddler nephew a pair of moccasins for his birthday. Apologies for the lousy photo—I forgot to take some better ones of the finished pair. Frankly, I’m really proud of how they turned out; moccasin pattern-making has finally clicked with me, through going back through the fundamentals to make these. And even better, my nephew loves them. Even got a chance to give him a short primer on leatherwork while putting an extra couple stitches in the sides to tighten up the mid foot this afternoon. These are 3/4 ounce bison chrome/veg re-tan. Great leather that I really enjoy working with.
What is Mycelium Leather? Does it exist?
Mablung replied to RobertoDR69's topic in Leatherwork Conversation
Course He did. But the objection to leather is, generally, an ethical one that lacks basis. The fact God also gave us mushrooms is a red herring in that respect.
